Rear Wheel Clicking noise - 600RR.net
post #1 of 11 (permalink) Old 04-17-2006, 07:13 PM Thread Starter
Mad RR's Avatar
Feedback Score: 9 reviews
I went for a short ride today about 1 block to a friend's house and I noticed a clicking noise coming from the rear wheel. When I came back home I put it up on the rear stand and turned the wheel over a few times to see if i could figure it out. It makes the clicking noise after 1 full rotation and it sounds like it's coming from inside the wheel somewhere. I checked the chain and no binds in it and I just lubed it about 100 miles ago. The bike has 10k miles on it now and I've only owned it for the last 2k and it's never made the noise before. I put a new rear tire on it 100 miles ago and no noises or problems until now. Could it be the bearing or maybe just something stuck inside the wheel? I would like to know what it is before I ride again.
2003 Black 600RR,Track , SOLD!! New track bike coming soon!!
NESBA/STT "I" #910
MADSPEED....
surf.skate.ride.drive.
Mad RR is offline
post #2 of 11 (permalink) Old 04-18-2006, 02:03 PM Thread Starter
Mad RR's Avatar
anybody have an idea?
NESBA/STT "I" #910
MADSPEED....
Mad RR is offline
post #3 of 11 (permalink) Old 04-19-2006, 02:24 AM
i had a f4i that did that i finally looked at my sprocket and half my teeth were broke off..
revhard is offline
post #4 of 11 (permalink) Old 04-19-2006, 12:01 PM
NewRedRider's Avatar
Images: 24
Definitely make sure all your teeth are on your sprockets. Did you retorque the rear axle nut or have someone else pull the tires for you? Check to see what the torque is set to now. Should be 83ft/lbs.
NewRedRider is offline
post #5 of 11 (permalink) Old 04-19-2006, 01:31 PM
Sodamninsane's Avatar
Images: 15
axle nut might be loose, have you ever taken the tire off??? something might have gotten inside the cush drive or maybe you got a rock in one of those open holes in the rim...
Sodamninsane is offline
post #6 of 11 (permalink) Old 04-19-2006, 02:03 PM
LonelyRR's Avatar
Images: 241
I had that problem!...But the clicking sound was coming from my rear suspensitheon.
Is the bike lowered?
LonelyRR is offline
post #7 of 11 (permalink) Old 04-20-2006, 06:27 PM
99SH's Avatar
Check for proper chain/sprocket alignment
99SH is offline
post #8 of 11 (permalink) Old 04-21-2006, 06:59 PM
Could also need to lube the chain.
05 Tribal
Current List of Mods:
Two Bros CF C5 Exhaust
Renthal -1/+2 520 Conversion/DID chain
Puig Smoke Windscreen
Factory Pro Velocity Stacks
Power Commander
Fender Eliminator
Integrated Tail Light
Gregg's Flushmounts
Frame Sliders
LED kit
gorrie16 is offline
post #9 of 11 (permalink) Old 04-22-2006, 08:23 PM Thread Starter
Mad RR's Avatar
I have looked at the sprocket and the teeth seem fine and the alignment, I just lubed the chain 100 miles ago, just put a new tire on about 100 miles ago ,but I torqued the axle nut to 83 ft. pounds. Bike is not lowered at all.
NESBA/STT "I" #910
MADSPEED....
Mad RR is offline
post #10 of 11 (permalink) Old 04-28-2007, 07:28 PM
i love juggggggggzzz
xxumattuxx's Avatar
Images: 11
im having this problem now, i just recently had my swingarm powder coated and after i reassembled everything it started making this clicking noise. did anyone ever figure it out?
xxumattuxx is offline
post #11 of 11 (permalink) Old 08-05-2007, 06:48 PM
pimprezawrx's Avatar
this problem just started with my 07
i changed the front sprocket to an AFAM 15t a few months ago
and made sure the nut was secure
i checked the chain/sprocket alignment and the rear axle nut torque and they are fine
i think i'm gonna go for a ride then lube it when i get back and see if that fixes the problem. if not i'll be back on here to find a solution.
pimprezawrx is offline
