Engine Mount Bolt Sounds Like It's Gonna SNAP , HELP !? - 600RR.net
post #1 of 17 (permalink) Old 10-09-2007, 11:44 PM Thread Starter
Okay so I was just in the garage trying to put on frame sliders , went step by step made sure everything fit, cut the whole correctly . Okay so now I am ready to put in the slider problem is we get about half way ( my bf is stronger so he is doing this) and the bolt just isn't going in all the way. So we take the slider out and decided to put the engine bolt back in as we are both tired . Now he is putting the original bolt back in and he is pushing it at over 100 lbs of torque and that bitch ain't going in. It starts making this really bad noise he say's that means if we push it the bolt will snap and that is bad. At this point the bolt is almost in but not quite . WTF ?? it came out okay ? What do I do now ??? anyone else have probs ??
TwistyB*tch is offline
post #2 of 17 (permalink) Old 10-09-2007, 11:48 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
youre probably crossthreading the bolt.
7093
SLAPS808 is offline
post #3 of 17 (permalink) Old 10-09-2007, 11:49 PM
What kind of sliders? I had no problems with my motivation sliders at all.
-adam
isolated1523 is offline
post #4 of 17 (permalink) Old 10-09-2007, 11:51 PM
SLAPS808's Avatar
is the bolt threads on both the slider bolt and the original bolt good or rounded out
7094
SLAPS808 is offline
post #5 of 17 (permalink) Old 10-09-2007, 11:52 PM
SLAPS808's Avatar
chances are is that you may have stripped the bolt or worse...stripped the threads on the bolt hole.
100ftlbs or more of pressure is too much to tighten that bolt.
7095
SLAPS808 is offline
post #6 of 17 (permalink) Old 10-09-2007, 11:56 PM Thread Starter
7094
They are both good , not striped , he said the same thing , waaaay too much pressure for the bike so he stopped . I am using BG sliders...a canadian maker
post #7 of 17 (permalink) Old 10-10-2007, 12:00 AM
Stu-Pac's Avatar
is it the wrong slider cuz i know one side slider is longer than the other!!!
Stu-Pac is offline
post #8 of 17 (permalink) Old 10-10-2007, 12:01 AM
gee
Overpaid South Pacific Barista overactive ADHD crew off their meds!!
gee's Avatar
are the threads the same size????
stainless steel is alot harder than wot its winding into!!
gee is offline
post #9 of 17 (permalink) Old 10-10-2007, 12:02 AM
SLAPS808's Avatar
does he know what thread size/pattern and type of bolt? a metric size bolt will not fit in a standard size hole and vice versa.
look in and inspect the threads on the bolt hole.
7096
SLAPS808 is offline
post #10 of 17 (permalink) Old 10-10-2007, 12:04 AM Thread Starter
The bolt were are having trouble getting back in is the original one , we took the slider bolt out and thought we out the original back in and go back to it tomorrow...but it just not going all the way in
post #11 of 17 (permalink) Old 10-10-2007, 12:05 AM
+1. i did that with mine.
prettyNpink is offline
post #12 of 17 (permalink) Old 10-10-2007, 12:06 AM
SLAPS808's Avatar
compare the two bolts and their thread patterns. are they the same?
7098
SLAPS808 is offline
post #13 of 17 (permalink) Old 10-10-2007, 12:06 AM
Stu-Pac's Avatar
idk sorry.. im a noob
Stu-Pac is offline
post #14 of 17 (permalink) Old 10-10-2007, 12:08 AM
Lifetime Premium
sdca7718's Avatar
Feedback Score: 9 reviews
I ate about half a thread on the right side when doing mine, really made me mad. I just threaded it through the back side of the hole to clean it back up.
sdca7718 is offline
post #15 of 17 (permalink) Old 10-10-2007, 08:40 AM
kiggy74's Avatar
Feedback Score: 7 reviews
By the way, the torque spec for those bolts is like 45 ft/lbs. Your screwing them into an aluminum block. If you go a pound over 45 you're taking the chance of stripping out the threads in your engine block, which would be really really bad.
WERA #262
2007 CBR600RR
kiggy74 is offline
post #16 of 17 (permalink) Old 10-10-2007, 09:14 AM
Do yourself a favor and go out and buy a tap and die metric set and run the bolt through the die and clean it up, then try again. If you can easily get to the threads, run a tap through it as well, just make sure you get the correct pitch on the tap and die set.
okiedokie is offline
post #17 of 17 (permalink) Old 10-11-2007, 11:51 AM Thread Starter
DONE ! and worked perfectly , when we took out the original bolt there was a hell of alot of gunk left behind caked in the threads , never would have thought there would be that much crap so I never thought to look. Anyway cleaned it all out and it is good , now we have the tools if the other side is the same prob so all is well. Thanks for all the input guys ! I am still learning here
