I need help...badly, starter going mad!!! - 600RR.net
post #1 of 28 (permalink) Old 09-05-2017, 12:40 PM Thread Starter
JohnleCBR's Avatar
Hello!
I got a 2003 CBR 600 RR, that I really enjoy. But recently I am hearing this noise by the engine. It goes away when I clutch in so thought that it was related to the clutch.
But I have always thought it was wierd when I put the bike in neutral, it starts up by itself (also when in first when clutch is pressed in). I dont need to push the start button, which is wierd. But I am hearing a noise by the engine side, and inspected it today. I stopped the bike, and flipped the engine stop button over, and started it, and noise disappeared. And also, my headlights doesnt work, only the middle light and the high beam flash button (dont know what its called), and read that the headlight wiring is by the start button, and opened that up, but it was ok.
But today I think I figured it out. When you push the start button, the headlights doesnt stay on because it saves power. So in that way, the starter motor must stay on all the time to me, as I have no headlights, and the bike starts itself, and the noise, and when I stop it I hear the starter continue for a second.
So my question is, do some of you know how to start looking for this problem? Could it be a starter relay thats gone mad or..?
I really appreciate all the help I can get, its not so big community in Norway, so I will be thankfull of every reply I get :)
And sorry for the english being borat like ;)
JohnleCBR is offline
post #2 of 28 (permalink) Old 09-05-2017, 02:17 PM
Lyoha's Avatar
So to summarize, ignoring the noise for now:
-Engine cranks independently while in neutral
-Engine cranks independently in first with the clutch lever pulled
-Both high and low beams are out unless you flip the flash
-Starter stays engaged after you lift off the start button
So from your description the starter itself is for some reason engaged without command. I don't have the 03 wiring diagram in front of me but I'm going to base it on the 05 that I have. US spec models also don't come with high beam flash levers so I can't speak to that part of the circuit either. I'm also going to assume that the bike's not electrically modded.
You're right in that the headlights are wired to turn off when you hit the start switch. From that alone I'd say your starter switch is bad. I suspect that if any other component was causing the starter to engage your headlights would stay on.
For the noise then. Can you post a video?
Lyoha is offline
The Following User Says Thank You to Lyoha For This Useful Post:
JohnleCBR (09-05-2017)
post #3 of 28 (permalink) Old 09-05-2017, 02:19 PM
The noise is the starter motor running
Your start button is stuck.
It has to be the button because the lights are out. If it was the relay the lights would be on
wibbly is offline
post #4 of 28 (permalink) Old 09-05-2017, 02:39 PM
Honda-Power's Avatar
Damn man I have never heard of the starter button going bad like that.
I would try removing the two screws that hold the two halves of the right-hand side switch gear together. Then, inspect, possibly clean it out. If no luck, replace it.
By the way I have had my starter button get physically stuck in the on position before. I fixed it by just cleaning out the assembly like described above.
Honda-Power is offline
The Following User Says Thank You to Honda-Power For This Useful Post:
post #5 of 28 (permalink) Old 09-05-2017, 02:52 PM
NewRedRider's Avatar
Images: 24
It's sounds like someone has screwed with the wiring and made some custom alterations. I'll post a wiring diagram when I get home. The 05' wiring is different.
Sent from my XT1097 using Tapatalk
NewRedRider is offline
The Following User Says Thank You to NewRedRider For This Useful Post:
post #6 of 28 (permalink) Old 09-05-2017, 04:25 PM Thread Starter
JohnleCBR's Avatar
Thanks for the quick replies, really helpful. It seems like all of you thinks that it is the starter switch that is faulty, which makes sense. And really good about the relay, as Wibbly said that the lights would be on, which they arent. I will try to look at the switch itself, and if I dont find any solutions, then I could buy another switch. But as for driving, its probably better to drive my car for now, as the starter motor cant enjoy that it is on all the time? Really nice if you could get the diagram NewRedRider, that would help alot!
post #7 of 28 (permalink) Old 09-05-2017, 04:28 PM
Images: 24
I definitely would not ride that bike until you get this figured out. The last thing you need is for it to cut off on you in the middle of an intersection.
post #8 of 28 (permalink) Old 09-05-2017, 04:34 PM Thread Starter
JohnleCBR's Avatar
Thats true, will let it rest for now, but do you think it has done any damage for the starter itself, or is that impossible to say?
post #9 of 28 (permalink) Old 09-05-2017, 09:18 PM
The starter will be fine. It's just spinning there. Not doing any work.
wibbly is offline
post #10 of 28 (permalink) Old 09-06-2017, 08:28 AM
Images: 24
Get the bike wiring straightened out and then see what the starter does. You'll know if you need a new starter or flywheel the next few times you crack it. It'll make a God awful rattling noise.
I can still post some troubleshooting help for you. But at this point I'd highly suggest you find a service manual. If the PO screwed around with the engine stop switch, the clutch switch, and the ignition, who knows what else you're going to find. You're going to need the troubleshooting section as well as the wiring diagram for all that and maybe more. That's just too much to try and post. You'll be better off in the long run with your own copy in your hand.
post #11 of 28 (permalink) Old 09-06-2017, 10:57 AM
Based on what was written by the OP there has been no screwing around with the clutch switch or any other safeties. Those all behave as they should as described in this thread
Secondly, the flywheel has nothing to do with the starter. This isn't a car
Thirdly, you should probably hold off on that troubleshooting advice. You have completely incorrectly assessed this issue.
wibbly is offline
post #12 of 28 (permalink) Old 09-06-2017, 11:18 AM Thread Starter
JohnleCBR's Avatar
Thats good news that the starter would be fine, thanks for that :) Will check the starter button now, and order one if I dont find the fault. Thanks for great help, really does a lot.
post #13 of 28 (permalink) Old 09-06-2017, 11:47 AM
The starter probably wouldn't be running all that much. In gear with the clutch out it would be disabled.
So it would only really run either in neutral or in gear with the clutch in.
The starter is in constant mesh with the crank on the right side of the engine. There is a sprague clutch (one way clutch, think like the free hub on your bicycle), on the end of the crank. If the engine is going faster than the starter motor will turn it. Nothing happens the motor will just spin with no load. If the engine slows down the starter will turn it.
It's very unlikely anything has been damaged by this as there is nothing to grind or wear prematurely (aside from the brushes in the starter)
Just get that switch fixed and you should be golden
wibbly is offline
JohnleCBR (09-06-2017)
post #14 of 28 (permalink) Old 09-06-2017, 12:19 PM Thread Starter
JohnleCBR's Avatar
Ok, the way you write it makes me understand it much easier, thanks a lot :)
I hope and think that as well
post #15 of 28 (permalink) Old 09-07-2017, 07:38 AM Thread Starter
JohnleCBR's Avatar
I am such a fool, a happy one :) I opened up the starter button, and looked inside, but it seemed really clean. But when I pushed the button, I noticed that it didnt go all the way back. And when I manualy pushed it back, I saw the lights turn on :)))) I am so happy about it, it looked like it just got stuck like Honda-Power had the same problem. I saw by the mechanismen that it was a wire (something like a wire), that helds the starter button, and that doesnt release it all the way back, so can I spray some WD 40 or something down there? I am scared to mess it up, like the other stuff in the button ,wires and such. I can also just push the button back manualy each time I start the bike, which wont be a problem eather.
post #16 of 28 (permalink) Old 09-07-2017, 08:30 AM
Lyoha's Avatar
Start out by hitting it with some electric contact cleaner and lube with dielectric grease. Though the latter isn't entirely necessary and just makes a mess next time you go to work near it
Sent from my SAMSUNG-SM-G935A using Tapatalk
Lyoha is offline
The Following 2 Users Say Thank You to Lyoha For This Useful Post:
JohnleCBR (09-07-2017), NewRedRider (09-07-2017)
post #17 of 28 (permalink) Old 09-07-2017, 08:49 AM Thread Starter
JohnleCBR's Avatar
Ok, then I will go and buy that later, thanks for all the help I got from all off you :)
post #18 of 28 (permalink) Old 09-07-2017, 09:21 AM
Images: 24
Bombardier lube is what I use for my cables and exterior switches. It doesn't wash away as easily as other lubes because it's thicker.
post #19 of 28 (permalink) Old 09-07-2017, 09:23 AM Thread Starter
JohnleCBR's Avatar
Ok, thats good to know, I will look after that :)
post #20 of 28 (permalink) Old 09-07-2017, 09:40 AM
Images: 24
You may have to look for XPS lube made by Seadoo. It looks like they may have changed the name.
https://www.amazon.com/gp/aw/d/B001K...mbardier+lube#
post #21 of 28 (permalink) Old 09-07-2017, 10:13 AM
Dont put anything wet in the switch. It'll collect dust and end up messing up again
wibbly is offline
post #22 of 28 (permalink) Old 09-07-2017, 10:27 AM Thread Starter
JohnleCBR's Avatar
Ok, thanks!
post #23 of 28 (permalink) Old 09-08-2017, 12:49 AM
You want something like this:
When I cleaned mine I think I used silicone spray or something. Probably not the best tool for the job but it worked. Let us know how it goes!
post #24 of 28 (permalink) Old 09-08-2017, 11:08 AM Thread Starter
JohnleCBR's Avatar
My dad had some grease that was made for stuff like that, looked like the XPS lube that NewRedRider mentioned, and when I placed some really small amount by the mechanismen and pressed it a couple of times it went back to where it should go after I pressed the start button, so all good now :)
post #25 of 28 (permalink) Old 09-08-2017, 11:27 AM
Images: 24
Just make sure you keep up a periodic cleaning/lubing schedule since it's already gotten stuck once.
For cables and switches that are exposed to the weather I like the XPS/Bombardier lube because it's harder for water and rain to wash it off.
If it's internal dry contacts then I use the contract cleaner that Honda power posted and silicone grease or spray.
post #26 of 28 (permalink) Old 09-08-2017, 11:36 AM Thread Starter
JohnleCBR's Avatar
That sounds like a safe and good plan to check somethimes, good tips!:)
post #27 of 28 (permalink) Old 09-13-2017, 10:18 PM
AF4iK's Avatar
I did not know this. My starter is struggling lately and I suspected the relay but now I will check to see how the headlights behave. Thanks!
AF4iK is offline
post #28 of 28 (permalink) Old 09-13-2017, 11:09 PM
if your starter is struggling i would expect it's brush wear. the comment you quoted is in reference to the starter motor running while the bike is also running. if you press the start button with the bike idling in neutral you can actually hear the starter spin.
if you have verified the health of the battery, i'd pull the end cap off the starter and see if there's a lot of brush material in the end housing. it can cause a ground fault and reduce starting torque.
wibbly is offline
