help.....electrical problem... - 600RR.net
post #1 of 2 (permalink) Old 06-26-2014, 01:35 AM Thread Starter
Hello.
My 2003 600rr not charge battery, with full charge battery start engine and with time the battery drain. I measure the voltage and with 9000rpm I.have 12.4 volt.
Then I measure altenator the coil between it has 0.1 ohm and with 5000rpm give me 69-70 volt ac.
Is the right results?? Anything else to check? I try to fixed my self. no money :-(
Also check and rectifired with diode test and give 0.46 v.
Thanks for your time :-)
AGGAS98 is offline
post #2 of 2 (permalink) Old 06-26-2014, 09:19 AM
X-treme1's Avatar
Feedback Score: 5 reviews
I know the '03-'06 models had a lot of issues with the voltage regulator. That is most likely your problem. You should be getting around 14V at 5K RPM.
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
