Bike won't shift out of first. - 600RR.net
post #1 of 33 (permalink) Old 01-01-2008, 01:42 PM Thread Starter
03 600rr won't shift out of first. I have no idea where to begin checking. The shifter moves, but never clicks into gear. Any ideas?
Truthalive7 is offline
post #2 of 33 (permalink) Old 01-01-2008, 04:26 PM
Knightslugger
Posts: n/a
ok, is this with the engine running or what?
post #3 of 33 (permalink) Old 01-01-2008, 05:35 PM
Feedback Score: 7 reviews
even on rear stand if the bike isnt running or at least manually turning the rear wheel
you might get a gear maybe two
RShackleford is offline
post #4 of 33 (permalink) Old 01-01-2008, 05:44 PM Thread Starter
Off or on, the bike will not shift out of first. The shift pedal feels limp. Normally downward pressure in first feels firm, but the pedal moves. Could the the crankshaft gear have slipped?
post #5 of 33 (permalink) Old 01-01-2008, 05:53 PM
Knightslugger
Posts: n/a
oooooh ho hooo ho hoooo...
ouch.
oh that sucks... RShackleford might just be right... it probably isn't a gear that you need though. i'm not really experienced in this field.
Was there an event that preceded this problem?
post #6 of 33 (permalink) Old 01-01-2008, 06:17 PM
shiftn3rdon1's Avatar
ouch.
Yeah did you take anything apart before this started to happen?
Bungle in the Jungle!!!
Beep Beep m' Beep Beep YEAH!!!
shiftn3rdon1 is offline
post #7 of 33 (permalink) Old 01-01-2008, 06:18 PM
49erRider's Avatar
Yah a little more info. Did you go down or did this just pop out unexpected out of no where?
49erRider is offline
post #8 of 33 (permalink) Old 01-01-2008, 06:36 PM
from the manual
hard to shift
-improper clutch operation
-incorrect oil weight
-bent shift fork
-shift fork shaft
-shift drum
-shift drum groove
-bent gearshift spindle
tranny jumps out of gear
-gear dogs
-gear shift grooves
-shift fork shaft
-shift drum stopper arm
-stopper arm spring
-bent shift fork
-gearshift spindle
post #9 of 33 (permalink) Old 01-01-2008, 07:15 PM Thread Starter
I dropped the bike on the left side at a very low speed. this caused the problem. My bike is exactly like the blue one depicted above, by the way - nice choice!
post #10 of 33 (permalink) Old 01-01-2008, 07:18 PM
kihun's Avatar
Feedback Score: 6 reviews
Your shifter is bent. I dropped my F3 too. I couldn't shift out of first gear because the shifter was bent.. take a good picture of another RR shifter and adjust it.. or just straighten out the shifter.
2006 Yamaha R6 - STOLEN (miss riding)
350z Track edition -Back to stock, soon to be turboed. 500WHP
kihun is offline
post #11 of 33 (permalink) Old 01-01-2008, 07:30 PM
Knightslugger
Posts: n/a
does this help?
post #12 of 33 (permalink) Old 01-01-2008, 07:31 PM Thread Starter
Here are some pictures of it. Does it look bent? I can't really tell. And if it is, where exactly is it bent? Thanks...
post #13 of 33 (permalink) Old 01-01-2008, 07:39 PM
A blue one eh? You over Europe?
post #14 of 33 (permalink) Old 01-01-2008, 07:41 PM
doofiep007's Avatar
If the spline shaft coming out of the tranny takes a hit it will jump off the shift star....there is a really thin piece of metal holding it in place. See if there is play in the upper heim (in or out) on the spline.
doofiep007 is offline
post #15 of 33 (permalink) Old 01-01-2008, 07:41 PM
Knightslugger
Posts: n/a
Looks pretty straight to me...
post #16 of 33 (permalink) Old 01-01-2008, 07:44 PM Thread Starter
I have done some tampering, and I am worried something is disconnected underneath.
post #17 of 33 (permalink) Old 01-01-2008, 07:45 PM Thread Starter
I don't quite understand what to look for here. Do I need to start pulling the plastics and cover off? Where is the spline?
Thanks
post #18 of 33 (permalink) Old 01-01-2008, 09:05 PM
If you replaced it yourself with oem parts it will run you like $180.00 if you have to do it yourself.Its just a stupid asspain to get done.
R6ixxer is offline
post #19 of 33 (permalink) Old 01-01-2008, 09:07 PM
BTW its common to mess up a shift fork when your drop a bike with stock rearsets.I've seen it more than once.
R6ixxer is offline
post #20 of 33 (permalink) Old 01-01-2008, 10:17 PM
ok i know whats wrong with it. i go to school for motorcycle tech and i just got done with this class it is you shifting paw is too worn down and is not catching and keeping in gear. or your shift fork has too much wear and isnt catching which means your shift dogs are not connecting. you will have to split the cases and rebuild your tranny which is about 10 hours of labor
psy_co8 is offline
post #21 of 33 (permalink) Old 01-01-2008, 11:43 PM Thread Starter
If that is the case, I will do it, but I don't know where to begin...
post #22 of 33 (permalink) Old 01-02-2008, 11:08 AM Thread Starter
I don't see how this analysis could be the result of a fall
post #23 of 33 (permalink) Old 01-02-2008, 11:38 AM
it could have bent the shift rod by the fall the same thing happened to my bike when i lowsided it it bent my shift rod resulting in bent shift forks
psy_co8 is offline
post #24 of 33 (permalink) Old 01-02-2008, 11:42 AM
Knightslugger
Posts: n/a
durring a fall, does the FD Sprocket even hit the ground? i suppose the sudden trauma of the stop could cause the damage, but that'd have to be a violent fall!
post #25 of 33 (permalink) Old 01-02-2008, 11:48 AM Thread Starter
I don't think the sprockets did, and the fall was not very violent, the back wheel skidded out from under me at 5 mph.
post #26 of 33 (permalink) Old 01-02-2008, 01:31 PM Thread Starter
This sounds probable. So should I get a new rod and new shift forks if this is the case? Should I take it to a shop and get it over with?
post #27 of 33 (permalink) Old 01-02-2008, 07:07 PM
If you have the money its worth taking to a shop.
R6ixxer is offline
post #28 of 33 (permalink) Old 01-02-2008, 07:13 PM
NraGed's Avatar
Feedback Score: 5 reviews
I'm with 6ixxer....go pay the diag and then decide if it's a home job ? If you misdiagnose it yourself, you could be in too deep?
2005 600RR - SOLD
2007 600RR - SOLD
NraGed is offline
post #29 of 33 (permalink) Old 01-03-2008, 04:11 PM
sethr21785's Avatar
Images: 2
Feedback Score: 14 reviews
can you push in on the top where the shifter goes into the casing? there shouldnt be any play there and if there is then you need to get a plate that holds it in place.. part # 14623-MV1-000... if your lucky that is all it is and its a cheap part.. the only thing that sucks is that you have to remove the clutch basket to get to it..
http://www.ronayers.com/fiche/200_04...50&parent=5240
this link might help..
sethr21785 is offline
post #30 of 33 (permalink) Old 01-04-2008, 07:03 PM
i just posted a how to on exactly how to do that.
