Engine stalling - 600RR.net
post #1 of 5 (permalink) Old 09-22-2018, 06:09 AM Thread Starter
stevecbr80's Avatar
Engine stalling
Hi guys, I'm having an issue with my 06 cbr 600rr and hoping someone here can help out.
So I was on track today(second session) and I was pushing hard(did hit the rev limiter a couple of times) and as I was exiting a tight hairpin I accelerated only to loose power and the bike cut out, I managed to push it to the pit lane where it started again only to stall again after a few minutes. The bike would start and run for a couple of minutes then stall. Checked all the relays and fuses,wiring but couldn't find an issue. With the bike not able to ride I packed up and came home, started the bike up and drove around the estate for a few minutes only for the bike to cut out again. Same as before the bike will run for a few minutes then stall. The fan does come on and cool the engine down so I'm assuming something electrical is over heating maybe the fuel pump or cam sensor? I cant find any thread anywhere with this issue.
stevecbr80 is offline
post #2 of 5 (permalink) Old 09-26-2018, 08:13 AM Thread Starter
stevecbr80's Avatar
Americans only forum aye, problem solved thanks for all the info 🤘
post #3 of 5 (permalink) Old 09-26-2018, 08:21 AM
Wazoo's Avatar
So what was the solution? Don't leave us hanging!
Wazoo is offline
The Following User Says Thank You to Wazoo For This Useful Post:
dixon cider (09-26-2018)
post #4 of 5 (permalink) Old 09-27-2018, 07:38 AM Thread Starter
stevecbr80's Avatar
Tested everything even replaced crank and cam sensors as I couldn't test them while the bike was running being internal sensors but problem persisted, I disconnected the PC 5 and the bike runs mint even idles better so I need the bike back on the dyno to see if it's a faulty PC unit or wrong mapping, bike had done 2 full track days previous with the map so odds are it's a bad unit, really hope not cause I've got a full titanium arrow system and slipper clutch going into it which would really help the lap times. Pity I didnt disconnect it track side and finish the day but aye ya live and learn 😉👍
post #5 of 5 (permalink) Old 09-27-2018, 09:24 AM
Wazoo's Avatar
Glad you found the culprit. Any chance the set-up inputs can shake/vibrate into different settings while your riding, or are the setting completely secure so that can't happen? How about the ground wire for the unit? Good luck!
Wazoo is offline
