Bike will not start after valve adjustment - 600RR.net
post #1 of 4 (permalink) Old 03-29-2019, 06:46 PM Thread Starter
Plusaq's Avatar
Exclamation Bike will not start after valve adjustment
Hi all,
Sorry for posting twice, i had the inital thread going under engine tech, but realized maybe i should be posting to troubleshooting section.
Anyways, to recap. I did a valve adjustment and changed my shims and measure spacing all was good, got the bike back together no problem. The bike would not start.....When it started for two seconds there was a loud clank from the cam chain. So, i tore everything back down to the valves again, aligned everything to top dead center made sure markings In & Ex were at 9 and 3 o'clock and flush. Bottom T mark was positioned accordingly. I took the CCT off and made sure the links between the sprockets were exact. I reinstalled the CCT and cranked it a few times and it spun well with a bit of force needed, but no clank or rattling of the chain anymore.
Reinstalled everything, tried the bike again, but did not start again. I then checked the spark plugs gap and even tested to see if all four fired which they did no problem. While i had the plugs off i did a compression test which yielded between 165 and close to 170 for all four which is a good reading seeing how the bike is cold and may be off from the 178 psi indicated in the manual. So all is good there and i was happy to see my compression tests come out clean that nothing is severely damaged and i think this also clears that my valve job was done correctly.
I then got desperate and switched out the gas in the tank thinking this might have gone bad, but still the bike will not start. All i am able to get from the bike is it started for a brief very short period and was revving very low and did not sounds good, then it would not start at all. When i tried starter fluid sprayed into the intake and it worked better and got the bike turning but died once i stopped spraying.
I am missing something and it is driving me crazy!!!! not sure at this point what the problem could be. I didnt do anything else to the bike except the valves, which the spacing is good and the compression test came out clean. Is gas not getting where its supposed to? i have no idead.
HELP!!!!!
Plusaq is offline
post #2 of 4 (permalink) Old 03-29-2019, 07:57 PM Thread Starter
Plusaq's Avatar
Problem solved.....wow ...spent a day trying to figure this nonsense out....
Thank you all for the emotional support :)
Plusaq is offline
post #3 of 4 (permalink) Old 03-30-2019, 03:50 PM
Glad to hear its sorted.
What was the issue in the end?
Diefenbaker is offline
post #4 of 4 (permalink) Old 03-30-2019, 11:31 PM Thread Starter
Plusaq's Avatar
Well i solved the CCT problem and realigned the chain on the sprockets as it was slipping.
Then i figured out that no gas was getting to injectors and my gas line had been bent under the gas tank. Stupid ....
i just need to figure out how to orient or put the line in so it does not get bent when lower the gas tank down
Plusaq is offline
The Following User Says Thank You to Plusaq For This Useful Post:
Diefenbaker (03-31-2019)
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cam Chain Noise after valve adjustment Plusaq Engine Tech 6 03-29-2019 08:11 PM
Idle valve adjustment - post valve replacement trolley Maintenance 9 03-09-2015 08:08 AM
After Valve Adjustment, Engine Won't Start dreamzboy Troubleshooting 23 08-01-2011 04:30 PM
Ticking noise after valve adjustment, chain tensioner? Slickrick592 Troubleshooting 4 11-08-2010 03:05 PM
FI and oil light on after valve adjustment? (Fixed problem) doofiep007 Maintenance 5 02-11-2005 08:16 AM
