Bike won't start in gear. - 600RR.net
post #1 of 11 (permalink) Old 05-01-2006, 10:26 PM Thread Starter
When I engage the clutch, the starter will not start the bike in gear. The bike works fine, and I just have to put it in neutral, but I'm positive I could do this before. I'm guessing a sensor has gone bad, but if you could point me in the right direction to look it will be much appreciated.
TIA
04 M3
05 600rr
jetm3 is offline
post #2 of 11 (permalink) Old 05-01-2006, 10:30 PM
RL600's Avatar
Make sure the kickstand is up. A lot of people don't know thats a "kill switch". If the kickstand is down, the bike will only start in neutral. It will not start with the kickstand down and the bike is in gear, even if the clutch is in.
2006 Honda CBR600RR, Red/Black
Daily Driver.
RL600 is offline
post #3 of 11 (permalink) Old 05-01-2006, 10:37 PM
Images: 13
yep, kickstand up, clutch in and start it in gear
DarkS1de is offline
post #4 of 11 (permalink) Old 05-01-2006, 11:13 PM Thread Starter
Actually, I do know about the kickstand sensor, but it still won't fire up. I'm guessing something might be wrong with the sensor itself. But thanks for the quick replies.
04 M3
05 600rr
jetm3 is offline
post #5 of 11 (permalink) Old 05-01-2006, 11:16 PM
It's pretty simple to eliminate the kickstand sensor as the culprit. Disconnect it at the green connector up under the tank area and jump the two ends together. Done, bike now thinks the kickstand is up.
Might as well start with the easy steps.
bda116 is offline
post #6 of 11 (permalink) Old 05-01-2006, 11:35 PM Thread Starter
Thank you very much sir. I'll try it tomorrow when theres some light.
04 M3
05 600rr
jetm3 is offline
post #7 of 11 (permalink) Old 05-02-2006, 10:48 AM
NewRedRider's Avatar
Images: 24
Sounds like you're having the same problem as Mad Arab. Make sure you check your wire connectors at the clutch lever. Check this thread out also.
https://www.600rr.net/vb/showthread.php?t=47712
NewRedRider is offline
post #8 of 11 (permalink) Old 05-02-2006, 06:37 PM Thread Starter
Thanks for the info.
04 M3
05 600rr
jetm3 is offline
post #9 of 11 (permalink) Old 05-02-2006, 06:54 PM
APEX_600RR's Avatar
exactly, i got my money on the clutch engagment sensor. those units go out ALL THE TIME. I cant tell you how many of those i've come across that have been faulty ...
APEX_600RR is offline
post #10 of 11 (permalink) Old 05-03-2006, 02:47 PM Thread Starter
Thanks Red Rider and Apex, it was the sensor. Thanks
04 M3
05 600rr
jetm3 is offline
post #11 of 11 (permalink) Old 05-03-2006, 04:15 PM
Images: 24
Glad you got it! Happy riding!
