HELP: Installed LP Integrated TL now NO Headlight & High Beam **Kill switch wire ** - 600RR.net
post #1 of 9 (permalink) Old 06-04-2014, 05:00 PM Thread Starter
Guys,
need help!! i installed a new Lockhart Philips integrated TL and now the Headlight and High Beam are not working. i checked the 20A fuse on the fusebox looks OK.
this is how i connected the left and right wires from the Tail light.
The turn signal wire from LP is Yellow and Blue connected like this:
Yellow- i connected them to the Blue (connector side)
Blue- i connected them to the Orange (connector side)
[Click image for larger version
i dont know if the bulbs are out????
UPDATE: i just checked the bulbs and they are good.(i put in a tested spare one i have around and they dont light)
thanks guys!!
omie_cbr is offline
post #2 of 9 (permalink) Old 06-04-2014, 07:39 PM Thread Starter
help, anyone????
omie_cbr is offline
post #3 of 9 (permalink) Old 06-04-2014, 07:52 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
The Turn signal wires usually are yellow one goes to Orange connector and the second goes to the Blue connector for left and right turn signals what kind of front turn signals you got OEM or after market and are they working or not
Moeman is offline
post #4 of 9 (permalink) Old 06-04-2014, 08:55 PM Thread Starter
these are the rear integrated tails from LockhartPhilips and came with Yellow and Blue wires as turn signal wires to the rears...Its plug and play right? so i have the connections backwards?
I tested the turn signals in the rears and they do work with the current connections but i dont have headlight LO/HI.
omie_cbr is offline
post #5 of 9 (permalink) Old 06-04-2014, 11:07 PM
Back in the Day
Moeman's Avatar
Images: 665
ok check the fuse , wiring connections , light bulb sockets and finally the bulbs themselves
Moeman is offline
post #6 of 9 (permalink) Old 06-04-2014, 11:11 PM Thread Starter
hi moeman: yes i did check the 20A fuse, checked the bulbs by using my test bulb.. same type. connections look good!!
omie_cbr is offline
post #7 of 9 (permalink) Old 06-05-2014, 12:56 AM Thread Starter
i was a ble to fix my problem!!! it was one of the wires that came loose on the starter button switch when i opened it up!!!
that #2 wire was loose on mine..i have to resolder it
this thread really helped me:!!!
thanks guys!!!..THIS FORUM ROCKS!!!!
omie_cbr is offline
post #8 of 9 (permalink) Old 06-05-2014, 01:46 AM
Back in the Day
Moeman's Avatar
Images: 665
Attachment 129234
I am glad you found the culprit the kill switch would have been my next suggestion as it has always been known to be a cause to head light issues
Moeman is offline
post #9 of 9 (permalink) Old 06-05-2014, 01:54 AM Thread Starter
Thanks Moeman!!!
omie_cbr is offline
The Following User Says Thank You to omie_cbr For This Useful Post:
Moeman (06-05-2014)
