Bike wont start, key does not turn past "on" - 600RR.net
post #1 of 17 (permalink) Old 06-25-2019, 02:49 PM Thread Starter
Smalltittymcgee's Avatar
so i have an 06 cbr 600rr and im having trouble getting the bike to start. key wont turn past the on icon and when key is turned to fuel priming is heard. guague cluster does light up when key is turned to the on position but headlights are not on, battery was replaced today. i also checked my BAS to see if that may be the issue but its connected correctly. any insight to find the issue would be greatly appreciated
Smalltittymcgee is offline
post #2 of 17 (permalink) Old 06-25-2019, 03:17 PM
A blown headlight fuse will disable the starter circuit. ..fix your headlights and the bike will start.
wibbly is offline
post #3 of 17 (permalink) Old 06-25-2019, 03:40 PM Thread Starter
just replaced the fuse and still no start.
post #4 of 17 (permalink) Old 06-25-2019, 11:27 PM
do you headlights work? no working headlights = no start.
wibbly is offline
post #5 of 17 (permalink) Old 06-25-2019, 11:47 PM Thread Starter
Yeah the headlights don't turn on but. Not sure why. They're plugged in correctly and the fuse isn't blown as was just replaced
post #6 of 17 (permalink) Old 06-25-2019, 11:54 PM
Start digging. Power for the headlights goes thru the start button.
wibbly is offline
Wazoo (06-27-2019)
post #7 of 17 (permalink) Old 06-27-2019, 10:50 AM Thread Starter
update:
i now have the head lights turning on, still no priming of the fuel pump. im thinking i may have to remove the gas tank and start testing the pump.
post #8 of 17 (permalink) Old 06-27-2019, 06:23 PM
Anthony Jr Vargas's Avatar
Open up the killswitch and check inside for corrosion on the wiring.. check the toggle switch as well, dirt can build up in there causing a poor connection..
Hope it works..
You don't know, til you know.
Anthony Jr Vargas is offline
post #9 of 17 (permalink) Old 06-27-2019, 06:34 PM
Sorry. Your original post never read said the pump wasn't priming. Your typo was misleading
When you toggle the kill switch does the FI indicator show up on the dash?
wibbly is offline
post #10 of 17 (permalink) Old 06-27-2019, 06:36 PM
The only reason I mention the kill switch is because you mentioned the headlights not turning on..
I had a similar issue and almost ordered a new fuel pump. Well, turns out that the on/off toggle switch had a crap load of grime and dirt behind it. Some wd-40 cleaned it right up..
My headlights would also turn off on me during rides home at night which sucks ass in a rural area being that I was pretty much riding blind and had to pull over to follow the next car as he pretty much escorted me home..
Lng story short.. there's blue wire inside the kills-switch... (headlights) and it was broken off so I just soldered it together and it worked for awhile until the solder broke.. so just to keep it from happening again I just ended up splicing them and crimping them together.. my headlights are always on now but at least I don't have to worry about them going out anymore at night..
post #11 of 17 (permalink) Old 06-27-2019, 06:56 PM
If the kill-switch is good then the only other thing I can think of is the relay next to your battery under the seat. check it to make sure its not bad and check the fuse as well as the connections to the fuse for corrosion.
post #12 of 17 (permalink) Old 06-28-2019, 10:36 AM Thread Starter
alright ill try out he kill switch this weekend, fingers crossed this is the issue
post #13 of 17 (permalink) Old 06-28-2019, 10:42 AM
DOES THE FI INDICATOR SHOW UP ON YOUR DASH????
the reason i ask this question is because if it does, it rules out most people's suggestions. the test takes you 3 seconds and you don't have to take anything apart.
if you want to do it the hard way i'll stop posting here.
wibbly is offline
post #14 of 17 (permalink) Old 06-28-2019, 12:06 PM Thread Starter
i'm showing no FI indicator on the dash. for future reference what exactly does it tell you if it is lit?
post #15 of 17 (permalink) Old 06-28-2019, 12:23 PM
That the EFI system is powered up. .
It will come on for a few seconds then go out when you turn the kill switch to the run position.
If it doesn't come on its either the ign circuit (fuse), the EFI fuse, the kill switch, bank angle sensor, or engine stop relay.
wibbly is offline
post #16 of 17 (permalink) Old 07-02-2019, 11:03 AM
epalacios23's Avatar
I completly agree with this! I also have the wiring diagram and can send it over to you if needed!
epalacios23 is offline
post #17 of 17 (permalink) Old 07-08-2019, 01:07 PM Thread Starter
would you be able to send the wiring diagram, it would help out a lot
