Front Brake Caliper tightening up - 600RR.net
post #1 of 5 (permalink) Old 05-06-2006, 12:21 PM Thread Starter
Has anyone seen anything like this? 900RR has a front brake caliper that keeps getting progressively tighter on the rotor once you squeeze the lever and let go. It is really wierd, you put on the brakes then let off and they keep braking harder and harder as if you were squeezing the brake harder and harder. This is a wierd problem, any ideas what to replace first? Caliper, Master cylinder, something else?
Boaz is offline
post #2 of 5 (permalink) Old 05-06-2006, 01:37 PM
APEX_600RR's Avatar
Thats really weird. I've seen this happen twice when someone tried puttin the wrong brake lever on. Slight pressure is put on the brakes, the pads are draggin on the discs harder than usual, they heat up and lock up. Saw a buddy low side when his front locked up at 50 when he threw an o2 R1 brake lever on his o1 R1. It could be that or possibly pads or the discs? My guess is that something isnt right and is causing them to drag, heat up and expand causing the brakes to feel like they arent completly disengaging.
APEX_600RR is offline
post #3 of 5 (permalink) Old 05-07-2006, 10:12 AM
NewRedRider's Avatar
Images: 24
When's the last time the brake fluid was changed?
NewRedRider is offline
post #4 of 5 (permalink) Old 05-07-2006, 10:19 AM
OveRReV's Avatar
Images: 16
you need to overhaul your brakes dude, usually gunk that had built-up inside is causing the brakes to lock up, if you hadn't changed the fluid for years now maybe it's time you did.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #5 of 5 (permalink) Old 05-07-2006, 11:45 AM Thread Starter
I think it was the wrong lever on there. We are going to rebuild everything anyway though.
Boaz is offline
