'04 600rr - Knocking Sound on Cold Start-up - 600RR.net
post #1 of 7 (permalink) Old 01-05-2008, 08:10 AM Thread Starter
I own an 04 600rr, 17xxxkms.. I only aquired it recently & am not sure about a few things...
Firstly, sometimes on a cold startup, I can hear this loud knocking noise coming from the engine. It only last for 3-4 seconds then it sounds "normal". When I did my first oil change (using motul 5100), I didn't fill to the max level on the sight glass, it was slightly above the lower mark. I started the bike & it made the same knocking noise, but it didn't go away for approx 20 seconds, so I hit the kill switch, topped up the oil & tried again, which seemed to work... no knocking noise..
I this normal? or should I panic?
Also, when I'm cruising at low rpm, If I throttle on firmly, I can hear a clunking noise.. It's really annoying, I have to be dead smooth or else I can hear it, note: it's definitely not from the chain being loose.
Any help would be appreciated.
Jason
Speedracer is offline
post #2 of 7 (permalink) Old 01-05-2008, 04:42 PM
troy45's Avatar
When I've done oil changes mine knocks a little too as you first start it. So now I disconnect the fuel pump and let it turn over a few times to pump oil around the motor before starting up. It's best filling to the upper level initially beacuse this will drop once the motor starts and it pumps oil all around the motor - I run mine a few times to get a steady reading.
It normally sounds OK when I start it otherwise even if it's been stood for some time so I'm not sure what you're hearing.
When you say cruising at low rpm's then it clunks when you accelerate are you trying this in top gear? Could be that you're asking too much of the motor at low revs in a high gear, with the peak power at say 14,000 rpm it really doesn't have much power or torque at the bottom end of the rev range. Try dropping a gear or 2 before accelerating. If it's not in a high gear when you get the knocking maybe see if you can compare it with another RR?
troy45 is offline
post #3 of 7 (permalink) Old 01-05-2008, 04:54 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
The sound you are hearing is from the fuel injectors
and that is a normal condition
Moeman is offline
post #4 of 7 (permalink) Old 01-06-2008, 06:36 AM Thread Starter
did you even read my post? :icon_roll it's obviously not the fuel injectors, I can tell the difference between injectors ticking & knocking.
post #5 of 7 (permalink) Old 01-06-2008, 06:45 AM Thread Starter
I'm hearing the same noise you hear after an oil change, except not just after an oil change, but on most cold starts.
When you say cruising at low rpm's then it clunks when you accelerate are you trying this in top gear? Could be that you're asking too much of the motor at low revs in a high gear, with the peak power at say 14,000 rpm it really doesn't have much power or torque at the bottom end of the rev range. Try dropping a gear or 2 before accelerating. If it's not in a high gear when you get the knocking maybe see if you can compare it with another RR?[/
Not just in top gear, any gear.. I'll try comparing it with another 600rr, i haven't had the opportunity yet. I know what your getting at about "asking too much" of the motor, but I'm certain it's not that, just feels like somethings loose, sounds like the gearbox... I think the previous owner had a little too much fun on it
post #6 of 7 (permalink) Old 01-06-2008, 12:41 PM
Is it a knocking or more of a slapping noise? Also, as far as oil goes, you should have your oil level between the lines on the sight glass.
Knocking on Cold start sounds like it may be coming from the bottom end. Excess rod bearing clearance perhaps?
Jason
Flipper is offline
post #7 of 7 (permalink) Old 01-12-2008, 02:13 PM
anotherhenry's Avatar
Images: 14
Honda instructs that, after replacing oil, start engine and let idle for 3-5 min. stop engine and with bike upright oil level should be at upper line, not in the middle. keep it at the upper line or you may damage upper end of motor in time.
anotherhenry is offline
