Hotbodies LED Wiring Problem.. - 600RR.net
post #1 of 7 (permalink) Old 05-08-2006, 11:57 PM Thread Starter
bwest3's Avatar
Angry Hotbodies LED Wiring Problem..
I have my lights wired up so they are running lights....
My signal lights stay on in the gauge pod the whole time..
What do I have wrong?
Also is there a way to wire them up so they can be used as blinkers?
bwest3 is offline
post #2 of 7 (permalink) Old 05-08-2006, 11:58 PM Thread Starter
bwest3's Avatar
I have the running lights & signals both wired together to the power of the
signal... and the green to the ground...
bwest3 is offline
post #3 of 7 (permalink) Old 05-11-2006, 09:52 PM
tripage's Avatar
Feedback Score: 91 reviews
If your signals only have 2 wires, they are not meant to be running and signals, just signals..
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #4 of 7 (permalink) Old 05-11-2006, 11:17 PM
hotbodies are not meant to act as running lights..only two wires and more than likely you will need a resistor to flash properly....i did
RickRR is offline
post #5 of 7 (permalink) Old 05-11-2006, 11:31 PM
i had same problem, front hotbodies led wire black to green, red to orange, and spare the third wire, do this for both sides and it will work properly, but will blink faster than normal, resistor will only make blinks slow down.
jbell is offline
post #6 of 7 (permalink) Old 05-12-2006, 08:24 AM
Images: 304
look around on here. I thing teg posted a really good how to. i followed his advice and it worked perfect.
CHEWKNOW is offline
post #7 of 7 (permalink) Old 05-15-2006, 10:33 PM Thread Starter
bwest3's Avatar
Actually I have found some neat lil modules that splices into the wires, that let you have signals and running lights with the hotbodies... so i guess my problem
is fixed
bwest3 is offline
