Need help with Power Shifting - 600RR.net
post #1 of 13 (permalink) Old 10-03-2007, 11:13 AM Thread Starter
CBRYDR's Avatar
Hey guys,
I've noticed an issue while attempting to power shift. I notice when shifting from 2nd to 3rd and 3rd to 4th, the range where I get a smooth shift is between 5-6K RPM. Whenever I shift at a higher RPM 10-13K(that's with re-adjusting the throttle just a little notch), one of two things happen:
1. The shifter is stuck HARD and doesn't shift.
2. I shift, but it comes with a huge jolt!
What am I doing wrong here? I'm trying to time it, but sometimes it works, sometimes it doesnt.
Would I be able to power shift at higher RPMs smoothly? Thanks
E
- WC Frame Sliders
- Two Brothers M-5 Slip-On
- PP 2CT's
- Gilles Tooling Rearsets
NESBA B #818
CBRYDR is offline
post #2 of 13 (permalink) Old 10-03-2007, 11:33 AM
element692121's Avatar
by power shifting do you mean without the clutch ??
if so you need to back out of the throttle a lil and bang the $hit out of it . then instantly right back on the throttle ..
07 600rr pearl white (sold)
07 s2000 232whp white (sold)
05 4runner black (sold )
98 prelude 287whp na (sold)
09 civic si 236whp taffy white (sold)
06 civic si cp black ( current daily )
13 cbr1000rr red (current project )
element692121 is offline
post #3 of 13 (permalink) Old 10-03-2007, 11:57 AM
getmadboy's Avatar
getmadboy is offline
post #4 of 13 (permalink) Old 10-03-2007, 12:16 PM Thread Starter
CBRYDR's Avatar
Yes, I do mean clutchless. Sorry.
Normally I don't need to gang the ish out of it! Sometimes, I tap it and it slips right into the next gear. I will try that though. Thanks
- WC Frame Sliders
- PP 2CT's
NESBA B #818
CBRYDR is offline
post #5 of 13 (permalink) Old 10-03-2007, 12:19 PM
Macho Office Monkey
chadandy12's Avatar
Theres a sweet spot for shifting up and down actually you just gotta find it. Once you do clutchless is the sh*t
08 600rr Orange/Black
https://www.600rr.net/vb/showthread.php?t=144174
Wifes new ride so pumped!!
chadandy12 is offline
post #6 of 13 (permalink) Old 10-03-2007, 01:14 PM
the sweet spot is right where you line up the revs with were they should be in the next gear ... you can also downshift clutchless by opening the throttle a little bit to match the revs of where it would be in the lower gear ..its basically rev matching weather its upshifting or downshifting
post #7 of 13 (permalink) Old 10-03-2007, 02:26 PM
Jim Moore's Avatar
Feedback Score: 9 reviews
Are you accelerating or just sitting there at 11000 rpm? If you are just sitting there, it is much harder to upshift without the clutch. If you are accelerating (WFO - shift - WFO) it shifts much more easily.
Jim Moore is offline
post #8 of 13 (permalink) Old 10-03-2007, 02:38 PM Thread Starter
CBRYDR's Avatar
No, I am accelerating. Normally, from 1st to 2nd, I engage the clutch. For every gear thereafter, it's clutchless. When I take 2nd gear to 11K, and shift around that mark, it feels as though the shifter is 'locked' and won't shift, even when I let off the throttle a tad. It's weird.
E
- WC Frame Sliders
- PP 2CT's
NESBA B #818
CBRYDR is offline
post #9 of 13 (permalink) Old 10-03-2007, 02:43 PM
its all about the throttle blip!
usmcr6 is offline
post #10 of 13 (permalink) Old 10-03-2007, 02:46 PM Thread Starter
CBRYDR's Avatar
So how can that be measured? Do you blip less as youre going up gears? (i.e. 2nd-6th)
- WC Frame Sliders
- PP 2CT's
NESBA B #818
CBRYDR is offline
post #11 of 13 (permalink) Old 10-04-2007, 10:57 AM
i clutchless all the time, the problem you are having is timing, it has to be just right to be smooth keep practicing!
SilvaRR is offline
post #12 of 13 (permalink) Old 10-04-2007, 03:59 PM
Simmonds steak Do not leave the kitchen without it
find out the sweet spots. Apply constant pressure upwards [not too hard], and blip the throttle. She should pull right in.
yoyokata is offline
post #13 of 13 (permalink) Old 10-08-2007, 11:20 PM Thread Starter
CBRYDR's Avatar
I'm really proud to say that I have almost mastered powershifting (well not really master, but you know what I mean :P) It feels so much better. I blip in accordance with revs. It's amazing!
Anyhow, thanks for all the advice!
E
- WC Frame Sliders
- PP 2CT's
NESBA B #818
CBRYDR is offline
