secondary injectors are not spray (help) - 600RR.net
post #1 of 21 (permalink) Old 05-07-2007, 05:28 AM Thread Starter
RRReadyRacer's Avatar
i have alot of ideas but what does everyone think or has anyone had this prob
Day To Day Slidin
WHAT DO YAMAHAs AND SOOOSUKYS LOOK like from behind?Ive never seen it
RRReadyRacer is offline
post #2 of 21 (permalink) Old 05-07-2007, 07:11 AM
how do you know that the injectors are not spraying ?
fordfasterr is offline
post #3 of 21 (permalink) Old 05-07-2007, 07:21 AM Thread Starter
air box off 5500 and up nothin , and poor perfomence not enough fuel
Day To Day Slidin
post #4 of 21 (permalink) Old 05-07-2007, 07:47 AM
The was the back wheel spinning when you did this test ?
The bike will run like crap with the airbox open anyway...
If the rear wheel is not spinning, I don't think it will activate the secondaries... Also, try revving higher than 5k .. go to about 10k and see if they work. Use a flashlight or something to make sure.
post #5 of 21 (permalink) Old 05-07-2007, 07:53 AM Thread Starter
well it was running bad couldnt clutch up in secon couldnt power up in first
and check but as far as i know theres no gear indicator in the ecu ive done both in up on a stand and unpluged the neutral switch, on my brother 1000rr it sprays regardless of anything at 5500 they sparay maybe tps ?
Day To Day Slidin
post #6 of 21 (permalink) Old 05-07-2007, 08:17 AM
those injectors don't spray till about 10k
CAPITAL ROB is offline
post #7 of 21 (permalink) Old 05-07-2007, 08:39 AM
Thats what I'm trying to tell you meng...
Also, the ecu can detect a load from the sensors on the airbox ... it may never turn them on unless you are actually on the bike while moving........
post #8 of 21 (permalink) Old 05-07-2007, 10:54 AM
They should defiantly work air box or not, will run abit lumpy like but would rev right though
gray is offline
post #9 of 21 (permalink) Old 05-07-2007, 11:22 AM
Im having the same issue and have no idea what to do....the dealer doesnt "think" anything is wrong either so they are not replacing anything.
jerz600RR is offline
post #10 of 21 (permalink) Old 05-07-2007, 12:01 PM
I just talked to someone at dynojet and they say that throttle position doenst matter, its all RPM controlled. The only thing that he said is that maybe they wont spray in neutral if there is a neutral cut off in the ECM but that he isnt sure of that.
post #11 of 21 (permalink) Old 05-07-2007, 12:25 PM
raptor's Avatar
You need 50% throttle opening and over a certain number of revs -->
Try 5.5k.
"Help look after a$$hole rookies so they can become a$$hole bikers!"
"You appear intelligent, but when you open your mouth, the effect is spoiled"
'03 CBR600RR Black (and silver)
Micron stainless steel slip-on pipe
Dark MRA double bubble screen
Clear headlight lens covers
Home-made Ultra-bright white
Third-Eye and blue Crazy-Eyes
16/45 sprocket setup
raptor is offline
post #12 of 21 (permalink) Old 05-07-2007, 02:51 PM
Try 5.5k.
According to who? Not that i dont believe you or im saying that you are wrong but i have herd 8000 with 100%, 6000 at 75%, now 5500 at 50%.
post #13 of 21 (permalink) Old 05-07-2007, 03:09 PM
the only reason i know they dont work till about 10k or above is that when i put my power commander on, i stuck it on the wrong set of injectors. when i hooked the lap top computer onto the power commander i was not getting a reading for mapping, then i decided to rev the motor to see if anything changed and it did after 10 k rpms. then i called dyno jet and they told me i had it on the secondary injectors instead of the primarys
post #14 of 21 (permalink) Old 05-07-2007, 04:16 PM
Macho Office Monkey
chadandy12's Avatar
RRRRRRRRRRRRRRRR Wrong answer if you read the service manual or probably the owners manual maybe even it say 5500 RPM's or more than 50% throttle they are supposed to kick in.
08 600rr Orange/Black
https://www.600rr.net/vb/showthread.php?t=144174
Wifes new ride so pumped!!
chadandy12 is offline
post #15 of 21 (permalink) Old 05-07-2007, 04:18 PM
Macho Office Monkey
chadandy12's Avatar
Try 5.5k.
This is correct, nice call
post #16 of 21 (permalink) Old 05-07-2007, 04:22 PM
Ive also been told 5000 rpm and i doubt there gonna open in netural prolly foul plugs that way
RMH77 is offline
post #17 of 21 (permalink) Old 05-07-2007, 05:50 PM Thread Starter
thats what i thought but on the 1000rr it doesnt give a dam it sparys anytime
Day To Day Slidin
post #18 of 21 (permalink) Old 05-08-2007, 06:53 AM Thread Starter
dddddddddddddddddaaaaaaaaaaaaaaaaaam
Day To Day Slidin
post #19 of 21 (permalink) Old 05-09-2007, 05:38 AM Thread Starter
i never seem to get help
Day To Day Slidin
post #20 of 21 (permalink) Old 05-09-2007, 09:32 AM
Your not alone...ive been asking for 2 weeks. Im hoping that it is a case that no one on this board know rather than no one cares.
post #21 of 21 (permalink) Old 05-09-2007, 02:03 PM
What im gonna do is set up the bike on stands, put it in first and just go wide open throttle in 1st until 12K with the airbox open and see if they fire. Im gonna do it with a freind of mine so he can look at the tack and quickly engage the clutch incase god forbid the bike falls with the back tire spinning at 70 mph. My foot will be on the break and my thumb on the cut-off switch just incase. I know...not the smartest thing in the world to do but i got no choice.
