couldnt fine solution... plz help - 600RR.net
post #1 of 13 (permalink) Old 04-06-2007, 02:55 AM Thread Starter
hello, i need your help. so i was trying to get the licence plate light on. i accidently cut out the taillight wires, so i just tucked in the wire to the harness. " taillight works. then i cut off the licence harness and all the lights worked. later i tried to start my bike and all i hear is the battery rumbling. after a whilte the lights dim. what did i do? bike wont start and i need help !
yonimation is offline
post #2 of 13 (permalink) Old 04-06-2007, 02:59 AM
cyclesector.com
Disco's Avatar
Images: 31
Feedback Score: 85 reviews
Yikes. Well I'm not sure whats going on there. Your picture isnt working.
Disco is offline
post #3 of 13 (permalink) Old 04-06-2007, 02:59 AM
Nixinus's Avatar
Feedback Score: 16 reviews
it seems your battery has drained itself which probably happened from a short. If you have ay wire exposed or connected incorrectly and making a circuit it will drain your battery. Check all your connection again and make sure everything is properly insulated. If you find nothing make sure you have not connected a hot wire to a ground, that would short your system.
Nixinus is offline
post #4 of 13 (permalink) Old 04-06-2007, 03:00 AM
get ths pic working. sounds like you're grounding out somewhere
Spastik Monkey is offline
post #5 of 13 (permalink) Old 04-06-2007, 03:04 AM Thread Starter
ok pictures up. again after connecting every back where it should go, the light work. but now when i turn on the switch i hear the buzz. and when i start i dont hear the engine wanting to start, all i hear is the battery tryna start ( i dont know if that mad sense), then after 2-3 tries the lights dim =(
btw when i try to start ,the battery sounds energetic. its just that i dont hear the engine trying to start. i feel like if i charge the battery it would have the same affect. or am i wrong?
post #6 of 13 (permalink) Old 04-06-2007, 03:07 AM
the pic is kinda small, but it looks like you have bare wires, or you've hooked something up to a direct short. havy you tried pulling the taillight fuse and seeing if it'll start?
post #7 of 13 (permalink) Old 04-06-2007, 03:09 AM Thread Starter
yea pic is small, tried bigger but it says files to large. the picture shows just that i cut the wire off its hardness (hopefully nothing serious). where are the fuse box located and which ones the tail light?
post #8 of 13 (permalink) Old 04-06-2007, 03:15 AM
fuse box is located in a rubber cover on the left side of the bike. i don't remember if you have to remove the fairing or not. it'll be labeled tail light.
post #9 of 13 (permalink) Old 04-06-2007, 03:38 AM Thread Starter
just checked, all fuses are good. lights good until i turn on the switch and start up the bike, the noise comes around the battery area. but no engine noise =(
post #10 of 13 (permalink) Old 04-06-2007, 03:42 AM
so the bike starts? or it just cranks?
post #11 of 13 (permalink) Old 04-06-2007, 03:44 AM Thread Starter
still cranks
post #12 of 13 (permalink) Old 04-06-2007, 03:51 AM
hmmm, you may have cut a sensor or something. hard to tell without seeing it in person. can you push start it fine?
post #13 of 13 (permalink) Old 04-06-2007, 12:12 PM
I Am a Ticket Magnet
hammbone's Avatar
Images: 2
sounds to me like a short as welll........... make sure all of your wires are connected securely or capped off... you may have shorted out the harness... which would suck... i shorted out my front subharness a while back because one of my blinker wires came loose and grounded out....
Pics Here >> https://www.600rr.net/vb/showthread.php?t=70659
*On falling off a race bike at high speed -It's kind of like tumbling around inside a giant clothes-drier.
Dave Aldana (1975)
*At 180 mph, when your front wheel wants to play pogo stick, you don't do nothing. You don't sneeze, you don't hiccup, you don't even breathe. All you do is point it and hang on.
Kenny Roberts
hammbone is offline
