brake light problem - 600RR.net
post #1 of 8 (permalink) Old 04-08-2007, 10:49 PM Thread Starter
brake light problem
i have intergraded led tail light. before it was working properly now it looks like its always braking. i played with the brakes to see if its stuck but its not the lines...could it be a fuse? or a wiring problem?..pls help..oh and my bike is a 04 RR
TdotORR is offline
post #2 of 8 (permalink) Old 04-11-2007, 02:39 PM
Have you checked both switches located at the hand, and foot brake, to see if they are stuck, or hung up somewhere? If there is a short or loose connection in your wiring/connection plugs, the brake light will usually sometimes work, or not even work at all.
larry is offline
post #3 of 8 (permalink) Old 04-12-2007, 10:23 AM Thread Starter
im going to take a better look this weekend..thanks larry
TdotORR is offline
post #4 of 8 (permalink) Old 04-12-2007, 11:20 AM
Mad Chemist
WherzRoony's Avatar
Images: 57
The '03's had a recall for some issue with the rear brake master cylinder. I don't know if that applied to the '04's But I've had the rear brake light switch stick before.
I Like My Guns Like Obama Likes His Voters: Undocumented
WherzRoony is offline
post #5 of 8 (permalink) Old 04-12-2007, 12:08 PM
The brake recall was with one of the bolts on the rear brake caliper seizing due to corrosion.
larry is offline
post #6 of 8 (permalink) Old 04-13-2007, 05:05 PM
mcr500's Avatar
it could be your rear brake switch sticking
mcr500 is offline
post #7 of 8 (permalink) Old 04-14-2007, 12:28 AM Thread Starter
thanks guys...im waiting for better weather to take it to the shop to have it looked at...toronto is still some what cold
TdotORR is offline
post #8 of 8 (permalink) Old 04-14-2007, 01:17 AM
Ceph's Avatar
actually, it was the ball joint lookin pivot bolt, at the bottom of the rear master.
Ceph is offline
