weird grease and shifting problem - 600RR.net
post #1 of 6 (permalink) Old 01-07-2015, 06:39 PM Thread Starter
Hey guys i was under my bike today and noticed some random green grease right below my shifter and trans is this normal? also i have not been having smooth up shifts i ignored it for awhile now but it doesn't feel right, hard to explain but its not as smooth as when you down shift it feels like it catches or doesn't go into gear right away 1 N and 2 feel fine just going past that.
Goose899 is offline
post #2 of 6 (permalink) Old 01-07-2015, 06:47 PM
6hunnit's Avatar
couple drops of coolant mixed with grease and road grime maybe?
Nothing of value comes easy, and nothing that's easy is of value.
-6hunnit
Riding Prayer - Thank you God for the privilege of riding, please watch over
us riders and bring us home to our families every day. Give me strength to obey the laws, and stay vigilant and focused.
6hunnit is offline
post #3 of 6 (permalink) Old 01-07-2015, 07:49 PM
BOTM Winner 07/16
rinonz's Avatar
What colour is your chain lube? Is it similar to the colour of the grease that you're seeing?
Re: Shifting, how old is your engine oil? and are all the shift linkages lubed?
rinonz is offline
post #4 of 6 (permalink) Old 01-08-2015, 08:53 AM
G Money's Avatar
Can you take a picture from further back, so we can see more than just the bolt and greasy area?
I'm thinking that is coolant, and its coming from the coolant drain bolt or the water pump itself.
'03 600 RR - ~33,000 miles (14,000 from me)
Yoshimura RS-5 Slip on - Arrow Stainless Headers - BMC Street Filter - PCV - EK 520 Chain on Driven Sprockets - CoreMoto Stainless Lines (F+R) - Dan Kyle PAIR Delete - The2Wheels Shorty Levers - Vortex V3 Rearsets - Woodcraft Frame Sliders & Bar Ends - Woodcraft Stator and Clutch Covers - Cox Radiator Guard - Renthal Dual Compound Grips - 1000RR Kill Switch and Throttle Housing - TST IT and FE - Proton Flushmounts
G Money is offline
post #5 of 6 (permalink) Old 01-08-2015, 03:56 PM Thread Starter
looking at this post https://www.600rr.net/vb/showthread.php?t=89348 it may be my drain bolt was loose at one point im going to go over the bolts and tighten them up wipe it and go from there, engine oil is a month old full synthetic. Also by lubing the shift linkages do you mean clutch cable and such?
Goose899 is offline
post #6 of 6 (permalink) Old 01-08-2015, 08:45 PM
BOTM Winner 07/16
rinonz's Avatar
lube the knuckle joints of the shift linkage and any moving parts on the rearset that has anything to do with the shift linkage.
Are you running OEM rearset or aftermarket?
Often Aftermarket doesn't have a closed bearing and need regular lubing on the moving parts otherwise that may not move as freely as it should be.
rinonz is offline
