loud noise when shifting up or down - 600RR.net
post #1 of 27 (permalink) Old 06-27-2014, 07:42 AM Thread Starter
CeeBeeRR's Avatar
Sometimes when i shift either up or down it would sound harsh like a chain clunk ? it shifts normal i guess. haha new with this bike stuff but i hope i can get some info
CeeBeeRR is offline
post #2 of 27 (permalink) Old 06-27-2014, 07:48 AM
JUICEBOX0331's Avatar
How much chain slack do you have? Are you running standard or GP shift? Most likely you have too much slack in the chain.
07 CBR 600rr- Track
06 636- Track
09 ZX-10r- Street
08 ZX-10r- Gone
07 R1- Gone
JUICEBOX0331 is offline
post #3 of 27 (permalink) Old 06-27-2014, 07:59 AM
koekemgh's Avatar
Clutch / throttle control
koekemgh is offline
post #4 of 27 (permalink) Old 06-27-2014, 08:42 AM
Jericho87's Avatar
+1 All the above
07 CBR600RR
Two Brothers Carbon exhaust
Jericho87 is offline
post #5 of 27 (permalink) Old 06-27-2014, 08:44 AM
dmc41's Avatar
Is it only when you go into first?
Originally Posted by Ldn View Post
I'm glad lines have been identified...even if it is all the way at bukake....
Originally Posted by Bridge_Jumper View Post
no he's not... I can already tell he's a soulless little fawker who is going to destroy everything you love
My long not exciting build, but I have hyperflo's
dmc41 is offline
post #6 of 27 (permalink) Old 06-27-2014, 08:54 AM
X-treme1's Avatar
Feedback Score: 5 reviews
Due for an oil change?
You start the game with a full pot of luck and an empty pot of experience. The object is to fill the pot of experience before you empty the pot of luck.
2010 Leyla
X-treme1 is offline
post #7 of 27 (permalink) Old 06-27-2014, 09:02 AM
dmc41's Avatar
I'm guessing the loud noise is when he goes from neutral to first or from second to first. Could be completely wrong (wouldn't be the first time) though.
dmc41 is offline
post #8 of 27 (permalink) Old 06-27-2014, 09:11 AM
koekemgh's Avatar
Have a look at all the threads started by the OP and the questions asked. Ii is obvious that the problem is with the operator and not the bike.
koekemgh is offline
post #9 of 27 (permalink) Old 06-27-2014, 11:17 AM
Austicus's Avatar
It could be the metal to metal contact in your transmission. That could be a serious issue. If you bike doesn't shift like knife through butter than something is DEFINITELY wrong.
Could also be transmission mites.
Austicus is offline
post #10 of 27 (permalink) Old 06-27-2014, 11:26 AM
dmc41's Avatar
Transmission mites was my other guess.
dmc41 is offline
The Following User Says Thank You to dmc41 For This Useful Post:
Austicus (06-27-2014)
post #11 of 27 (permalink) Old 06-27-2014, 11:36 AM
Bridge_Jumper's Avatar
Easiest way to get rid of transmission mites is to pour about 2 cups of lukewarm water through the oil filler cap. Then run the engine for a couple minutes. The water drowns the mites and gets rid of your problem
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
The Following User Says Thank You to Bridge_Jumper For This Useful Post:
post #12 of 27 (permalink) Old 06-27-2014, 01:21 PM
Moto_Junkie's Avatar
Do you change the oil after or is the milky by product better for lubing the transmission?
Moto_Junkie is offline
post #13 of 27 (permalink) Old 06-27-2014, 01:37 PM
You'll want to change it so you get rid of the mites
2W1R - IceTitan
post #14 of 27 (permalink) Old 06-27-2014, 02:55 PM
CbrRoaR600's Avatar
Haha Bridge between your posts here and the penis down the exhaust, you have my bustin up at work!
Sent from Motorcycle.com App
CbrRoaR600 is offline
post #15 of 27 (permalink) Old 06-27-2014, 02:58 PM
It works!! I'm serious
2W1R - IceTitan
post #16 of 27 (permalink) Old 06-27-2014, 03:06 PM
DO NOT use water in your oil! It is H20, which is hydrogen and oxygen. Those elements will be separated through the internal combustion process and will make your engine explode!
Only use ASE headlight fluid for boats/motorcycles.
77345 is offline
post #17 of 27 (permalink) Old 06-27-2014, 03:08 PM
headlight fluid doesn't kill tranny mites though... which is why you must use water. The headlight fluid will just mix evenly with the oil. Oil is less dense than water which is why you have to use H2O. It will go to the bottom of the engine where the transmission mites live and will conveniently drown them
2W1R - IceTitan
post #18 of 27 (permalink) Old 06-27-2014, 05:56 PM
Ldn
Ldn's Avatar
Originally Posted by bridge_jumper View Post
headlight fluid doesn't kill tranny mites though... Which is why you must use water. The headlight fluid will just mix evenly with the oil. Oil is less dense than water which is why you have to use h2o. It will go to the bottom of the engine where the transmission mites live and will conveniently drown them
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
post #19 of 27 (permalink) Old 06-27-2014, 06:07 PM
BOTM Winner 03/14
D1stylz's Avatar
Hahahaha this is great
My simple build.
RIP SpdyG_AK 22 June 2014
D1stylz is offline
post #20 of 27 (permalink) Old 06-27-2014, 08:13 PM
This is terrible, but I can't stop reading the posts. Soo much useful information
Shane J. is offline
post #21 of 27 (permalink) Old 07-02-2014, 03:23 AM Thread Starter
CeeBeeRR's Avatar
im new in this bike life. its a 14 cbr600rr witch 120 miles. sometimes when i get to 3rd gear it will clunk sometimes not. i have no idea what it could be cause i usually shift by pull the throttle back clutch in shift up let go of the clutch and it would clunk
CeeBeeRR is offline
post #22 of 27 (permalink) Old 07-02-2014, 03:26 AM Thread Starter
CeeBeeRR's Avatar
what you mean by the operator? i shift slow trying to get use to it. i pull the clutch shift up let go of the clutch sounds like a hard clunk coming from the front or middle
CeeBeeRR is offline
post #23 of 27 (permalink) Old 07-02-2014, 03:46 AM Thread Starter
CeeBeeRR's Avatar
no that clunk sound going to first is not even as close as it is when i go to second or third and it happens sometime. i think I'm shifting right. let go of the throttle pull the clutch in shift up let go of the clutch it clunks and i give it throttle and thats that
CeeBeeRR is offline
post #24 of 27 (permalink) Old 07-02-2014, 03:47 AM Thread Starter
CeeBeeRR's Avatar
still don't understands this clunk noise
that clunk sound going to first is not even as close as it is when i go to second or third and it happens sometime. i think I'm shifting right. let go of the throttle pull the clutch in shift up let go of the clutch it clunks and i give it throttle and thats that i called honda going friday
CeeBeeRR is offline
post #25 of 27 (permalink) Old 07-02-2014, 04:59 AM
YG27's Avatar
Letting go of the clutch too fast or taking to long between the clutch and the shift. Same idea in a car if you drop the clutch its going to grab hard. It's not the bike, it's you. You're either dropping the clutch. Or you're taking so long on your shifts and holding your clutch in for so long when you finally do let go of the clutch your engine speed is slower then the wheel speed and letting go of the clutch is making the engine catch up to wheel speed.
2A7X3. Aircraft Structural Maintenance.
Any corrosion (Paint, priming, identification, etc) or Fabrication (Sheetmetal, Fiberglass, Tubing, etc)
questions, go ahead and ask and I'll do the best to respond to the best of my knowledge.
Current : '08 CBR1000RR 20160213
Wrecked: '05 CBR600RR 20151221 RIP
Crashes: 2 minor low speed lowsides, 1 50MPH impact.
Injuries: 0 Broken bones, possible tear in shoulder.
YG27 is offline
post #26 of 27 (permalink) Old 07-02-2014, 11:34 AM
koekemgh's Avatar
^ See the post above. This is exactly what I meant - with some practice and experience you wil get it right. Best is to ride the bike, get the experience and stop worrying that there is something wrong with the bike.
koekemgh is offline
post #27 of 27 (permalink) Old 07-02-2014, 12:23 PM
Try shifting around 6000 rpm. Does that change anything?
77345 is offline
