03 Instrument panel problems - 600RR.net
post #1 of 17 (permalink) Old 05-07-2006, 01:49 AM Thread Starter
Exclamation 03 Instrument panel problems
Hey all I'm new to this forum - recently bought a used 03' CBR600RR (in RED)
Last night while riding I noticed the right blinker signal works intermitently and the same with the high beam light. Is something lose or possibly a short?
Another pain in as well is the fuel gague seems to be off , after I fill it up it says there is only 5 of 7 blocks. Which also plays a role with the low fuel blinking. I usually will burn about 1.5 gallons of fuel until it starts to blink.
When I fill it up, I'll fitll it to the metal cage for the cap.
Is it a possibility that my instrument panel is all together messed up?
Bike still has 2 years left on the warantee.
Any help would be great! THanks!
-Craig
craig4722 is offline
post #2 of 17 (permalink) Old 05-07-2006, 02:01 AM
Ceph's Avatar
check the plug to the gauge cluster, they do tend to vibrate loose sometimes.
Ceph is offline
post #3 of 17 (permalink) Old 05-07-2006, 02:32 AM Thread Starter
And what about the funky fuel reading...is a sensor gone?
post #4 of 17 (permalink) Old 05-07-2006, 02:42 AM
Ceph's Avatar
it's prolly in the plug, try that first and let me know how it goes.
Ceph is offline
post #5 of 17 (permalink) Old 05-07-2006, 02:43 AM Thread Starter
Where is this located....I just got the bike a few days ago so bear with me, I tried to trace some of the wires to see if anything is loose...gauge seems to be covered pretty well?
-Craig
post #6 of 17 (permalink) Old 05-07-2006, 02:58 AM
Ceph's Avatar
yes it is, the plug is on the back side of the gauge cluster, and you almost have to remove the whole upper fairing to get to it... in fact, it might just be easier if you do.
Ceph is offline
post #7 of 17 (permalink) Old 05-08-2006, 12:15 PM Thread Starter
I was able to grab my younger sister and coach her into pushing the plug into the gague cluster. Now the only thing left to get fixed is the fuel problem.
It will blink that I'm empty...but then it will re-adust and say I have 2 bars left. Sometimes it even does some funky 'show of bars' where it will light them all up and then they will all dissapear slowly...i'm guessing this is what is supose to happen when you are allll out of fuel?
Anyone?
post #8 of 17 (permalink) Old 05-08-2006, 12:20 PM
NewRedRider's Avatar
Images: 24
You mean like this? If that's the case it sounds like your in tank fuel sensor may be bad or you could still have a short somewhere else.
NewRedRider is offline
post #9 of 17 (permalink) Old 05-08-2006, 01:38 PM Thread Starter
Exactly like the first diagram
post #10 of 17 (permalink) Old 05-08-2006, 01:50 PM
Images: 24
But the rest of the guage is working properly now?
Read those two paragraphs. It could still be in the wiring harness somewhere.
post #11 of 17 (permalink) Old 05-08-2006, 02:52 PM Thread Starter
All the lights work properly on gauge.
The bike is still under warantee, but I don't want to take it to the local dealership if it's an easy fix in under an hour.
-Craig
post #12 of 17 (permalink) Old 05-08-2006, 03:24 PM
Images: 24
If it's the fuel sensor take it in. You'll have to pull the tank and the entire fuel pump assembly out in order to replace it. Atleast you have narrowed it down for them so maybe they'll only keep it for a month or two.
post #13 of 17 (permalink) Old 05-08-2006, 06:59 PM
Images: 25
i had the same problem with mine , except i had it in the shop from an accident with another bike and they had to replace a lot of shat, and there was some thing wrong with the connection , everything thing on the display worked , minus the high beam indicator.. Never taken it back to that shop after seeing how they fixxed my bike!!!!! it only took 4 times back to get it all squared away!!!!!
aarons600rr is offline
post #14 of 17 (permalink) Old 05-08-2006, 09:59 PM Thread Starter
Squared away? you in the military or something :)
post #15 of 17 (permalink) Old 05-08-2006, 10:06 PM
I had a sending unit just up and **** on me on my 04, it wouldnt read correctly, so I took it to the stealer. They tested it and found it went bad, warranted it and bent the new one when they installed it :) I cracked it open and fixed the new one myself, they just bent the float bracket.
Kevlar is offline
post #16 of 17 (permalink) Old 05-09-2006, 08:45 AM
Images: 24
F'n slackers! Good for you!
post #17 of 17 (permalink) Old 05-09-2006, 04:59 PM
Images: 25
no i am not in the military, this happened last year, when my buddy on his R1 ran into my bike after doing a wheelie right at me, not the smartest kid!!!!!! lol , but it is all better now after $2,800.00
