Cutting out at low revs - 600RR.net
post #1 of 13 (permalink) Old 11-02-2014, 05:46 AM Thread Starter
Hi guys I recently put diesel into my bike by mistake
I didnt start it and drained the tank. After that I put in a new fill and went for a spin but it kept on cutting out at low revs. I thought this might be the plugs so I changed them and did the oil and filter while I was at it. But still have the same problem. I should mention the bike also has a power commander on it.
I was hoping someone might know why this is happening?
Cheers
chrisb13 is offline
post #2 of 13 (permalink) Old 11-02-2014, 09:48 AM
TBR33ZY's Avatar
What rpm is it adling at before it cuts out
TBR33ZY is offline
post #3 of 13 (permalink) Old 11-02-2014, 01:07 PM
try reloading power commander map?.....
tary preisser is offline
post #4 of 13 (permalink) Old 11-03-2014, 02:12 PM Thread Starter
Im not sure what RPM it is cutting out at but Im guessing about 2-3000
Il take ot for a spin when im back home and let you know
chrisb13 is offline
post #5 of 13 (permalink) Old 11-03-2014, 05:21 PM
TBR33ZY's Avatar
Is it cutting out while idling ir riding
TBR33ZY is offline
post #6 of 13 (permalink) Old 11-04-2014, 07:04 AM Thread Starter
No (sorry I should have mentioned that) it only cuts out when you put it in gear. I have to give it a bit of a rev when I turn it on but then it will tick over fine.
chrisb13 is offline
post #7 of 13 (permalink) Old 11-10-2014, 04:09 AM Thread Starter
Just a quick update. I took the bike out for a spin at the weekend. For about 5-10 mins it was driving fine. Then the cutting out started again. It is happening when the revs dip below 2000rpm
Anyone have an ideas please?
chrisb13 is offline
post #8 of 13 (permalink) Old 11-10-2014, 10:26 AM
TBR33ZY's Avatar
What rpm does it idle at?? It should be idling aroubd 1500-2000 rpm. Any lower u need to adjust it that could be causing it
TBR33ZY is offline
The Following User Says Thank You to TBR33ZY For This Useful Post:
chrisb13 (11-11-2014)
post #9 of 13 (permalink) Old 11-11-2014, 07:41 AM Thread Starter
It is idling around around 1500 but I think its a bit too low. But the bike will tick over perfect when you turn it on but then when your driving it, it will cut out when the rves drop in any gear not just first. Could that be a sign that it is idling at too low of an RPM?
chrisb13 is offline
post #10 of 13 (permalink) Old 11-11-2014, 09:14 AM
TBR33ZY's Avatar
Damn idk lol I just remember my gsxr used to cut out cuz it was only idling around 1000-1200 rpms. Try adjusting it to abt 1800 at idle n see if that works
TBR33ZY is offline
chrisb13 (11-12-2014)
post #11 of 13 (permalink) Old 11-12-2014, 08:22 PM Thread Starter
Thanks a mill il give it a go tomorrow
chrisb13 is offline
post #12 of 13 (permalink) Old 11-13-2014, 11:32 AM Thread Starter
TBR33ZY ur a legend thanks a mill adjusted the idle rpm and its running fine. Just back in from a spin on a wet horrible day but im happy out now that it is back working 100% :-)
chrisb13 is offline
The Following User Says Thank You to chrisb13 For This Useful Post:
TBR33ZY (11-20-2014)
post #13 of 13 (permalink) Old 11-20-2014, 02:34 PM
TBR33ZY's Avatar
Just saw this bro. Glad all worked out
TBR33ZY is offline
