how do i fix my air intake - 600RR.net
post #1 of 10 (permalink) Old 05-18-2006, 11:18 AM Thread Starter
crap man... i removed the right fairing last night and i also pulled out the air intake boot, the one that goes into the bike, i dont think i put it back in right now my bike doesnt run as well, any tricks to making sure its in there in the right location as snug as it was before.
senoroms is offline
post #2 of 10 (permalink) Old 05-18-2006, 11:40 AM
chkaotic's Avatar
Images: 30
Um.. if its the rounded-rectangle part you're talking about that fits through the hole in the frame, it just pushes back in.. lift up on the front, stick it in, and then push the front back down.. worked for me
^chka0tic :: WERA N#721 :: 2003 Honda CBR600RR
- OverTwo Customs / http://www.overtwocustoms.com/
- Vortex Racing / www.vortexracing.com
- RK Chain / www.rkexcelamerica.com
- Lockhart Phillips / www.teamprivateer.com
- www.sponsorhouse.com/members/chkaotic
chkaotic is offline
post #3 of 10 (permalink) Old 05-18-2006, 04:25 PM
NewRedRider's Avatar
Images: 24
Yeah, you should try to take it out by removing the right mid fairing only. You need to remove the front clip and then pull the air ducts. Not sure if you can get it back in the same way it came out.
NewRedRider is offline
post #4 of 10 (permalink) Old 05-18-2006, 05:10 PM Thread Starter
Thanks New Red... You Have Been Answering Alot Of My Questions. I Apreciate Thatbike Feels Like It Lost Some Umph, At 8000 Rpms It Would Pick Up And Start To Go, Just Doesnt Feel Like That Now.. Is It Maybe Becuase I Dont Have The Intake In Correctly? Sucking Air From Somewhere Else??
Another Thing, That Little Triangle Piece That Is Attached To The Air Duct, The Last Piece Tucked Into The Fairing, Well My Isnt Even On Tight, It Only Stays On Because The Fairing Keeps It From Falling Off, But If I Remove The Fairing, Gravity Makes It Fall, Is That Normal?
senoroms is offline
post #5 of 10 (permalink) Old 05-18-2006, 06:08 PM
Images: 24
Yes fix the intake first. Try what chkaotic is telling you by loosening the front and lifting it up a little. The traingle piece is the resonator. It's held in by 2 plastic trim clips that are obviously missing. I doubt it's causing any performance issues. You have 5 trim clips on the lower fairings. 3 up front and 2 in the back. Pull 1 and put it in the resonator until you can get another one. Put a small zip-tie on the lower where you robbed the trim clip from.
Why did you pull the fairing in the first place?
post #6 of 10 (permalink) Old 05-18-2006, 06:12 PM
DethMetal Jeff's Avatar
I had mine out last time I flushed my coolant...it was a huge pain in the arse to get back in properly but eventually it did go back.
"This here's my demon face"
Dissatisfaction is the basis of progress. When we become satisfied we become obsolete.
DethMetal Jeff is offline
post #7 of 10 (permalink) Old 05-18-2006, 06:25 PM
Images: 24
It's real easy with the front off.
post #8 of 10 (permalink) Old 06-01-2006, 06:41 PM
prettyboymfm426's Avatar
how bad is it to run with out the tubes
prettyboymfm426 is offline
post #9 of 10 (permalink) Old 06-01-2006, 07:27 PM
APEX_600RR's Avatar
<-- Currently running tubeless. Your bike will will run like a champ if you buy mine but if not, youre fukced.
APEX_600RR is offline
post #10 of 10 (permalink) Old 06-01-2006, 09:22 PM
Images: 24
Without a before and after dyno who knows. But if it was better without the ram air tubes Honda would have never installed them in the first place.
