Hi guys ! I will try to explain as good as possible my problem.
I have CBR 600RR 07. It has 33000 KM on it.
At first It only happened on high speed. The bike was stalling randomly. Sometimes everything was good and sometimes not. The tach stays on and there is no FI lights. It will start without problem after that but If I not rev it up It will stall again.
Lately It starts doing it on idle.
Idle is 1300RPM. The fan is working properly when the bike heatens up. No loose cables on battery. Spark plugs are new. There are no pinched fuel hoses. Fuel pump working properly. Maybe It's an electrical issue.
The thing I've noticed is when on idle sometimes It's like almost stalling but gets back.... and 3-4 seconds later shuts off.
I will upload video from today. I heaten It well and then I record the video :
( In the video the tach loads slow because the clock/turn fuse is not in place. And the problem It's not from that.)
I'll be thankfull If someone gives an idea to fix the problem.
