Help me identify these parts - 600RR.net
post #1 of 11 (permalink) Old 12-21-2014, 11:40 PM Thread Starter
I'm fixing a wrecked 03 CBR 600rr and turning it into a track bike. Can you help me identify these parts what they are used for and if I will need them? Only damage was to the front of the bike, thanks!
ID:	144793   Click image for larger version
ID:	144801   Click image for larger version
ID:	144809   Click image for larger version
Camreno is offline
post #2 of 11 (permalink) Old 12-21-2014, 11:49 PM Thread Starter
Oh and I guess it would be helpful to know there they actually mount up to. Thanks in advance!
Camreno is offline
post #3 of 11 (permalink) Old 12-22-2014, 12:02 AM
YG27's Avatar
First off. If you're going to do this then you might as well do the research yourself because this is no small task. Get a manual, and do research online for a parts breakdown.
On to the pictures.
the 1st picture, those are your relays. they mount to the ram air tube on the left side. Everything in that image will mount or rest on or near that tube.
2nd image I can't really tell, but looks like it belongs to the headlights. Get a wiring diagram and trace the colors to its source.
3rd image another relay. again without better images can't tell you where it mounts, looks like the bracket may be broken?
4th that mounts into your upper fairing right below the third eye.
2A7X3. Aircraft Structural Maintenance.
Any corrosion (Paint, priming, identification, etc) or Fabrication (Sheetmetal, Fiberglass, Tubing, etc)
questions, go ahead and ask and I'll do the best to respond to the best of my knowledge.
Current : '08 CBR1000RR 20160213
Wrecked: '05 CBR600RR 20151221 RIP
Crashes: 2 minor low speed lowsides, 1 50MPH impact.
Injuries: 0 Broken bones, possible tear in shoulder.
YG27 is offline
post #4 of 11 (permalink) Old 12-22-2014, 06:10 AM
Lifetime Premium
wrathsrr's Avatar
2.... blinker plug in.
3... headlight relay mounts in between headlights.
4.... bas tipover sensor. This mounts in between headlights also. This is very important to mount correctly as bike will not start if wrong. Turn that over and you'll see it says "up" with an arrow.
If you search hid how to threads you'll get some pics of where these last two are mounted.
hey pound town is going to take over as a saying
Keeper of the Bucket-2W1R
My build thread...
[/I]https://www.600rr.net/vb/showthread.php?p=6111490#post6111490
wrathsrr is offline
post #5 of 11 (permalink) Old 12-22-2014, 01:53 PM Thread Starter
I have a decent amount of knowledge when it comes to rebuilding old bikes. This will be my first newer generation model so all the electronics will be a little different. Thank you for your help!
Camreno is offline
post #6 of 11 (permalink) Old 12-22-2014, 10:46 PM Thread Starter
Better pictures for you fine gentlemen. These are?
ID:	144874   Click image for larger version
Camreno is offline
post #7 of 11 (permalink) Old 12-23-2014, 05:42 PM
Mbiker's Avatar
First one of the above post headlight or indicator relay.
Second one, headlight lamp connector and i believe right side indicator connector.
For non stock bas mounting option check p2 of my build
On p3 there is a pic of the relay block mounted next to the ram air tube on the left side
Live to ride!
Build of my 05 600RR; https://www.600rr.net/vb/showthread.php?t=414385
Mbiker is offline
post #8 of 11 (permalink) Old 12-23-2014, 07:14 PM
mikesx4911's Avatar
Do you guys happen to have a picture of how that relay mounts between the two headlights? Mine kind of just sits in there.... and I would like to fix this.
mikesx4911 is offline
post #9 of 11 (permalink) Old 12-24-2014, 03:15 AM
Soponcio Virtual's Avatar
Why don't you get a Haynes manual??
It's pretty hard to imagine where does each part has to be fixed and how it's fixed... even more if you didn't dismantly it byyourself...
Its not an expensive thing and it has lots of pictures!!
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #10 of 11 (permalink) Old 12-24-2014, 09:03 PM Thread Starter
If I have any problems putting everything together I will thanks!
Camreno is offline
post #11 of 11 (permalink) Old 12-24-2014, 10:28 PM
YG27's Avatar
It's worth buying even if you don't have problems. Because there is a lot of great information in there. Between common issues that can show up that tells you how to troubleshoot the issue. There is information on literally every little thing on the bike, including torque specs and proper ways to install, uninstall everything.
I bought a clymer manual off of Amazon. Worth every single penny.
YG27 is offline
