hot start problem - 600RR.net
post #1 of 15 (permalink) Old 05-22-2014, 09:49 PM Thread Starter
hot start problem
08 cbr600rr starts up when cold but won't turn over when hot.
Dealer said it is clutch starter.
I removed clutch cover but didn't see anything damaged.
If the fiber plates are worn. Wouldn't that cause slippage in shifting and not start up?
hondaboss is offline
post #2 of 15 (permalink) Old 05-22-2014, 09:53 PM
tripage's Avatar
Feedback Score: 91 reviews
Your brushes in the starter could be worn and this could cause the starter not to function correctly. It won't turn over at all when hot? Is the starter relay clicking? I would look at your starter being the problem.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 15 (permalink) Old 05-23-2014, 04:52 AM Thread Starter
Replaced starter. Replaced. R/R. No go.
post #4 of 15 (permalink) Old 05-23-2014, 07:37 AM
yankee99's Avatar
I see these threads all over and most never post a solution. I am having a similar issue and pulled my starter cleaned the brushes and reinstalled with same hard cranking when hot.
I would hate to spend $250 on a starter and it not fix the problem.
yankee99 is offline
post #5 of 15 (permalink) Old 05-23-2014, 07:41 AM
yankee99's Avatar
I wonder if the copper in battery cables loses its conductive properties with age?
yankee99 is offline
post #6 of 15 (permalink) Old 05-23-2014, 07:48 AM
Bubba James's Avatar
Nope. That's part of the reason it scraps for so high. We use copper in ALOT of applications for circuitry here at thee ol' salt mine. Usually it's a copper alloy too so it doesn't oxidize as easy.
Bubba James is offline
post #7 of 15 (permalink) Old 05-23-2014, 09:13 AM
tripage's Avatar
Relay is clicking when you push the button? Is there a specific temp it won't start at but if it drops below that temp it will start?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #8 of 15 (permalink) Old 05-24-2014, 10:25 AM Thread Starter
Relay is clicking. It seems like it only starts completely cold. Might restart if I turned off right away. Also gave a little throttle.
post #9 of 15 (permalink) Old 05-24-2014, 10:37 AM
tripage's Avatar
Does the starter spin when it's hot or just turns over really slow?
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #10 of 15 (permalink) Old 05-24-2014, 11:29 AM Thread Starter
I'm pretty sure it spins. Voltage keeps dropping when it's trying to start. Don't get what they mentioned by clutch work. Starter gears look fine.
post #11 of 15 (permalink) Old 05-24-2014, 07:07 PM
Miweber929's Avatar
They mentioned starter clutch, not transmission clutch; two different things.
Battery tests good? I'd be thinking R/R and stator but if those were replaced by new parts....
Mike
Miweber929 is offline
post #12 of 15 (permalink) Old 05-24-2014, 08:31 PM Thread Starter
Yes stator and r/r good. New starter. New correct battery load tested. Where is starter clutch?
post #13 of 15 (permalink) Old 05-25-2014, 08:03 AM
Miweber929's Avatar
Should in the be the series of gears that go between the starter motor and engine, one of them should have a one way clutch on it. Look it up in your service manual, will be easy to find in there.
Mike
post #14 of 15 (permalink) Old 05-25-2014, 02:54 PM Thread Starter
Figured it out finally. Gears were fine. Dealer was wrong. Flipped my starter relay enough to twist a couple lose strands. Can't believe all the troubleshooting replacing of parts... One stupid little connection that didn't even look bad.
post #15 of 15 (permalink) Old 10-03-2014, 03:27 AM
where is the starter relay located? im having this same issue.
eunosz is offline
