charging the battery ..help - 600RR.net
post #1 of 5 (permalink) Old 04-04-2006, 09:14 PM Thread Starter
I took the battery out and left it in the basement over winter. I put the battery back into my bike last nite but the bike won't start. There is some light on the gauges but bike won't start.
So I borrowed a charger from my friend:
Manual 6V 10 A
Automatic 12V 2 A
Automatic 12V 10A
Which setting should I use and for how long?!?!
Seks is offline
post #2 of 5 (permalink) Old 04-05-2006, 11:17 AM
APEX_600RR's Avatar
did u leave the battery on the floor of your basement? if so it's probably dead for sure. you dont ever want to set batteries on the ground (especially for an extended amount of time) because its draws all of its charge from it ... its a 12v batt tho.
APEX_600RR is offline
post #3 of 5 (permalink) Old 04-05-2006, 11:48 AM
Rhino's Avatar
Images: 16
I'd say 2A over night (8-10 hours)
'04 Candy Blue CBR 600RR
Yoshi RS5 Full System
BMC Air Filter
PCIII usb
Arrow rearsets
Renthal 14/46 sprockets with 520 chain
Emission system fully removed
APR Racing brake pads
A few other minor mods that I can't remember now.
"Health is merely the slowest possible rate at which one can die"
Rhino is offline
post #4 of 5 (permalink) Old 04-05-2006, 12:44 PM Thread Starter
Before I hook the batt to the charger, the reading was 10.8V. After charging it, 12.6V...and the bike started fine :)
The battery was left on a piece of wood in the basement.
I didn't think a 2V drop in charge would make such a big diff.
Seks is offline
post #5 of 5 (permalink) Old 04-06-2006, 09:42 AM
NewRedRider's Avatar
Images: 24
Don't use that charger again. You need a 1 amp charger for 5-8hrs and the voltage needs to be 13.0-13.5v on a good battery. 12.6v is almost too low to crank and it probably won't last very long. Do you know how to push start it?
NewRedRider is offline
