Crush Washers - 600RR.net
post #1 of 16 (permalink) Old 09-11-2012, 04:39 PM Thread Starter
Crush Washers
Wheres a place i can get cooper crush washers for the brake lines? i dont want to pay the 3 bucks per washer at the honda store.
LCRfan is offline
post #2 of 16 (permalink) Old 09-11-2012, 04:45 PM
*BOTM Feb '11, Mar '12*
sincalirider's Avatar
Feedback Score: 27 reviews
Autoparts store or a supply chain for dealers.
sincalirider is offline
post #3 of 16 (permalink) Old 09-11-2012, 08:08 PM
CNI Dawg's Avatar
Feedback Score: 11 reviews
Call Brad @ Superbikesupply
I think mine cost about $3 for 5 Galfer copper washers in a package
63 and still having FUN !!
#737 BK Racing - CMRA
Sponsors- Dallas Honda, Impact Safety Armor
"The road to Hell is really grippy with loads of run off & some wicked lefthanders"
CNI Dawg is offline
post #4 of 16 (permalink) Old 09-11-2012, 09:01 PM
if you re-anneal them they can be reused.
provided they are in good shape.....
heat them red hot and let them air cool.
tary preisser is offline
post #5 of 16 (permalink) Old 09-12-2012, 02:37 AM
SLAPS808's Avatar
Feedback Score: 56 reviews
cyclegear.
SLAPS808 is offline
post #6 of 16 (permalink) Old 07-14-2013, 07:24 PM
NaturalPhenomenon's Avatar
Sorry to dig up an old thread. Anyone know what size our bike is
NaturalPhenomenon is offline
post #7 of 16 (permalink) Old 07-15-2013, 10:51 AM
Bump anyone know the size?
post #8 of 16 (permalink) Old 07-16-2013, 10:22 PM
Tater S's Avatar
Pretty sure that's 10mm
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
https://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
The Following User Says Thank You to Tater S For This Useful Post:
NaturalPhenomenon (07-17-2013)
post #9 of 16 (permalink) Old 07-22-2013, 04:52 PM
It is 12mm.
youngy is offline
post #10 of 16 (permalink) Old 07-22-2013, 08:54 PM
Tater S's Avatar
Originally Posted by youngy View Post
It is 12mm.
Oil pan crush washer is 12mm
This question whas posted in the wrong section as this is the Oil and Lube area.
Motorcycle brake stuff is usually 10mm
Tater S is offline
youngy (07-23-2013)
post #11 of 16 (permalink) Old 07-23-2013, 03:40 AM
you're more awake than I am Tater!
youngy is offline
post #12 of 16 (permalink) Old 08-13-2014, 10:37 PM
CProgrammer's Avatar
CRUSH WASHER OIL Filter
I revived this old thread because of the title and well that's what you should do instead of cluttering our forum with krap...
So I've always wanted to trot on down to the local hardware store and get like a dozen CRUSH
Washers since I buy my filters and Oil in bulk for the season from a local AMSOIL jobber ( highly recommend this BTW )
but locating a match for internal & external diameter isn't usually the problem its the freaking material.
Are these things aluminum or what I mean they should ""C R U S H "" right
it's in their name ---thusly ---- their function.
A steel washer -- ASSUMPTION-- just wouldn't be correct RIGHT ??
So if I can luck out on an internet search (not hard) for the correct inner & outer diameter what material am I looking for .?.
I just hate buying these from a dealership its FREAKING insane its just a washer after all..
Do we have a vendor handy that can hook me up ??
CProgrammer is offline
post #13 of 16 (permalink) Old 08-13-2014, 10:51 PM
Modcake with sprinkles
HighzerOfLife's Avatar
Images: 28
Feedback Score: 20 reviews
I believe they are aluminum. Usually crush washers are aluminum or copper but I believe the oem oil filters come with aluminum.
Someone correct me if I'm wrong please.
HighzerOfLife is offline
post #14 of 16 (permalink) Old 08-14-2014, 07:45 AM
Miweber929's Avatar
How often are you changing oil and how much is your dealer charging for these that cost is even an issue with these? Don't think I paid more than a dollar for each one, buy them a half dozen or so at a time and I only change them if they are deformed or otherwise worn. No reason if you use them correctly not to get a change or two out if them, I usually do.
But to answer your question either copper or aluminum (OEM) will work, and as long as the the ID is the same (the ID can be either slightly smaller or larger as long as it fits) will work fine. The reason you don't want steel is in the name like you said, crush washers. The idea behind them is to collapse slightly to:
1. Provide an oil tight seal
and
2. Provide a "crush zone" so SLIGHTLY over tightening the drain bolt would result in crushing the washer, not stripping the drain plug threads. But we all know that you can still strip the threads if you're not careful, especially with a reused washer, why you want to replace them.
Don't make it a big deal, next time walk into your dealer and buy a handful, probably under $5 for 6 of them and have them on hand. If your dealer is charging more than $1, go to another one.
Mike
Miweber929 is offline
post #15 of 16 (permalink) Old 08-14-2014, 01:39 PM
Official Dealer
Honda East Toledo's Avatar
Feedback Score: 5 reviews
The washer for the oil drain bolt?
94109-12000 is 12mm
94109-14000 is 14mm
Like 60 cents a piece.
Honda East Toledo is offline
post #16 of 16 (permalink) Old 09-27-2014, 09:21 AM
Can I get these washers at a normal honda car dealerships?
kDASH106 is offline
