Coolant in the Oil? - 600RR.net
post #1 of 6 (permalink) Old 04-08-2006, 12:18 PM Thread Starter
Coolant in the Oil?
I crashed my bike it looked ok, changed my oil and coolant was floating on top. Any ideas why this is? Thanks in advance.
dakinejb is offline
post #2 of 6 (permalink) Old 04-08-2006, 12:24 PM
tripage's Avatar
Feedback Score: 91 reviews
coolant was on top of the oil after you drained it????
Have you refilled it??? Refill it and try running it, see if it happens again..
Make sure the container your putting the oil in is clean..
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 6 (permalink) Old 04-08-2006, 12:49 PM
NewRedRider's Avatar
Images: 24
Like Tripage is saying, I hope it was collant in the drain pan and not a cracked head or block from the crash. Keep a VERY close eye on your oil. If you change the oil and see foam, grey oil, or white smoke out of the exhaust, you have a serious problem. If any of these symptoms comes true after you change the oil you'll need to run a compression test on the cylinders and a leak down test on the radiator. Don't continue to run the bike if you are mixing oil and water. Watch your temperature gauge also.
NewRedRider is offline
post #4 of 6 (permalink) Old 04-08-2006, 01:53 PM
APEX_600RR's Avatar
^^ EXACTLY. check these things out for you might have a big problem on your hands. Some oils appear to have a slightly green layer on top sometimes tho when you look at the right angle. If you do see foamy oil, white smoke and/or a distinct burnt smell when the oil cap is pulled off you may also have blown your head gasket ... you need to really look into this problem.
APEX_600RR is offline
post #5 of 6 (permalink) Old 04-08-2006, 10:33 PM Thread Starter
Yeah the coolant was just floatting on top. I will try and do wat you guys said and see what happens. Thanks.
dakinejb is offline
post #6 of 6 (permalink) Old 04-09-2006, 10:12 PM
watch when you re-drain that oil, if there is coolant in the oil and the bike has been sitting a little while, the coolant will drain out before the oil being that they dont mix
RickRR is offline
