Brake Light not Working with Rear Brakes - 600RR.net
post #1 of 9 (permalink) Old 05-03-2018, 09:05 PM Thread Starter
Hi,
I've got rear seats on my bike which shouldn't affect the operation of the brake light.
However, it does not trigger the brake light once applied.
Not sure what's the issue as the light works with front brakes but not rear.
Any troubleshooting recommendations.
TIA
Moustafa
badbro0 is offline
post #2 of 9 (permalink) Old 05-03-2018, 09:08 PM
is the brake light switch installed? it looks like this
a lot of aftermarket rearsets don't accommodate this switch. if it's not there then the answer is pretty obvious.
wibbly is online now
trevorking1964 (05-04-2018)
post #3 of 9 (permalink) Old 05-04-2018, 01:04 AM Thread Starter
Thanks Wibbly. spot on.
Yes correct there is no brake light switch as I checked.
I can't locate the harness though so I'll take the seat off and check underneath.
Do you happen to have the service manual for 13-17 cbr.
Thanks.
badbro0 is offline
post #4 of 9 (permalink) Old 05-04-2018, 03:40 AM
https://www.motosport.com/vortex-brake-pressure-switch
You can pick this up all over the net, including amazon. Just make sure you get the correct thread pitch for the banjo bolt. Splice the end of the wires into the current sub harness so you can still unplug it if needed.
Smalls599 is offline
post #5 of 9 (permalink) Old 05-04-2018, 09:29 PM
10mm x 1.25 Pitch Hydraulic Brake Light Switch Banjo
You can pick them up on ebay and amazon
utspecter is offline
post #6 of 9 (permalink) Old 05-10-2018, 08:34 AM Thread Starter
Hi guys
I’ve taken a deeper look at the bike.
Unfortunately I couldn’t find the harness that I am supposed to connect to.
So went ahead and taken off the seats and checked all wires.
There is a green wire which I suspect it’s for the rear brake light because after testing it’s the only one that doesnt affect my current brakes or turn signals.
It’s actually damaged or frayed but not sure best way to remedy as I’m not good with electronics but don’t want to leave it like that which can damage my bike.
I also am curious to know what does that red big fuse do.
Any advice much appreciated.
photos attached as well
ID:	199370   Click image for larger version
ID:	199378   Click image for larger version
ID:	199386   Click image for larger version
badbro0 is offline
post #7 of 9 (permalink) Old 05-11-2018, 10:29 PM
Hi Have a look in the motorcycle manual for your model, It's got lots of valuable information Such as the the Main fuse you see there which i believe is a 20amp PGM FI fuse. If this was blown it would effect allot more then just rear lights
Regarding the harness, i'm not experienced enough to say however it should be clear due to the fittings. Really need to look at the Manual as it will give you a clear image of what you need compared to what you have..
A quick search online:
https://www.google.co.uk/search?q=ho...hrome&ie=UTF-8
Also some close up images would really help here, just a thought.
Hope that helps, i'm sure it's nothing to worry about. Might as well get some mini 20 & 10 amp fuses. Their handy especially if your new to electronics and last but not least always disconnect the battery when working with the wiring, just a reminder..
Take it easy
Hondarep is offline
post #8 of 9 (permalink) Old 05-24-2018, 09:39 PM Thread Starter
Thanks mate for the feedback.
badbro0 is offline
post #9 of 9 (permalink) Old 05-25-2018, 09:32 AM
tripage's Avatar
Feedback Score: 91 reviews
The red cap is your data port plug.
Looks like you have aftermarket rearsets on the bike. I would guess that they don't have a spot for oem spring type brake connection or previous owner didn't want a rear brake connection and left it off.
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
