Electrical problems? - 600RR.net
post #1 of 12 (permalink) Old 05-10-2006, 04:14 PM Thread Starter
I posted awhile back about my dead battery but had to go overseas because I'm in the AF...here's the back story (short version):
Bike was dead so I jumped it with my car and my (expert neighbor) crossed the the + -...batter was sizzling. I replaced the batter and fuses but when I turn the key on NOTHING lights up. I do not know much about the electrical system and I do not trust my neighbor at all to ask. Is it the ground wire that is causing this or more? Please help me out, it's riding season and I have the itch.
Thanks for your suggestions guys!
pavelowcc78 is offline
post #2 of 12 (permalink) Old 05-10-2006, 05:56 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
i hope you did not fry the rectifier/ voltage regulator
try and charge the battery and see what happens
Moeman is offline
post #3 of 12 (permalink) Old 05-10-2006, 07:22 PM Thread Starter
I have charged the new battery and still nothing...do you think that it's the rectifier? I really do not know what I should check or the order I should troubleshoot this problem.
Any pointers would be appreciated!
Thanks
post #4 of 12 (permalink) Old 05-10-2006, 07:46 PM
APEX_600RR's Avatar
Its the main system fuse. It is located on the positive battery cable just off the terminal on the battery. I believe on the 600RR its in a little black box with "FUSE" printed on it next to the battery itself under the main seat. This fuse is designed to pop and protect the rest of the electrical system from frying when this exact situation occurs.
APEX_600RR is offline
post #5 of 12 (permalink) Old 05-13-2006, 12:24 AM Thread Starter
I have replaced that fuse and the other one under the seat...still will not start. Any idea what I should do next??
Thanks for any advise!
post #6 of 12 (permalink) Old 05-13-2006, 12:30 AM
get a volt meter and start testing
super600rr is offline
post #7 of 12 (permalink) Old 05-13-2006, 06:13 AM
envirocbr's Avatar
WOw, your gonna need to start a testing. Mkae sure your did not fry anything.
Because the Headlights, Fuel Pump and I belive Ignition are on the same circuit you should check that one first
Squids
Use
Zero brains
Under
Krappy
Intelligence
envirocbr is offline
post #8 of 12 (permalink) Old 05-13-2006, 07:21 AM
OveRReV's Avatar
Images: 16
oh my god i think you just fried your ECU dude, did you check the fuse box under the left midfairing cowl? never jumpstart your battery from another vehicle, remove the battery & recharge it.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #9 of 12 (permalink) Old 05-13-2006, 07:28 AM
envirocbr's Avatar
Also...Start Cheap put ALL NEW fuses in, then see what happens
Squids
Use
Zero brains
Under
Krappy
Intelligence
post #10 of 12 (permalink) Old 05-13-2006, 10:27 AM
NewRedRider's Avatar
Images: 24
Questions:
How did you charge the battery and for how long? Needs to be 5-8hrs ona 1amp charger. No "Quick Chargers"!
What voltage is the battery showing after you charge it? anything below 12.4v and the bike won't crank. You need 13.0-13.5v or higher on a good battery.
Have you had the battery load tested? If not, take the battery to a local AutoZone or Advanced Auto Parts and have them load test it.
NewRedRider is offline
post #11 of 12 (permalink) Old 05-13-2006, 01:35 PM
C.A.H.N founder / President
CBR/LS1's Avatar
Images: 10
Was the car running when you tried to jump it? For future reference I don't think the car should be running when jumping a MC. Someone correct me if I'm wrong. This probably wasn't what messed your up since the cables got crossed but it can help in the future.
CBR/LS1 is offline
post #12 of 12 (permalink) Old 05-13-2006, 04:42 PM
APEX_600RR's Avatar
No you are correct on that man.
Since it's not the fuse then im thinkin along the same lines as OveRRev, you may have just fryed the ECU or possibly the entire electrical system. Get yourself a multimeter and start testing EVERYTHING. Let us know how it goes...
You may post new threads
You may post replies
