oil leak - 600RR.net
post #1 of 8 (permalink) Old 05-07-2006, 11:52 PM Thread Starter
oil leak
bike fell on right side, now leaks oil through the cover, does anyone know where i can get a gasket for this, i tried ebay but nothing, dont want to go through honda...
jbell is offline
post #2 of 8 (permalink) Old 05-08-2006, 12:52 AM
Spectre's Avatar
Images: 89
ronayers.com
FIG JAM
Ride with your balls on your feet.
Important Satety Information: http://www.obairlann.net/~reaper/motorcycle/corona.html
Spectre is offline
post #3 of 8 (permalink) Old 05-08-2006, 01:41 AM
It's a liquid gasket so you just need something like Honda Bond. My bike was leaking a little oil too through the right engine cover so I had my local shop take the cover off, got it powdercoated and then they reinstalled it using Honda Bond. No more leak!
DhoomRR is offline
post #4 of 8 (permalink) Old 05-08-2006, 11:22 AM
Bingo....
All the covers used liquid gaskets so you will have to go buy some or go tatke it to the dealer. If you do it yourself, make sure to follow the directions for the liquid gasket.
beung is offline
post #5 of 8 (permalink) Old 05-08-2006, 11:40 AM
NewRedRider's Avatar
Images: 24
Also make sure the cover isn't cracked anywhere before you reinstall it.
NewRedRider is offline
post #6 of 8 (permalink) Old 05-08-2006, 12:37 PM
Yah, if it fell over theres not any reason for it to leak unless you damaged the cover. The fall shouldn't effect how the cover is sealed, the cover and the case shouldn't have come apart nor should the cover have moved unless the cover is damaged.
beung is offline
post #7 of 8 (permalink) Old 05-11-2006, 11:27 PM Thread Starter
thank you all, i rev'd the bike and was able to see the leak come out of the damaged crack, now to call honda for liquid gasket
jbell is offline
post #8 of 8 (permalink) Old 05-12-2006, 09:47 AM
Images: 24
And a new case right? You're not planning on trying to seal the crack with liquid gasket are you?
