fuel pump wont prime. HELP! - 600RR.net
post #1 of 13 (permalink) Old 01-07-2008, 05:59 PM Thread Starter
Hello I need a little help getting the fuel pump to kick. I just got done replacing my air filter and when I went to fire her up the fuel pump wouldn’t kick. Battery is fine and so are the fuses, switched the three left side relays around and still nothing( no corrosion either) the bike was stunted before I got it so there is no BAS. Just trying to get some feed back on what I need to check/ or test?? thanks:01_thumbu
Ryanwill86 is offline
post #2 of 13 (permalink) Old 01-07-2008, 07:35 PM
Ride Red
AFP520's Avatar
Make sure the red kill switch isn't on.
AFP520 is offline
post #3 of 13 (permalink) Old 01-07-2008, 07:38 PM
Chief IronLungs
cbrRedRag's Avatar
Feedback Score: 8 reviews
your font is too small i cant even read it
good luck with finding out the problem
Hit busters on the head like Vonage
* Im not rude, youre just insignificant
cbrRedRag is offline
post #4 of 13 (permalink) Old 01-07-2008, 07:43 PM Thread Starter
Better?
post #5 of 13 (permalink) Old 01-07-2008, 07:43 PM
Feedback Score: 7 reviews
whatever the original owner did to make the bike run without a bas might have came undone
RShackleford is offline
post #6 of 13 (permalink) Old 01-07-2008, 07:43 PM Thread Starter
not being a *****
post #7 of 13 (permalink) Old 01-07-2008, 07:44 PM Thread Starter
yea what might that be?? how do you bypass the BAS so i can look over it??
post #8 of 13 (permalink) Old 01-07-2008, 07:45 PM
Chief IronLungs
cbrRedRag's Avatar
Originally Posted by Ryanwill86 View Post
not being a *****
oh not at all, was just letting you know it was very hard to read on my screen
good luck once again
1000th post gyeah!!!
post #9 of 13 (permalink) Old 01-07-2008, 07:46 PM
ryoung57's Avatar
Probaby the BAS bypass, or the kill switch. I've been guilty of that one. I sat on the side of the road for an hour trying to push start my bike when it died after I accidently bumped the kill switch. Boy did I feel dumb.
I rear ended a car a few days ago.......
The driver got out of the other car, and he was a DWARF!!
He was pissed!
He looked up at me and said "I am NOT happy!"
I said, "Then which one are you?"
*****Join the revolution*****
*****http://www.ronpaul2008.com/*****
ryoung57 is offline
post #10 of 13 (permalink) Old 01-07-2008, 07:47 PM
ryoung57's Avatar
It should be pretty obvious. There will be some kind of shoddy workmanship wiring near the guage cluster/harness. Just look for the wire with tape on it and check it out.
He was pissed!
ryoung57 is offline
post #11 of 13 (permalink) Old 01-07-2008, 08:02 PM
tripage's Avatar
Feedback Score: 91 reviews
Bas, the plug under the gas tank for the fuel pump came off. White plug by battery not plugged in. blown diode(03-04) Bad fuel pump not common. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #12 of 13 (permalink) Old 01-07-2008, 10:25 PM Thread Starter
so how do i do this shady BAS by pass. where are the wires involved coming from? any other ideas?
post #13 of 13 (permalink) Old 02-09-2008, 06:39 PM
Feedback Score: 6 reviews
Trip
what does the diode do? I am searching the forum before i ask the same questions. same thing here. my batt is good, test all relays, bypassed the BAS and the kill switch. still no pump action. if I remove the relay and bring power from the batt to the relay leads to the pump it kicks on. I cant think of anything else. anyone got a diagram for an 07?
ircsmith is offline
