How to change your oil without removing the fairings... - Page 2 - 600RR.net
post #31 of 183 (permalink) Old 11-20-2005, 10:29 PM
bastiz_mars's Avatar
thanks for the trick buddy It helped me a lot
Bastiz_mars from Montreal, cbr 600 RR 2004 , scotts steering damper, yoshi RS-5 slip on stainless, viper alarm system, michelin pilot power, fender eliminator ss kit! Watsen's Front turn signals, sportbikecam camera mount, progrip tank pad, 6500k front lights and plasma running light, spool sliders, frame sliders, pazzo shorties levers, led running light, reflective red rim tape, oem seat cowl and vortex adjustable rearsets.
bastiz_mars is offline
post #32 of 183 (permalink) Old 11-21-2005, 10:39 AM
The cup sockets have saved my butt a couple times. I just used one on my rr this weekend and used a 6 inch extension. Make sure you get the metal cup sockets instead of the plastic ones...the cheapy plastic ones suck.
Brocken is offline
post #33 of 183 (permalink) Old 01-15-2006, 10:40 PM
Ok so this might be a dumb question but i need to ask. You still gonna need to drain the oil, so wouldnt it be easier to just remove the fairing to drain the oil and since u already have the fairing off remove the oil filter as well? just what i think.
Daniel
"Great things happen where men and mountains meet"
pissces06 is offline
post #34 of 183 (permalink) Old 01-15-2006, 11:36 PM
lowzx3on17s's Avatar
Images: 11
Daniel
no, it's super easy to do it this way actually. i did it for my oil change at 3k, the first after my 600 mi service and i had great results, ie, no oil on headers or anywhere it shouldnt have been!
great write up
lowzx3on17s is offline
post #35 of 183 (permalink) Old 01-15-2006, 11:42 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
this is a nice write up. gonna be changing my oil here soon.
SLAPS808 is offline
post #36 of 183 (permalink) Old 01-23-2006, 04:14 PM
ok so i was able to remove the oil filter this way. didnt go as smoothly as it did for the author but it worked. Anyway i still have oil to drain, and im trying to remove thebolt to do so but i cant get it to come loose. and im gettign to the point where im scared im gonna strip the bolt. anyone have any suggestions on how i can finish this up? by the way im doing this without a rear tire stand.
post #37 of 183 (permalink) Old 01-23-2006, 04:45 PM Thread Starter
Images: 28
As long as you have the correct size socket or wrench (don't use pliers or vice-grips!) then I wouldn't worry about stripping it. I'm always able to loosen and tighten the oil pan drain bolt with just a typical 3/8" wratchet. You might try a longer wratchet or wrench for more leverage. A rear stand helps I'm sure but you should be able to do the job easily without one.
2003 CBR600RR
Ajax is offline
post #38 of 183 (permalink) Old 02-15-2006, 04:10 PM
yeah great tip bro. unfortunatly like everyone else with an 05' has said. it just won't fit through the pipes. thanks anyway.
bcreconRR is offline
post #39 of 183 (permalink) Old 03-23-2006, 09:42 PM
SniggiH's Avatar
Images: 4
do you have to drain the oil from anywhere else or just what comes out of the hole from the filter....i'm going to attempt this next week!
SniggiH is offline
post #40 of 183 (permalink) Old 04-03-2006, 07:56 PM
ILLstunter's Avatar
thanks that was sweet got mine done quick. oil only comes from where you remove the filter.. i did mine a little bit at a time so i had a very slow drain.. didn't get anywhere close to my fairings.
ILLstunter is offline
post #41 of 183 (permalink) Old 04-03-2006, 08:15 PM Thread Starter
Images: 28
You need to drain the oil from the oil pan too. There is a drain bolt that plugs the drain hole, once it's removed a most of the oil in the engine will come out from there. The oil that comes out when you remove the oil filter is a mere fraction of what's in the engine.
2003 CBR600RR
Ajax is offline
post #42 of 183 (permalink) Old 04-03-2006, 08:16 PM
ILLstunter's Avatar
yea sorry . i thought he was implying when removing the filter would oil only come from the single hole
post #43 of 183 (permalink) Old 04-03-2006, 08:17 PM
simplepinoy's Avatar
this worked for me on my 04, but a buddy of mine who has an 06 couldn't get the filter through the header pipes. he had to remove fairings and all that junk.
Born in Heaven, Trained in Hell, Unleashed on Earth
U.S.M.C
http://www.myspace.com/simplepinoy
simplepinoy is offline
post #44 of 183 (permalink) Old 04-09-2006, 11:19 PM
smokie31111's Avatar
thanks for the tip. I am changing my oil tomorrow.
smokie31111 is offline
post #45 of 183 (permalink) Old 04-10-2006, 12:29 AM
mikehal's Avatar
wear some of those rubber examination gloves and that'll speed up the cleaning of your hands.
"A good way to threaten somebody is to light a stick of dynamite. Then you call the guy and hold the burning fuse up to the phone. 'Hear that?' you say. 'That's dynamite, baby.'"
-Jack Handey
mikehal is offline
post #46 of 183 (permalink) Old 04-23-2006, 11:09 AM
Talking Mr
05 just take a hammer and a big crow bar and put it aginst the center header and knock the hell out of it about 3 times now you have room to get filter in and out :)
TWO71 is offline
post #47 of 183 (permalink) Old 04-23-2006, 02:51 PM
RandomStrata's Avatar
Images: 26
I've got an 06' and I was able to do this without removing the fairings
Just go out and buy a K&N oil filter KN-204 and you can wiggle it up in there the same way you got the first one out....think about it..if you can git it out you can get it in the same way.
RandomStrata is offline
post #48 of 183 (permalink) Old 05-04-2006, 02:24 AM
thank you ,you saved me some money,it worked easy
greenpea is offline
post #49 of 183 (permalink) Old 05-05-2006, 11:57 AM
Screamin' R's Avatar
awesome thread!! thanks!
06 CBR600RR
03 Audi A4 1.8T Quattro
00 Jeep Grand Cheroke Laredo
http://www.myspace.com/turnfast77
"If Jesus rode a motorcycle it would be a CBR600RR!"
Support FairTax
Screamin' R is offline
post #50 of 183 (permalink) Old 05-16-2006, 09:57 AM
MIXXX's Avatar
I tried it ..... thanx
MIXXX
2004 Candy BLUE RR
MIXXX is offline
post #51 of 183 (permalink) Old 05-31-2006, 04:31 PM
i have an 04 and it worked out great!!
Teetoly is offline
post #52 of 183 (permalink) Old 05-31-2006, 07:15 PM
Mister Dirt's Avatar
they make a filter screw thing for about 4 bucks. I just changed my oil and my neighbor had one which made it easy. plus u dont have to worry the hammer hittin stuff..
Mister Dirt is offline
post #53 of 183 (permalink) Old 07-05-2006, 09:59 AM
Hooked on Phonics
teleinfoncarr's Avatar
Great write up this was quick and easy thanks
NO BRAINS NO HEADACHE
The edge... theres no honest way to explain it, because thoes who know where it is have gone over..
teleinfoncarr is offline
post #54 of 183 (permalink) Old 07-27-2006, 03:21 PM
Lifetime Premium
Hawke's Avatar
I have an 06 and this worked great. The removal of the OEM filter was somewhat difficult but it happened. I use the K&N 204 filter which has a 17mm bolt on the end and my next oil change went even faster, bout 15 minutes including warming the bike up. I do not have any problems getting the filter between the headers.
Hawke is offline
post #55 of 183 (permalink) Old 07-29-2006, 09:07 PM
Fantas's Avatar
Good tip thanks, need to do an oil change in about 100 miles.
Fantas is offline
post #56 of 183 (permalink) Old 07-29-2006, 09:13 PM
600rr.us
great site for work
-Down1up2Gone-
2005 600RR
RS-5 slip
Vortex 15/45 520
Puig Carbon Double bubble
GPR Damper Gun Metal Blue
Vortex Sliders
Star lights
"Down 1, up 2, like clock work and Im gone"
down1up2gone is offline
post #57 of 183 (permalink) Old 08-08-2006, 01:36 PM
can u still do it this way with arata header installed? its such a tight fit.
kekoa is offline
post #58 of 183 (permalink) Old 08-08-2006, 01:39 PM
NewRedRider's Avatar
Images: 24
I found that some aftermarket headers didn't have enough room for the filter to fit between the header pipes. Take a new filter and see if you can make it fit between the headers from the bottom. You may have to do some creative positioning to get it through.
NewRedRider is offline
post #59 of 183 (permalink) Old 08-19-2006, 03:22 AM
Negative. I have a 2006 CBR 600RR, 3/06 build date, and there is no way the filter will come out the way you guys mention. The weld is too thick to pass it through on my bike. I tried it at every angle possible and I am seasoned enough at mechanics to guarantee I am correct in my finding. I think it is luck of the draw if it will work on a bike, depends on that weld which seems to be slightly different on each bike. In short, this will not work on all 05 and 06 RR's.
James06CBR is offline
post #60 of 183 (permalink) Old 08-19-2006, 03:47 AM
McShagger's Avatar
yep, with an '05/'06 this cant be done. With 05/06, you might as well take both farings and lower off. It makes the job easier.
McShagger
McShagger is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
3000K oil change with Repsol Racing full Synthetic Oil. e-saint Maintenance 13 08-29-2009 11:27 AM
Wtf! Bad Frame Slider Install And Oil Change! BRO6RR 03-06 RR Modifications 63 11-21-2006 02:16 AM
early oil change.. skimmilk68 Maintenance 30 09-22-2005 10:35 AM
Oil Change Ceph Off Topic & Flame Thrower 17 08-08-2005 11:27 AM
Changed to Synthetic Oil when should I change the oil again? MavrickDrummer Maintenance 5 08-14-2004 05:49 PM
