How to keep you lights off until the bike is running - 600RR.net
DIY Write up's This forum should be used for any step by step descriptions of a job you are tackling. Pictures are a big help to clarify the process
post #1 of 65 (permalink) Old 04-09-2010, 02:29 AM Thread Starter
Nico's Avatar
Hi all,
Intro
Now I found a couple of threads on this, but they were a couple of years old and I wasn't much of a fan of the method they used, one was using the un-rectified output of the alternator to switch a relay, and another was a timer based solution.
My controller monitors the battery voltage to decide if the headlights should be on or not.
What I have based my design on is the fact that before the bike starts you have at most 12.5V in the system and once your running and charging the battery you have around 14V.
The aim is that by monitoring the battery voltage, when the circuit senses the voltage getting above a threshold value the headlights turn on, and then stay that way.
Parts List
Here is a parts list of what you will need to build this controller with prices in $AU (and part numbers for jaycar)
To this you will have to add the cost of whatever you choose to protect your circuit with, for mine I have chosen to pot it to ensure a completely watertight seal, cost of around $3 for the box and around $35 for the potting compound - but I had way to much of that!
Power Consumption
The circuit in its standby condition only draws around 45mA, so is a hell of a lot more efficent than the headlights, once triggered it draws around 300mA, but that will change dramaticly depending on what relay you choose to use.
Basic Functional Description:
The schematic of the circuit you will be building:
The description:
Reference Voltage
R2 and the zener set up a reference point well below the minimum voltage the bike will operate under any normal circumstance (6.8V). The value of R2 is set to limit the current through the zener to just above its minimum current to allow it to operate at the correct voltage. In this case around 38mA
Voltage Sensing
R1 is a 20k potentiometer set to give an output at the wiper of around 6.3V with the bike off and around 7.3 with the bike running.
Comparator
IC1 is set up as a comparator with no feedback (open loop) to allow the output to swing between rails. The output will swing from around 10V to around 2V when the voltage at the -ve input goes above the reference (ie once the bike starts)
Inverter
IC2 is a 555 timer set up as an inverter. When you start the bike and cause the output of IC1 to swing to 2V this will cause the output of IC2 to go from 0V up to 12V applying power to K1 via D2.
The reason for doing this instead of simply swapping the inputs to IC1 is that the 555 can sink and source up to 200mA at its output compared to 20mA for the comparator (IC1), and due to the output of the comparator only swinging between roughly 2V and 10V I found it a lot simpler than setting up a transistor to allow full rail voltage swing (0V - 12V)
The Output
Once 12V is applied to K1 via D2 its contacts will make causing 12V to be applied via D3 latching the relay on regardless of what the voltage on the output of IC2 is. D2 is required to prevent the current being supplied via D3 from flowing into the output of IC2 when K1 is latched and IC2's output goes low. D3 is required to prevent the current being supplied via D2 from trying to drive the load (your lights) thereby exceeding the rated output current of IC2 and possibly pulling its voltage below what is required to activate K1.
Resetting the Controller
Finally the controller will reset when power is removed ie:
When you turn the key off, or;
When you stop the bike with the kill switch and then hit the starter (with the kill switch still in the stop position).
Building the Controller
To build it you will need everything on the parts list, some things may be substituted, or different values used, and feel free to ask if your not sure about something.
First step is to print off the schematic diagram, after that you just follow it and hook everything up as it says. You will need to cut the tracks on the bottom of the vero board to ensure everything is hooked up right, and there is plenty of info out there on the net about soldering and the like so I wont go into that here.
Some pictures of the finished circuit:
The last ones are of the enclosure I used and the potting compound.
To Be continued in the next post...
Nico
Nico is offline
post #2 of 65 (permalink) Old 04-09-2010, 02:32 AM Thread Starter
Nico's Avatar
Part 2
Set up Procedure
To save confusion:
When I say turn the bike on, I mean only the key. (kill switch doesn't matter)
When I say start the bike thatís when you fire her up!
When turning the pot slowly you may hear the relay chattering, this is nothing to be concerned about, just move the pot a little further and it will sort itself out, the relay should not chatter during normal operation (once you have it set up properly)
Step 1:
Hook it up as per the schematic ensuring that your relay is rated for the headlight, if you look at the photos of the one I built you will see the yellow box, that small relay runs the big one bolted to the back
Step 2:
Testing the board, With the bike off turn the pot fully clockwise. Turn the bike on, if the headlight comes on, then turn the pot fully counter clockwise and turn the bike off and back on again.
Now your pot will be on the stop one way or the other, with the bike on slowly turn the pot until the headlight comes on. If this works then you have a working circuit ready for tuning so proceed to step 3, otherwise check out you circuit to see where you may have gone wrong i.e. bridged solder connections, incorrect component orientation (pay particular attention to the diodes and ICs), over heated something when you soldered it together (blown up components and or dry joints), or maybe just wired it up wrong. In the case of the last I find it helpful to print the schematic off and red pen each connection as I make it.
Step 3:
Next place a multimeter on pin 2 of the 741 op-amp, note this voltage, and slowly turn the pot so that the meter reads 0.25V to 0.5V below the original reading. If you donít have a multimeter then you can turn the pot back a very small amount in the opposite direction to what you did to cause the lights to come on in step 2.
Step 4:
Turn the bike off to reset the circuit and test it out!
- Turn the bike on, no headlights
- Start the bike and the headlights turn on
Installing the Controller on the Bike
For starters you will need to know where to wire it in so for that I have drawn it onto the bikes schematic.
Just cut at the red lines and wire it up as shown, please note that this is for an 04RR
I have installed mine under the left hand side fairing with a waterproof connector, I had to move the relays to get it in there but here is what it looks like on the bike:
Enjoy your lights - this could be used for any load on the bike btw (or in a car for that matter)
Nico
Nico is offline
post #3 of 65 (permalink) Old 04-09-2010, 06:52 AM
InsolentMinx's Avatar
very impressive...
Steve
'04 CBR 600RR
IBA #40198
InsolentMinx is offline
post #4 of 65 (permalink) Old 04-09-2010, 02:16 PM
DeathWish's Avatar
Why not just:
1) Put key in bike
2) Hold down starter button
3) Turn on ignition with starter held in
Same end result, only this "mod" is free, and doesn't require you to waste hours of your life with fussing with the electronics.
**2006 with Repsol kit**
-Full Akra Ti exhaust
-PCIII
-Flush Mounts
-DIY O2 sensor eliminator
-DIY FE
-Tripage Hugger LED mod (SICK!)
-EVAP canister GONE (must-do for aftermarket plastics on CA bikes)
-6k HIDs
-1/+2 520 conversion
-Black chinese rearsets
-Tinted DB windshield
My $.99 DIY O2 (oxygen) sensor eliminator
DeathWish is offline
post #5 of 65 (permalink) Old 04-09-2010, 08:17 PM Thread Starter
Nico's Avatar
Originally Posted by DeathWish View Post
Why not just:
1) Put key in bike
Just because I can... electronics is my job and my hobby so I consider the time well spent
I will also have my angel eyes on only when the bike is off, in Sydney your not allowed to have a blue light on the front of a bike (or car) when its running, thats what the yellow line on the wiring diagram is.
Nico
Nico is offline
post #6 of 65 (permalink) Old 04-09-2010, 08:51 PM
Duff's Avatar
Why not just:
1) Put key in bike
Maybe I'm just anal, but I could never do that to my bike. It's not letting the fuel pump prime, it's not letting the gauges go through their self test, good way to get a power spike and fry something.... that just seems like a horrible idea all around
Duff is offline
post #7 of 65 (permalink) Old 04-10-2010, 12:36 AM Thread Starter
Nico's Avatar
So for those of you who may be thinking of building this, you can appreciate the fact that once you pot it in you can no longer adjust it - could be a problem.
So in order to overcome this you will need a 1W resistor and a relay. Depending on which direction you wish to adjust in will depend on where you put the resistor ect.
If your headlights are coming on before you have started the bike then you need to wire it up as shown in the schematic below, if they wont come one at all then you need to wire the resistor (and relay contacts) into the GND line instead.
The schematic:
Nico
Nico is offline
post #8 of 65 (permalink) Old 04-22-2010, 04:19 PM
DeathWish's Avatar
It's really not. There is a guy on here that has been doing it for years, I first got the idea from him in one of the zillion "how to keep your headlights from turning on" threads that litter this board. I'm not going to find it for you. It's an old post on an old thread. Anywas, I've been doing it ever since I installed my HIDs, and it works flawlessly.
So what if the fuel pump is taking a few more tenths of a second to prime? What exactly is that going to do to your bike? I'll try to answer for your: your theory should suggest that it takes longer for fuel to get to the engine as it is cranking over, no? That's bullshit. Mine doesn't take any longer to start up using my method versus using the conventional starting method. Ever if it did take a little longer, SO WHAT? The battery has to crank a couple more cycles. Boo hoo. That's why mine lives on a battery tender. As far as your inflammatory "good way to get a power spike and fry something," care to back that up with some actual evidence instead of just fear mongering conjecture? Lastly, you're a Colts fan. END OF STORY.
But since Nico seems to be an electrician by trade, I'd like to hear from him on the possibility of "power spikes" and "frying" things.
-PCIII
-Flush Mounts
-DIY FE
-6k HIDs
post #9 of 65 (permalink) Old 04-22-2010, 09:34 PM
fteac70's Avatar
I wish I was as smart as you............... If you come up with more please post. I will not mock anyone for going the extra yard especially if they enjoy doing it.
"It only hurts till you die"
"No, that really wasn't just a hint it was a suggestion"
"Crash"
fteac70 is offline
post #10 of 65 (permalink) Old 04-23-2010, 05:52 AM Thread Starter
Nico's Avatar
Ok, (IMO)
I'm not actually an electrician, by trade I'm an electronics technician. I maintain and repair high power RADAR, satellite and inertial navigation systems.
The chances of power spikes occurring as a result of starting the bike the way you suggest are negligible. BUT power spikes can (and regularly do) damage a vehicle's electrical system, the way this most commonly happens is people start their car/bike then disconnect the battery. The battery acts as a really big buffer to prevent high over-voltage conditions occurring.
While we are on the subject of that old thread one of the posts suggested running a diode directly off one of the windings - This I would strongly advise against as placing that much AC voltage into the system is a long term recipe for disaster. Its exactly why you have a regulator in the first place!
However I'm with Duff in that I don't want to treat my bike this way (however ridiculous it is). I like to let it all prime ect. ect. and then start er up, I also don't let the revs get up to high before its warmed up a bit. But I don't leave it in the driveway idling to get warm either...
Anyway thats my 2c
BTW fteac70 you don't have to be smart you just have to have had a chance to learn, unless your Jessica Simpson - then you have no hope and probably shouldn't own a bike anyway...
As for more, I have just finished making the circuit board for a power friendly indicator flash rate fix, just have to put the components on it and its done - and it measures a small (LBH) 1.25" x 0.6" x 0.15", which is about twice the size of my thumb nail and draws less than 2mA (about 1700 times less power than the resistor method). hopefully it works!
Nico is offline
post #11 of 65 (permalink) Old 04-23-2010, 03:34 PM
sbRR's Avatar
Anyone know where we can get all these parts in the US? I'd like to try this. I've tried Digikey and Jameco and it doesn't seem like they have everything. I'd also like to get things from one place instead of having to order from multiple places.
- Sakeo
2008 CBR600RR - Pearl orange/black
Leo Vince Al S/O
Puig DB dark smoke windscreen
Proton flush mounts
Driven D3 grips
DDM 4500k HID
LP frame sliders
OES rearsets risers
R&G bar ends
Tripage clear IT and ADJ FE
sbRR is offline
post #12 of 65 (permalink) Old 04-23-2010, 04:13 PM
fteac70's Avatar
Nico,
I too am trained in the Electronic Field only since the stupid military has gone to COTS (Commercial Off the Shelf) for troubleshooting and repair, I have since not been able to play or learn any fun stuff with electronics. So as I gain experience in my job I am losing the knowledge I was originally taught.
I don't pay attention to how smart Jessica is, I just want to bang the crap out of her over and over again and then take a hell of a lot of nude pics of her on my bike. Then do it again. Like I care if she thinks buffalos have wings.
I appreciate the fact that some people obviously enjoy their work and hobby enough to share it. Good Day, Mate.
"Crash"
fteac70 is offline
post #13 of 65 (permalink) Old 04-24-2010, 10:29 AM Thread Starter
Nico's Avatar
Have just done a quick search and Digikey has everything you need, just search for the part number that is under the description heading - not the jaycar part number, the only one you may have trouble with is the relay but if you search for "255-2815-ND" you should find it no worries.
Let me know how you go! And if you have any questions just ask.
Nico
Nico is offline
post #14 of 65 (permalink) Old 04-24-2010, 11:15 AM
SLAPS808's Avatar
Feedback Score: 56 reviews
interesting...
SLAPS808 is offline
The Following User Says Thank You to SLAPS808 For This Useful Post:
zza_mud (04-27-2011)
post #15 of 65 (permalink) Old 04-25-2010, 05:25 AM
sbRR's Avatar
Nico
I had trouble looking for the potentiometer. I wasn't sure which one to use. Everything else I found ok. Thanks for the help. I don't know when I'm going to try this but I know I will.
- Sakeo
Leo Vince Al S/O
Proton flush mounts
Driven D3 grips
DDM 4500k HID
LP frame sliders
OES rearsets risers
R&G bar ends
sbRR is offline
post #16 of 65 (permalink) Old 04-26-2010, 12:10 AM Thread Starter
Nico's Avatar
Do a search for "490-2976-ND", it will do you just fine.
Nico is offline
post #17 of 65 (permalink) Old 04-26-2010, 12:23 AM
kenneth33's Avatar
I am an electrician and there is nothing wrong with what he did. you are more likely to damage your system from doing exactly what he said" starting the bike/car and then disconnecting the battery. Seems he likes doing it and just wanted to share his efforts, no need to down a man for his passion, after all, don't we all spend countless hours tinkering with our bikes? Thumbs up on the mod Nico.
Ok, (IMO)
Anyway thats my 2c
2008 Graffiti
Honda Racing rim stripes
Vortex swing arm spools
Proton flush mounts
Tripage tail light
Powder coat/ led pegs
Triapge FE led bracket
Leo Vince sbk evo 2
shorty levers
DB smoked screen
Technics MK5 1200's/denon mixer:my other two wheels
kenneth33 is offline
post #18 of 65 (permalink) Old 04-26-2010, 01:46 AM
sbRR's Avatar
Alright cool. Thanks man.
- Sakeo
Leo Vince Al S/O
Proton flush mounts
Driven D3 grips
DDM 4500k HID
LP frame sliders
OES rearsets risers
R&G bar ends
sbRR is offline
post #19 of 65 (permalink) Old 04-26-2010, 03:15 AM Thread Starter
Nico's Avatar
Thanks Mate.
My pleasure, happy to help.
And when your done can you post up some pics of your build?
Nico
Nico is offline
post #20 of 65 (permalink) Old 04-26-2010, 04:21 AM
thats waaaaay to hard for a stoner...
2007 honda cbr600rr
hot bodies race fairings, hotbodies double bubble, two brothers slip on, swingarm spools, power commander 3, custom taillight mod...
woodruff112 is offline
post #21 of 65 (permalink) Old 04-28-2010, 02:50 PM
dreamzboy's Avatar
Pretty interesting idea. Great work!
Just out of curiosity, if you have a weak battery that doesn't get charged to 14V or the threshold voltage to turn on the lights, that means your light will stay off until you change your battery or adjust the (I assume) potentiometer?
I currently have the timer delay relay and it works about 95% of the time. Sometimes it glitches and turns on my light when I turn my keys to the "ON" position.
dreamzboy is offline
post #22 of 65 (permalink) Old 04-28-2010, 03:09 PM Thread Starter
Nico's Avatar
Yep, spot on. If you are worried about this then you can wire a 12V switching line via a momentary switch onto the coil of the relay - with another diode - so that you energise the relay then it holds itself on.
Nico
Nico is offline
post #23 of 65 (permalink) Old 07-03-2010, 01:37 PM
DTMan101's Avatar
Over my head. Kudos though
DTMan101 is offline
post #24 of 65 (permalink) Old 07-03-2010, 01:52 PM
outamyway's Avatar
Yeah, I'm a chemist so this electronic stuff is miles above my head... so, for all us dumbasses, are you going to make these for us? I wouldn't mind giving it a go.
2003 Yellow Definitely the fastest color.
A thrill a minute may sound pretty good, but a minute is a long time to wait between thrills.
outamyway is offline
post #25 of 65 (permalink) Old 07-03-2010, 06:39 PM Thread Starter
Nico's Avatar
I might see about putting together a kit if Moe is happy...
How does something with a prefab board, (instead of the prototyping board I used) all components (minus plugs, potting box and potting compound), and instructions so you know where everything goes?
Just tell me what you think its worth, you can see what most of the components cost in the first post, transfer film for the boards is about $35, a pcb to etch it into is about $20 and the etchant is about $15. Those last three things should be good for about 50 boards though.
I'm also not an engineer so no warranties on the design, and no warranties on your workmanship and as such no warranties on components you have touched. Having said that, the components are all reasonably robust and mine has been in and working a treat for about three months now.
Just remember I'm not a vendor and I don't want to go breaking any rules so this may go no further...
Nico is offline
post #26 of 65 (permalink) Old 07-06-2010, 01:00 PM
z537z's Avatar
Feedback Score: 10 reviews
Nico - this is pretty cool - these are all really common components (like the 555) which makes it easy to source for the average joe - nice job! I'd use a resistor divider in place of the zener, which would cut your current draw way down.
Good to see there's another electrical person floating around these parts...
z537z is offline
post #27 of 65 (permalink) Old 07-07-2010, 01:47 AM Thread Starter
Nico's Avatar
Thanks mate, the idea was to keep the cost down as much as possible.
If you do that then it wont work. You need the zener to give a stable reference voltage that wont change as the bikes voltage changes, There is a resistive divider on the other input pin of the 741, this is the one that you want to change as the bikes voltage changes. As the voltage changes it will go above and below the voltage set by the zener and the 741 will drive its output to be within about 1V of the rail voltage (because it is in open loop mode). 555 is there to buffer the signal and supply enough current to drive the relay.
Nico is offline
post #28 of 65 (permalink) Old 07-07-2010, 12:32 PM
z537z's Avatar
If you do that then it wont work. You need the zener to give a stable reference voltage that wont change as the bikes voltage changes.
DYUUUHHHHH this is we don't go to work hung over
z537z is offline
post #29 of 65 (permalink) Old 09-10-2010, 04:02 AM
great job !
meferd is offline
post #30 of 65 (permalink) Old 09-10-2010, 05:36 AM Thread Starter
Nico's Avatar
Originally Posted by meferd View Post
great job!
Thanks mate!
Did you ever end up giving it a go mate?
Nico is offline
