Excessive engine braking? - 600RR.net
post #1 of 8 (permalink) Old 07-07-2014, 07:47 PM Thread Starter
Hey guys,
I am very new to mike... only about 1,000 miles on it so far.
it is a 2008 cbr600rr with 9000km, all stock except flush mount signals.
Here is my issue and I can't tell if it's all in my head or if it has always been this way but the bike seems to be engine braking really hard... regardless of the gear.
If I'm cruising along in 6th gear and 3500rpm if I let off the gas the second the throttle is closed the bike starts slowing down very rapidly but the RPM doesn't rise like normal engine braking compression...
I know it's a drivetrain issue because if I pull my clutch in while cruising I will just coast and slow down normally.
Is it all in my head? Is this normal?
Also question #2 ... I just noticed my front right turnal signal is disconnected... the connection was just hanging loose... I can't seem to find where it plugs into... do I need to remove the fairing?
Cheers
Shep546 is offline
post #2 of 8 (permalink) Old 07-07-2014, 09:55 PM
EvilMrB's Avatar
Fairing for the blinker, yes.
Marchesini Al, Leo Vince 8493, BMC, Z-Fi, Gilles vcr38gt, Samco, MPro Revolver, Ballistik 8cell, Amsoil, SuperSprox, RK GXW 520, ASV C5, Fren Tubo, Akra tank panels, TST IT, Proton, Gcraft res, PSR plates, Renthal grips, OEM Seat Cowl & CF stickers, Woodcraft Sliders/Spools/Clip-ons/Axle Sliders, Ariete Stems
EvilMrB is offline
post #3 of 8 (permalink) Old 07-07-2014, 10:54 PM
mran556's Avatar
1st gear at 15k now thats engine braking
yes its normal.
Its much easier to remove the fairing
2007 Cbr600rr Black
mran556 is offline
post #4 of 8 (permalink) Old 07-07-2014, 10:59 PM
Ldn
Ldn's Avatar
Your engine breaking won't cause a spike in RPMs unless you're downshifting. Simply letting off the throttle in 6th at 3500 won't cause the RPMs to rise. The only way to get the RPMs to go up without downshifting is with the throttle.
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
post #5 of 8 (permalink) Old 07-08-2014, 02:52 AM
AF4iK's Avatar
Yea I'd say sport bikes in general decelerate very quickly when downshifting. When in traffic, I'll often coast a bit with clutch in because it's smoother at low RPMs and doesn't slow me down as quickly.
You'll most likely have to remove the fairing to get at the signal light wiring. If you're lucky you might see it through the hole after you remove your signal or you may only have to remove the black inner fairing that's by the radiator.
AF4iK is offline
post #6 of 8 (permalink) Old 07-09-2014, 08:06 AM
JohnH79's Avatar
It's worse when you go down in to 1st gear and the rear wheel locks/chatters.
This is why I have purchased a Slipper Clutch
Akrapovic full exhaust system with Carbon Hex can, K&N air filter, HRC Bell Mouths, Worked Head, HRC Cams, HRC ECU, Power Commander V, Ignition Commander V, Ohlins Rear shock, Ohlins front fork internals, HRC fully floating front discs, Ohlins Steering Damper, Suter Slipper Clutch, Black swingarm, Rev lights, Digital Gear indicator and Oil temp gauge, braided brake lines, Tail Tidy, Single seat Cowl, Double Bubble screen, flush mount LED indicators, tinted light covers, Honda Averto Alarm & HISS
JohnH79 is offline
post #7 of 8 (permalink) Old 07-09-2014, 09:39 PM
tlambert_01's Avatar
who's mike? lol Sorry, I didn't have anything productive to say that everyone hasn't commented on yet and no one else had made the joke yet.
'09 CBR 600RR
- Two Brothers carbon fiber black series slip on exhaust
- Power Commander V
- Autotuner
- Zero Gravity double bubble dark smoke windscreen
- BK Moto V2 dual halo/demon eye projector kit
- TST smoke integrated taillight
- ASV F3 shorty levers
- flush mount front signals
- Galfer steel braided brake lines and pads
tlambert_01 is offline
post #8 of 8 (permalink) Old 07-09-2014, 10:12 PM
TBR33ZY's Avatar
Sounds like normal operation
TBR33ZY is offline
