Water Pump snapped - 600RR.net
post #1 of 13 (permalink) Old 10-04-2014, 06:53 PM Thread Starter
Water Pump snapped
My bike has 75k miles and I found a slight leak from my water pump. I figured, replacing the gasket will fix it.
When water pump was pulled out, I saw that it was missing a whole piece which I can only assume is in my oil pan right now.
I'm not sure when or how this broke, bikes not being ridden until I pull this piece out of my oil pan.
Suggestion how something like this can break? I'll attach pic in my next post.
fezz is offline
post #2 of 13 (permalink) Old 10-04-2014, 07:13 PM
AJ26's Avatar
Picture?
Why in the oil pan? I would think that its probably gone into the water jackets
AJ26 is offline
post #3 of 13 (permalink) Old 10-04-2014, 09:48 PM Thread Starter
It won't let me upload. I'll try again shortly. It fell into the port, water jacket may be valid. Regardless it requires I remove oil pan from what my mechanic has told me so far
fezz is offline
post #4 of 13 (permalink) Old 10-04-2014, 09:52 PM Thread Starter
fezz is offline
post #5 of 13 (permalink) Old 10-05-2014, 04:48 AM
Black & Blue
I would definitely park the bike until I had that piece out. It looks like it would be small enough that it could be anywhere in the coolant system. Yikes!
Haru - 2007 Black & Blue & Silver
| TST Industries | Tripage LED | Hindle | Toce | Spiegler | PSR | KingTech | DynoJet | Factory Pro | Shorai | Driven | HealTech | SkutrNet | Zero Gravity | Honda Racing | Pit Bull |
jme6hundy is offline
post #6 of 13 (permalink) Old 10-05-2014, 12:37 PM Thread Starter
Yeah it's parked. Oddly I'm being told it'll be found inside the oil pan. Is the coolant fed through separately inside the Oil Pan on these models?
fezz is offline
post #7 of 13 (permalink) Old 10-05-2014, 01:15 PM
blkcavy98's Avatar
Coolant and oil doesn't mix. Hence the reason for having separate spots for them
blkcavy98 is offline
post #8 of 13 (permalink) Old 10-05-2014, 05:46 PM Thread Starter
That's a given. But I'm wondering if removal of oil pan is required for this pice to be found
fezz is offline
post #9 of 13 (permalink) Old 10-05-2014, 06:47 PM
blkcavy98's Avatar
Where's LDN when needed
post #10 of 13 (permalink) Old 10-06-2014, 01:08 PM
Lyoha's Avatar
The bit that broke off isn't sitting in a cooling jacket so looking in cooling passages or worrying that it ended up in there is pointless. The water pump sits just above the oil pan so why not give it a shot and take it off? The oil pan is held in by a few bolts around the perimeter so it's easy enough to get to. I'm not too familiar with the guts of this engine as I have't had the need to dig in that deep yet but as long as there aren't any big obstructions, you should find that piece in the oil pan.
Lyoha is offline
post #11 of 13 (permalink) Old 10-06-2014, 02:40 PM
BOTM Winner 07/14
tornado bait's Avatar
Images: 17
Feedback Score: 12 reviews
The cooling system is a self contained system. DOES NOT connect to the sump despite proximity to oil pan. However, the pump is driven from a shaft that connects through the pan. This looks like the driven end of the pump that inserts through the case, which explains why you are being told to look in the oil pan.
Vortex, Tucker Rocky, Speed & Strength, BikeMaster, E4S
Cafe Racer Inc.
Tornado Bait Racing
tornado bait is offline
post #12 of 13 (permalink) Old 10-06-2014, 10:23 PM
it seems unlikely that big chunks of alloy went past the shaft from the water side to the oil side?
could those pieces be hiding in the water cooler pump housing that is driven off that shaft?
or dropped in a pan, as you where working on this?
do you have water in your oil?
tary preisser is offline
post #13 of 13 (permalink) Old 10-07-2014, 01:16 AM
That looks like the drive side of the pump. Not the impeller side.
I don't know exactly how the pump is driven but that part definitely isn't pushing water.
You can either drop the pan or pull your clutch cover. You get good access to the pan if you pull your clutch basket
wibbly is offline
