Battery related issue - 600RR.net
post #1 of 7 (permalink) Old 09-25-2017, 10:06 AM Thread Starter
Hi All,
I have 06 600rr. I took it out on Saturday for a 30min ride, everything seemed normal. After spending 2hrs at destination i rode it back for 20min, made a quick 3-4 min stop(engine off). and when I went back to my bike to start it, it started choking. I tried it a few times and choking turned into rapid clicking, displays going out and coming back in while attempting to crank it. It just wouldnt start.
I had no idea what the problem was. Because all lights were on, power on was looking normal. Anyway did a quick google search and decided to jump it with a car. Voila! I was able to start it np. Rode it home for another 10min turned it off and started it just fine again.
Next day, (Yesterday) cold started it just fine after about 20hrs passed by, took it to advance auto and battery tested fine.
Not sure if its an alternator issue or the battery going bad.. Is there a way I can identify and fix the issue before it happens again?
gtrr is offline
post #2 of 7 (permalink) Old 09-25-2017, 05:28 PM
Honda-Power's Avatar
Did you leave your lights on for those 3-4 minuntes?
It could be your stator or regulator/rectifier. I'm sure there are troubleshooting directions in the service manual or elsewhere online. PM me if you have trouble finding them
Honda-Power is offline
The Following User Says Thank You to Honda-Power For This Useful Post:
dixon cider (06-05-2018)
post #3 of 7 (permalink) Old 09-26-2017, 10:16 AM Thread Starter
Lights weren't on.
I took the bike out yesterday. Multiple stops, no issues at all. I ordered a multimeter and will test it myself as well.
gtrr is offline
post #4 of 7 (permalink) Old 09-26-2017, 01:53 PM
NewRedRider's Avatar
Images: 24
You probably have too low of voltage on the battery and it needs to be charged. Order a 1 amp trickle charger if you don't have one.
Sent from my XT1097 using Tapatalk
NewRedRider is offline
The Following User Says Thank You to NewRedRider For This Useful Post:
post #5 of 7 (permalink) Old 09-26-2017, 03:02 PM
Not speaking as an expert here, but I believe if you have dead cells in the battery, in can still appear to be fully charged when metered, but it drains very fast. Vice versa as well, it will charge really fast. How do I know? That's what my battery was doing. I replaced it with a Lithium Iron battery.
Axel Nut is offline
The Following User Says Thank You to Axel Nut For This Useful Post:
post #6 of 7 (permalink) Old 05-22-2018, 09:21 AM
indfireblade's Avatar
Battery CCA should be 190
indfireblade is offline
The Following User Says Thank You to indfireblade For This Useful Post:
post #7 of 7 (permalink) Old 06-05-2018, 12:28 PM
ccs907's Avatar
There's only a few things that would cause the relays to flicker open and closed like that. mostly loose or corroded connectors. Easiest thing to check is the positive & negative cables at the battery.Then check the PGM-FI connector (white connector) for looseness. Next, and maybe the most problematic, is the grounding block on the left side of the subframe. this is really hard to diagnose due to its wrapping. maybe just gain access to this or keep it in mind if you can't find anything else wrong. Check the large black wiring harness connector on the right side of the bike (located under the right side air ram cover) for any loose or corroded connections. this is not a waterproof connector and corrosion is easily introduced due to the placement of the harness. If all seems tight and clean, remove the left side mid fairing and check the relay connector. There are a few grounding wires there as well. clean and tight.
If everything looks good, start the engine and jiggle each of the connectors i mentioned to try and induce the problem. once the motor starts acting up, you've found your problem.
ccs907
ccs907 is offline
The Following 2 Users Say Thank You to ccs907 For This Useful Post:
dixon cider (06-05-2018), tary preisser (06-05-2018)
