Engine light on (No Blinks). ** resolved Servo motor cleared the light ** - 600RR.net
post #1 of 22 (permalink) Old 05-06-2014, 10:50 PM Thread Starter
Seksas's Avatar
Feedback Score: 32 reviews
so ill just make a new thread, one problem down got the bike started, thanks wrathsrr. quick gist whats done to the bike since last started.. bazzaz system with qs& z bomb installed, PAIR system taken out, arrow headers installed, servo removed replaced with TST servo eliminator..
also probably doesn't help that my kickstand kill switch is by passed? but I've rode the bike plenty of times after that no lights..
what do i check, and how?
"It's not the size of the dog in the fight, it's the size of the fight in the dog.” Mark Twain
https://www.600rr.net/vb/176-rr-other-brands-bike-build/527578-seksas-track-build.html
04 CBR600rr Track bike partout : https://www.600rr.net/vb/106-03-06-rr-parts/581209-03-04-track-bike-part-out-pcv-yoyodyne-so.html
Seksas is offline
post #2 of 22 (permalink) Old 05-07-2014, 07:57 AM Thread Starter
Seksas's Avatar
Can these scothlocs cause it?
Read up on the codes and it states that if engine light stays on no blinks it mean i have a short in the lines? Can it give me the light since my headlights are not connected? Am i missing something dumb again?
Sent from Motorcycle.com App
Seksas is offline
post #3 of 22 (permalink) Old 05-07-2014, 03:49 PM
AF600RR's Avatar
So the bike does start and the fuel pump primes?
AF600RR is offline
post #4 of 22 (permalink) Old 05-07-2014, 03:58 PM
Honderr's Avatar
I can't remember how it is exactly but don't you have to have the kickstand down for the FI light to blink and give the code? If you have it bypassed it may think it's not stopped where you can count the code. Just throwing it out there, could be way off. If I remember I can check my shop manual when I get back but I would be surprised if there is a code for no blinks.
'07 CBR 600rr
'11 MV Agusta Brutale 1090RR
Build Thread-Come on, do it! DO IT! What are you waiting for!?
Honderr is offline
post #5 of 22 (permalink) Old 05-07-2014, 04:33 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
0 blinks usually = bank angle sensor, ECM, PGM-FI fuse
Moeman is offline
post #6 of 22 (permalink) Old 05-07-2014, 06:04 PM Thread Starter
Seksas's Avatar
So can it be that i connected the bazzaz wrong?
Seksas is offline
post #7 of 22 (permalink) Old 05-07-2014, 06:05 PM Thread Starter
Seksas's Avatar
Yup everything works just that engine light is on.
Seksas is offline
post #8 of 22 (permalink) Old 05-07-2014, 06:07 PM Thread Starter
Seksas's Avatar
It has to be something with the servo or something with bazzaz connection thats pretty much the only things that would effect it cuz it worked perfect before.. Also did the pair block offs but theres not much to miss there besides that lil hose.
Seksas is offline
post #9 of 22 (permalink) Old 05-07-2014, 06:08 PM
Back in the Day
Moeman's Avatar
Images: 665
It might be possible for the light to reset on its own disconnect the battery for and reconnect it may be just may be it will clear on its own did you check the PGM-FI fuse we know you took care of the BAS issue
Moeman is offline
post #10 of 22 (permalink) Old 05-07-2014, 06:20 PM
AF600RR's Avatar
It can't be a problem with your power wire (blue scotchlock) as this would prevent the fuel pump from priming. Mine got loose and I ended up permanently soldering it in. (I think, but dont quote me on this, your Neutral detect would also prevent the pump from priming as I think mine has got loose because I had to nudge it once when my bike wouldnt prime. Hate these scotchlocks).
When you turn the ignition on, does the EML go off? Then when you start the bike, it comes back on after a couple of seconds? It could be a fault with your TST servo thing. I'm sure I have read somewhere their servo eliminator has been hit and miss.
I would also go back and recheck every connection, unplug/plug everything back in again, something may be loose.
AF600RR is offline
The Following User Says Thank You to AF600RR For This Useful Post:
Moeman (05-07-2014)
post #11 of 22 (permalink) Old 05-07-2014, 07:37 PM Thread Starter
Seksas's Avatar
I read the same thing about the servo. Is there a way to check it? Also if i connected the coil wires wron or the injectors would the bike turn on?
And yea when i put the key on it turns on then shuts off when i turn it on and then turns on and stays on. Ill double check when i get home tho.
Seksas is offline
post #12 of 22 (permalink) Old 05-07-2014, 08:22 PM
Honderr's Avatar
I've gone through a couple of the Servo emulator but they blink everytime it burns out. TST is still doing some troubleshooting with it. If you want to confirm whether or not it's the Servo emulator just plug your Servo motor back in and see if the light goes off. Mine went away every time I plugged the motor back in and I'm actually going to run the motor in it until the bugs are worked out
'07 CBR 600rr
Honderr is offline
post #13 of 22 (permalink) Old 05-07-2014, 09:48 PM Thread Starter
Seksas's Avatar
I took the oem one apart i would have to play with it to put it back together. Lol does it do anything to the bike or put in limp mode or just the light.
Seksas is offline
post #14 of 22 (permalink) Old 05-07-2014, 09:50 PM
Back in the Day
Moeman's Avatar
Images: 665
The servo motor just tricks the ECU into believing the circuit is complete so if you leave it hooked up the FI light won't come on it's not that big anyway
Moeman is offline
post #15 of 22 (permalink) Old 05-07-2014, 09:55 PM
Back in the Day
Moeman's Avatar
Images: 665
Or follow this write up
Originally Posted by alexchannell View Post
I got tired of eveyone saying it's impossible so here you go:
I've not given a super in depth testing, just riding around the block at different throttle settings and RPM ranges. EFI light didn't turn on, also checked the voltages sent to the ECU and they look good.
Here is what happens: The red and blue wires are connected to the motor and switch poles to move the exhaust valve. The feedback is a potentiometer, the green wire is ground and the yellow/red is +5V. The brown wire is the input to the ECU.
When the red wire is energized the motor spins in the direction that increases voltage to the signal (brown) wire. Therefore I set the red wire to charge the capacitor (220ohm resistor there to limit how fast it chargesit, could overshoot without it). If it needs to move the valve the opposite way the red wire goes to ground and will lower the voltage in the capacitor. This replicates the pot moving the opposite direction. The 4.7k ohm resistor is simply there to protect the input line incase you hook things up wrong and send 12V into it.
These are the components I had sitting around and can be varied. These are all common values for these components however.
Enjoy.
Moeman is offline
post #16 of 22 (permalink) Old 05-07-2014, 10:01 PM
Honderr's Avatar
Doesn't do anything to the bike besides throw the FI light. Every time my Servo emulator failed it was after I rode it and it went through a few cycles to burn out. It also blinked the code that correlates with the Servo so I would be surprised if this was actually your issue.
'07 CBR 600rr
Honderr is offline
post #17 of 22 (permalink) Old 05-07-2014, 10:04 PM
Honderr's Avatar
When you say you took the OEM one apart do you mean you cracked the motor case open? I took the cables off mine, plugged it up and bolted it back in. Only purpose it has now is keeping the FI light off
'07 CBR 600rr
Honderr is offline
post #18 of 22 (permalink) Old 05-08-2014, 03:35 AM
AF600RR's Avatar
Just plug the old one back in. If the cables have been removed that doesnt matter, just the motor is fine.
Injectors would just make it run real crap.
To me it does sound like your servo elim. Kit as the light comes on once the bike has started.
AF600RR is offline
post #19 of 22 (permalink) Old 05-08-2014, 11:51 AM Thread Starter
Seksas's Avatar
so it doesn't matter that the lil housing the holes the cables is cracked open? I thought that alone would give me the light lol but I didn't touch the lil motor that in the subframe that's still good. ill connect it tonight. gna do samcos tonight as well so ill double check all the connections as well, but I made sure it clicked in
Seksas is offline
post #20 of 22 (permalink) Old 05-08-2014, 12:03 PM
Honderr's Avatar
Nope, that is fine. I thought you cracked the motor housing itself open and was wondering why you did that
Don't worry about bolting it back in, just pop the seat off, unplug the emulator and plug in the servo. You'll know whether or not it's that in minutes.
'07 CBR 600rr
Honderr is offline
post #21 of 22 (permalink) Old 05-08-2014, 08:16 PM Thread Starter
Seksas's Avatar
Problem solved!!!!! Thanks guys for the input. it was the servo, took the cables off plugged back the oem servo motor and shes good as new! Sounds meaner then ever!
Seksas is offline
post #22 of 22 (permalink) Old 05-08-2014, 09:49 PM
Back in the Day
Moeman's Avatar
Images: 665
Great news man just follow the DYI & you would be all set then take the motor off
Moeman is offline
