stuck engine bolt - 600RR.net
post #1 of 4 (permalink) Old 01-28-2015, 04:50 PM Thread Starter
Alvaro's Avatar
stuck engine bolt
So I'm trying to remove the right side engine bolt to install my frame sliders but having a really hard time taking it out. Any tips on removing it?
Alvaro is offline
post #2 of 4 (permalink) Old 01-28-2015, 05:04 PM
FightingChance's Avatar
Feedback Score: 10 reviews
I believe they are set at around 40 lb-ft, which isn't a lot, however time and heat can cause some amount of seizing. Are you using something with a decent amount of leverage, like a 1/2" drive ratchet? If you're using a 3/8" it may be too short to get enough force through.
Maybe also try right after a 20 minute ride; the heat from the engine and frame may help the bolt let go.
FightingChance is offline
The Following User Says Thank You to FightingChance For This Useful Post:
Alvaro (01-29-2015)
post #3 of 4 (permalink) Old 01-29-2015, 12:31 AM Thread Starter
Alvaro's Avatar
Went for a quick drive and saw something online about heating it up with a blow torch I was hesitant at first but it worked well and with the help of a buddy I got it off!! Definitely more of a paint in the rear than it should have.
2006 Cbr600rr
Alvaro is offline
post #4 of 4 (permalink) Old 01-29-2015, 02:57 PM
mran556's Avatar
Also depend on the other 2 bolts. Supporting the engine can help. Like a car jack and some wood or cardboard under the headers or sump.
2007 Cbr600rr Black
mran556 is offline
