highbeam wont turn on** loose connection ** problem solved - 600RR.net
post #1 of 7 (permalink) Old 04-20-2007, 09:49 AM Thread Starter
I have a problem with my headlights turning on. I do not have anything wired to my low beams but I have the projector mod and hids wired to my high beam. The inline fuses for the hids are not burned out and if I turn the high beam switch on, the blue light on the cluster doesn't even turn on. Any ideas?
kbcbr600 is offline
post #2 of 7 (permalink) Old 04-20-2007, 09:51 AM
chicosrr's Avatar
Check all your wires you may have clipped one or it may have burnt through! Check all your connections
chicosrr is offline
post #3 of 7 (permalink) Old 04-20-2007, 09:53 AM Thread Starter
everything seems to be fine, unless I'm overlooking something. but ill check again later today
kbcbr600 is offline
post #4 of 7 (permalink) Old 04-20-2007, 10:31 AM
dude YOU BLEW A FUSE...LEFT HAND SIDE OF THE BIKE Mid Ferring....I THINK ITS A 20 AMP AND YOUR GOING TO NEED NEEDLE NOSEPLIERS....GOOD LUCK
1sikCBR is offline
post #5 of 7 (permalink) Old 04-20-2007, 03:50 PM Thread Starter
the solder on one of the connections came loose. problem fixed.
kbcbr600 is offline
post #6 of 7 (permalink) Old 04-21-2007, 01:42 AM
MrBBQ's Avatar
Solder shouldn't be coming lose, maybe you should resolder all the connections to be safe it won't happen again?
MrBBQ is offline
post #7 of 7 (permalink) Old 04-21-2007, 12:26 PM Thread Starter
I did, I just didn't do a very good job the first time I did it. I guess I just wanted to get it done at the time.
kbcbr600 is offline
