03 fuel pump issues - 600RR.net
post #1 of 3 (permalink) Old 10-04-2007, 02:14 PM Thread Starter
03 fuel pump issues
the fuel pump in my bike will not prime when i turn the key.I have been able to turn the switch on and off like 20 times and the pump will randomly prime.Does this sound like a ground/relay problem or the fuel pump itself???
giallo sv is offline
post #2 of 3 (permalink) Old 10-04-2007, 02:19 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
Check the relays under the left side ram air cover
Did you mess with the upper or the headlights at all ?
BAS bank angle sensor might be loose
Moeman is offline
post #3 of 3 (permalink) Old 10-04-2007, 02:29 PM
Knightslugger
Posts: n/a
randomly as you toggle the run switch? sounds like something is loose or malfuntioning. either something in the switch itself, the fuel cut off relay, or the BAS.
