Help Bike won't start - 600RR.net
post #1 of 7 (permalink) Old 07-13-2014, 05:00 PM Thread Starter
I was riding my bike the other day and it worked fine. The following day it would not start. Here is a link to the video of what it does when trying to start it.
At first I tried the battery, thinking this was the issue. I took the old battery to Advanced Auto Parts and got them to see if the battery would hold a charge. It wouldn't, so I bought a new battery. Even when I put this one in the issue was not resolved. I also checked the fuses on the bike, and they were all good.
I then thought it could be a spark plug issue. So I replaced the 4 spark plugs. This turned out to also NOT be the issue either. The bike does display a "Fi" indicator light that is solid. When I bought the bike he had (still has) a PowerCommander III in it. I Don't have the USB cable, or program for it, but It seems to be fine.
Does anyone know what my issue maybe, or what I should try next?
Mech is offline
post #2 of 7 (permalink) Old 07-13-2014, 05:52 PM
after the last ride did you do anything to the bike or have it in a place where something or someone could have messed with it? i had a similar problem before, i had been working on my bike put everything back together and tried to start it and the same thing happened, and it turned out a little 2 wire connector had come unplugged that i hadn't even touched
badwolf5515 is offline
post #3 of 7 (permalink) Old 07-13-2014, 07:21 PM
Sammy600's Avatar
Does your fuel pump prime?
Sammy600 is offline
post #4 of 7 (permalink) Old 07-14-2014, 08:34 PM Thread Starter
Badwolf: It is garage kept so I don't think anyone could have messed with it, however, I will glance over it again to see if any wires are disconnected.
Sammy: I just looked up how to test to see if the fuel pump is priming, I will start working on that in the next few days and Ill post back to see if that solves the problem.
Mech is offline
post #5 of 7 (permalink) Old 07-23-2014, 08:45 PM Thread Starter
Checked the fuel pump elec. wire seems to be working fine. Any other ideas?
Mech is offline
post #6 of 7 (permalink) Old 07-23-2014, 08:49 PM
blkcavy98's Avatar
You checked the electrical for the pump but do you actually hear the pump prime? Do you use your kill switch to shut the bike off?
blkcavy98 is offline
post #7 of 7 (permalink) Old 08-03-2014, 12:00 PM Thread Starter
I finally gave in and brought to a shop. Apparently the guy who installed the Power Commander had it plugged into the wrong wire, and all of the electrical connections under the tank were corroded.
Mech is offline
