cbr 600 cc rr 2013 hot start issues - 600RR.net
post #1 of 22 (permalink) Old 07-15-2014, 06:04 PM Thread Starter
archer's Avatar
hi all, I have a cbr honda 600 cc rr, 2013 red 100 km, the new 0 km buy, but I've noticed that priate the motoclicleta this cold turn it on and turn right, but when I turn hot slow to start as happens to this youtube user ... it is the same problem that explains. could someone guide me with this problem?
archer is offline
post #2 of 22 (permalink) Old 07-16-2014, 04:48 AM
VinhMym's Avatar
Images: 3
You maybe wanna take back to the dealer
VinhMym is offline
post #3 of 22 (permalink) Old 07-16-2014, 12:45 PM
I second this suggestion. You bought it brand new, thus it will - or should still have a warranty with it. Let them fix the issue...
400kg is offline
post #4 of 22 (permalink) Old 07-16-2014, 03:48 PM Thread Starter
archer's Avatar
yes, i think so, by the way, the user of the video return to dealership and until now, they can´t fix the problem. :(
archer is offline
post #5 of 22 (permalink) Old 07-16-2014, 07:39 PM
VinhMym's Avatar
Images: 3
Umm did you try to ask ur dealer to see what can they do or maybe is need to recall for the abs models ?
VinhMym is offline
post #6 of 22 (permalink) Old 07-16-2014, 09:31 PM Thread Starter
archer's Avatar
my bike is not the abs model..the dealer say it may be the inyector..:(
archer is offline
post #7 of 22 (permalink) Old 07-16-2014, 10:08 PM
VinhMym's Avatar
Images: 3
Oh really? Ummm I thought all red 2013 models is abs. Because in Cali They only sell the abs on the red model.
VinhMym is offline
post #8 of 22 (permalink) Old 07-18-2014, 12:33 AM
I got the same bike and year and mine too waas a little hard on the start and after a while it return to normal. Maybe they put low octane gaz in it? the ethanol that contains the lower octane gaz can make strange thing to happen (I'm in Québec I don't konw for other countries)
Keldom
Keldom is offline
post #9 of 22 (permalink) Old 07-18-2014, 09:21 AM Thread Starter
archer's Avatar
I realized that they used low octane fuel fill with high octane fuel but still have that problem
archer is offline
post #10 of 22 (permalink) Old 07-18-2014, 01:08 PM
VinhMym's Avatar
Images: 3
Have u try 91 gas?
VinhMym is offline
post #11 of 22 (permalink) Old 07-18-2014, 01:45 PM Thread Starter
archer's Avatar
Have u try 91 gas?
yes i refill it...
this is my bike and the issue
archer is offline
post #12 of 22 (permalink) Old 07-22-2014, 01:02 PM
CeeBeeRR's Avatar
yes i refill it...
https://www.youtube.com/watch?v=xzF6sKv_2CE
mine starts like that...
CeeBeeRR is offline
post #13 of 22 (permalink) Old 07-24-2014, 12:43 PM Thread Starter
archer's Avatar
is the fuel pump, the dealer told me..
archer is offline
post #14 of 22 (permalink) Old 07-31-2014, 12:14 AM
CeeBeeRR's Avatar
i would of return it
CeeBeeRR is offline
post #15 of 22 (permalink) Old 07-31-2014, 06:30 AM
As far as returning to the dealer to let them trouble shoot it, that is a reasonable idea.
I can tell you that I have the same bike, and mine did the exact same thing. It has however been less of an issue once I started putting some miles on it. It seems that after my 4th or 5th tank it is going away. So my guess would be the use of non-premium fuel and it just takes awhile to work it out.
mblue0122 is offline
post #16 of 22 (permalink) Old 07-31-2014, 07:59 AM Thread Starter
archer's Avatar
is true that a bike consumes more gasoina when new?
archer is offline
post #17 of 22 (permalink) Old 07-31-2014, 10:21 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
I got a suggestion for you when you start the bike do not roll the throttle just hit the starter & let the bike idle on its own fuel injected bikes do not like the throttle to be rolled during start up rolling the throttle will foul up the spark plugs as well ( flood them with too much fuel) = hard start
Moeman is offline
post #18 of 22 (permalink) Old 07-31-2014, 10:59 PM
Back in the Day
Moeman's Avatar
Images: 665
Just hit the starter do not roll the throttle let the bike idle on its own when you attempt to roll the throttle the spark plugs will get flooded with fuel & that will foul them which will make it even harder to get the engine started smoothly
Moeman is offline
post #19 of 22 (permalink) Old 07-31-2014, 11:09 PM
icepik's Avatar
I'm noticing this same issue on my '13 600RRA I picked up today. Cold start is fine, but a hot start I usually need to 2-3 cycles on the starter button to get it to fire up. No idea what they put in it for fuel as it was full when i got the bike this morning, but I'll definitely be putting premium fuel in it on the refill.
icepik is offline
post #20 of 22 (permalink) Old 08-01-2014, 01:24 AM
YG27's Avatar
The type of fuel in the bike will have nothing to do with getting it to start, it'll affect it negatively once it's started though. All the octane rating has to do with is the engines ability to compress it without detonating. It'll ignite the same on ignition. Take it to the dealership because there is a lot that will have to be ruled out.
2A7X3. Aircraft Structural Maintenance.
Any corrosion (Paint, priming, identification, etc) or Fabrication (Sheetmetal, Fiberglass, Tubing, etc)
questions, go ahead and ask and I'll do the best to respond to the best of my knowledge.
Current : '08 CBR1000RR 20160213
Wrecked: '05 CBR600RR 20151221 RIP
Crashes: 2 minor low speed lowsides, 1 50MPH impact.
Injuries: 0 Broken bones, possible tear in shoulder.
YG27 is offline
The Following User Says Thank You to YG27 For This Useful Post:
icepik (08-01-2014)
post #21 of 22 (permalink) Old 08-04-2014, 07:29 PM Thread Starter
archer's Avatar
and no recall from honda...:(
archer is offline
post #22 of 22 (permalink) Old 08-04-2014, 10:31 PM
Why would there be a recall because two or three people in an internet thread are having problems?
bp7178 is offline
