Problem on the 06' - - 600RR.net
post #1 of 8 (permalink) Old 05-09-2007, 03:19 AM Thread Starter
bwest3's Avatar
Okay.. This is a long story.. so here we go..
Heres the stats:
2006 600RR, with 7,000 miles
At full throttle, the bike gets to 7K RPM's and just stutters, and won't accellerate like its supposed to. You can let out of it a little bit, and about 60-80% it will make its way up to 15k or so like its supposed to.. but its stuttering the whole time, and spitting.
Now, before you ask, bike had bmc race, velocity stacks, jardine exhaust, power commander, & vortex 15/45 520 conversion..
Thought some of the mods might be the problem, but took it all back to completely stock minus the gears, and still has the same problem..
Its not the connection to the battery, already checked that..
Nothing in the airbox, or inlet tubes, checked that..
It really sounds like a fuel or spark problem.. but I'm not sure..
But at 7K miles, I shouldn't have problems with my plugs..
Also.. I don't know, where it only sputters at 7K RPMS...
Could it be something to do with the secondary injectors, or what about the coil packs maybe going bad?
2007 Repsol 1000RR
bwest3 is offline
post #2 of 8 (permalink) Old 05-09-2007, 06:07 AM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Its got to be fuel related
Crapy fuel----- Fuel pressure ----------Clogged injectors
Moeman is offline
post #3 of 8 (permalink) Old 05-09-2007, 01:22 PM Thread Starter
bwest3's Avatar
I forgot to mentio, i've tried different brands of fuel, and also put fuel injector cleaner in too.. still the same
2007 Repsol 1000RR
bwest3 is offline
post #4 of 8 (permalink) Old 05-10-2007, 03:47 AM Thread Starter
bwest3's Avatar
anyone?...
2007 Repsol 1000RR
bwest3 is offline
post #5 of 8 (permalink) Old 05-10-2007, 06:10 AM
06seebrrr's Avatar
should be under warranty still right
when the boogey man goes to sleep at night he checks the closet for chuck norris
06 cbr 600rr pearl orange tribal jardine slip on,-1 front sprocket, seat cowl, zero gravity wind screen, power commander and other stuff also
06seebrrr is offline
post #6 of 8 (permalink) Old 05-10-2007, 06:22 AM
Back in the Day
Moeman's Avatar
Images: 665
Ok in that case check the fuel pump's pressure
may be its pressure aint up to par
Moeman is offline
post #7 of 8 (permalink) Old 05-10-2007, 07:19 AM
rocketscience's Avatar
Images: 17
Yes, fuel related... Spark issues are noticed at lower rpm's usually..
I'm never wrong. I once thought I was wrong, turns out, I was mistaken.
rocketscience is offline
post #8 of 8 (permalink) Old 05-10-2007, 05:14 PM Thread Starter
bwest3's Avatar
you would have to check the fuel pump under load to get it to loose pressure tho.. right?
2007 Repsol 1000RR
bwest3 is offline
