rough idle and low rpm "missing"? - 600RR.net
post #1 of 10 (permalink) Old 01-20-2018, 12:56 PM Thread Starter
Unhappy rough idle and low rpm "missing"?
Hey guys, my first post on here, im having an issue with my 04' 600rr,
shes got about 52.5k on her,
I've just replaced the plugs and done the valve adjustment. was really tight on exhaust side .20
had a bazzaz with apropo map for a K&N filter and jardine rt-1 slip on.
took those off and still does the thing(described below)
replaced map sensor and air pressure sensor(no effect)
Tried 2-3 tanks of injector cleaner(no effect)
checked charging system(perfect 14.0)
temp of all headers at temp fall around 500-520f
only use 91 gas and have gone through 10+ tanks of gas.
Heres what she does:
Cranks up fine, and idles pretty normal up to about 170F-190F
Once at temp, idle starts missing like shes not getting enough something. ex:
purrrrrpu purrrrrrrrrrpu pu purrrrrrrrrrrrrrrrrrrrpu purrrrrrrrrr pu pu pu purrrrrrrr
seems to get worse as it gets to 210ishF in traffic or street conditions.
never drops enough to stall and when revving up past 4-5k rpm it runs strong and pulls hard like usual.
but does sputter all the way to that 4ishK range.
im baffeled and ive talked to 2 shops. no clue, i have no choice but to turn to the all-knowing interwebs
ordered a fuel pump as that is the next on my list (fuel filter)
Joshua S Dean is offline
post #2 of 10 (permalink) Old 01-20-2018, 06:14 PM
Any F1 Codes on dash ??
I would advice NOT to buy stuff before you're sure its the fuel pump or get some advice from the senior guys on the forum ..
JXHennessy is offline
post #3 of 10 (permalink) Old 01-28-2018, 11:47 PM Thread Starter
no FI light
Anyone got any advice?
post #4 of 10 (permalink) Old 01-29-2018, 08:12 AM
Miweber929's Avatar
Did the problems already exist or did they start after something like your valve adjustment?
How long has it been doing this?
- '17 Ducati Supersport S
- '13 Kymco Super 8 150
- '11 Triumph Sprint GT
- '10 Yamaha WR250R
- Past rides: too many to list
Miweber929 is offline
post #5 of 10 (permalink) Old 01-29-2018, 04:08 PM
skeemin's Avatar
pretty sure the amount of extra work you put in did more harm then good. When did problems arise?
skeemin is offline
post #6 of 10 (permalink) Old 01-29-2018, 05:48 PM
498cm3's Avatar
Did the wax unit check out?
Sent from my XT1031 using Tapatalk
498cm3 is offline
post #7 of 10 (permalink) Old 02-03-2018, 04:32 PM Thread Starter
These problems came up as I started to need a valve adjustment. got the adjustment and it still had the issue, I've done the swap on the injectors and it helped a lot, but still, kind've does it.
wax unit?
sorry for late reply, i work 9-5 during the week
post #8 of 10 (permalink) Old 02-07-2018, 06:45 AM
NinjaBlade's Avatar
wax unit?
hey, have you checked coils/coil packs? I had a cbr 900 and back in the day cold fine but when up to temp also went funky, one of the plugs were bad, swapped it out sorted. my friend had the same problem but it was his coils ,this was also only when she was heated up to operating temp.
If it has wings, it will Fly
NinjaBlade is offline
post #9 of 10 (permalink) Old 02-07-2018, 07:34 AM
Miweber929's Avatar
If all of your valves were tight, I’d say your valve adjustment isn’t correct (it’s easy to mess up) because you might find one if two needing adjustment, not all of them, unless there is a larger problem. If the fuel pump were the issue, it wouldn’t be temperature dependent, though if your tank vent were plugged you could starve for fuel as the tank heats up.
I’ll echo the above poster that you may have a bad coil pack so pull and inspect for cracks. A video would help tremendously here.
- '10 Yamaha WR250R
The Following 2 Users Say Thank You to Miweber929 For This Useful Post:
NinjaBlade (02-07-2018), tylerboyd (02-07-2018)
post #10 of 10 (permalink) Old 05-11-2018, 01:51 AM Thread Starter
Hey Guys! so it turned out to be my coils! 2nd pack was super loose. Thanks guys! your amazing
