FI light on 07 600rr help!!!!!!! - 600RR.net
post #1 of 13 (permalink) Old 11-05-2007, 08:48 PM Thread Starter
ll2009's Avatar
Feedback Score: 8 reviews
my friend is having problems on his 07 FI light is on, i search but coulnt find anything, need help how to read the code, is trhowing 2 fast blinks pause the 1 slow blinks the 2 fast one again ...thanks in advance
08 GSRX 750 ....
06 600RR orange tribal....SOLD
03" 600 RR...SOLD
01 Prelude SH...:evil1:
98 Acura TL..
http://www.myspace.com/ll2009
ll2009 is offline
post #2 of 13 (permalink) Old 11-07-2007, 07:39 AM Thread Starter
ll2009's Avatar
any one?"?..............
08 GSRX 750 ....
03" 600 RR...SOLD
98 Acura TL..
ll2009 is offline
post #3 of 13 (permalink) Old 11-07-2007, 08:54 AM
Knightslugger
Posts: n/a
you don't have a honda service book? 2 flashes that last 0.5 seconds, then a pause then a 1.3 Second flash followed by two 0.5 second flashes right?
It's thorwing a #2 and a #12 code. #2 is a MAP Sensor performance problem and a #12 is a No.1 Primary Injector Circuit Malfunction.
unless he's missing the first 1.3 second flash, at which point forget about the #2 code.
post #4 of 13 (permalink) Old 11-07-2007, 07:58 PM
Feedback Score: 7 reviews
has he had the airbox off
the map sensor is bolted to the bottom of it an it can be a pain to hook back up correctly.
the hose is too short really. i ended up unbolting it and just zip tieing the sensor to the wiring harness.
RShackleford is offline
post #5 of 13 (permalink) Old 11-07-2007, 08:16 PM
is the bike still under warranty? how bout taking it to the dealer? do bikes come with an OBD plug?
07 600RR Pearl White/Silver
HIDs - 6000k
Akrapovic Ti Exhaust
Proton flush mounts
06 CA tail light conversion
CRG Shorties
Puig double bubble
Homemade FE
straight6 is offline
post #6 of 13 (permalink) Old 11-08-2007, 06:15 AM
there is a diagnostics plug. its the red one that is capped off under the seat. it just shows the code that the dash is blinking though.
just count the blinks look up the number.
post #7 of 13 (permalink) Old 11-08-2007, 10:36 AM Thread Starter
ll2009's Avatar
thanks for all the replies guys, yeah we took the air box off to install a new filter, ill check all this stuff out, and yes the bike has a warranty i just figure it was something small that we can fix ...
08 GSRX 750 ....
03" 600 RR...SOLD
98 Acura TL..
ll2009 is offline
post #8 of 13 (permalink) Old 11-08-2007, 12:17 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
The map sensor is the reason behind the FI light
Moeman is offline
post #9 of 13 (permalink) Old 11-08-2007, 02:09 PM
Knightslugger
Posts: n/a
thaaaaaaaaat's my guess as well...
odd though he's getting a #12 too...
post #10 of 13 (permalink) Old 11-08-2007, 03:58 PM
like i said the MAP is a PITA. just unbolt it from the bottom of the airbox. it makes it easier to plug the hose and wire back into. since it doesnt have to be bolted there just zip tie it to something stable.
post #11 of 13 (permalink) Old 11-08-2007, 04:06 PM
You are all sheep
squeaky's Avatar
can having the MAP sensor disconnected cause problems with your exhaust?
You're all sheep.
squeaky is offline
post #12 of 13 (permalink) Old 11-08-2007, 04:46 PM
Knightslugger
Posts: n/a
Depends on what the exact problem is...
post #13 of 13 (permalink) Old 11-09-2007, 06:19 AM
well considering that the MAP reads engine vacuum and adjusts the injector pulse accordingly i can see where it would probably destroy the air fuel curve
