How to change your oil without removing the fairings... - Page 3 - 600RR.net
post #61 of 183 (permalink) Old 09-20-2006, 10:39 AM
TonyBarron's Avatar
Honda OEM Oil filter Removal wrench Part number
Honda Original part No. 07HAA-PJ70101 OR 07HAA-PJ70100 (USA) is the part number for a Honda OEM oil filter removal wrench. Hope this Helps.
Originally Posted by Ajax
I have a cup oil filter socket that I've tried to use but it always popped off whenever I tried turning the oil filter. I couldn't put enough "down" force on it to prevent it from popping off. It is the correct size but it's also a cheap one so that's probably why.
If I had to completely remove the oil filter using the pliers alone then it would be a real PITA since there's not much room to work. If that was the case then a cup socket & extension would work much better. At least in my case though I only tighten the oil filter hand tight so I barely have to move the oil filter to break it loose, then I can remove it totally by hand. The pliers are barely used.
TonyBarron is offline
post #62 of 183 (permalink) Old 09-26-2006, 06:58 PM
xcessiv's Avatar
Images: 7
Feedback Score: 5 reviews
yay i did it. the k&n just use a 17mm socket. way less of a pita!!
The brighter the picture,the darker the negative
xcessiv is offline
post #63 of 183 (permalink) Old 10-19-2006, 03:57 PM
C.F. A member **C.F. Whore ** :)
Jake007's Avatar
This is great info I will use this for my next Oil change
Jake007 is offline
post #64 of 183 (permalink) Old 10-21-2006, 11:58 AM
I've got to try that method today when i change my oil today
hwang8 is offline
post #65 of 183 (permalink) Old 10-25-2006, 10:58 AM
deemack79's Avatar
thanx 4 the tip
deemack79 is offline
post #66 of 183 (permalink) Old 10-27-2006, 09:07 PM
fasterfortheMaster's Avatar
i did it this way on my '06 saved me lots a time. was able to gently push filter out da bottom between stock header pipes. thnx 4the great info
fasterfortheMaster is offline
post #67 of 183 (permalink) Old 11-16-2006, 09:53 PM
TribalCBR06's Avatar
Images: 13
with this method, we don't have to remove the screw to drain the oil right? does the oil drain out completely by just removing and replacing the oil filter?
* * 600RR Ex-Track Junkie * *
Current bike - Yamaha Liquid Silver R1
- Competition Breeds Excellence -
TribalCBR06 is offline
post #68 of 183 (permalink) Old 11-16-2006, 10:26 PM
Serious? No, you have to drain the oil pan regarless of the oil filter being taken off or not.
James06CBR is offline
post #69 of 183 (permalink) Old 02-03-2007, 07:00 PM
Simmonds steak Do not leave the kitchen without it
Originally Posted by Jayock
Some aftermarket headers, like my yosh, cant fit the filter through. Have to remove the coolant resevoir. Oh well. I like pulling it apart anyways.
I found that out the hard way with my yoshi, then my oil drain bolt stripped (#@*... I love my bike but sometimes i just dont know about her...
yoyokata is offline
post #70 of 183 (permalink) Old 02-24-2007, 04:50 PM
Uncle Dave's Avatar
Just wanted to say this is a great post and very helpful, total time saver, Thanks.
Uncle Dave is offline
post #71 of 183 (permalink) Old 03-02-2007, 05:27 AM
Images: 13
ok now i know. i just did my oil change last week by just removing the oild plug underneath the bike. i didn't change out the oil filter tho. next time i will.
post #72 of 183 (permalink) Old 03-02-2007, 09:54 AM
NewRedRider's Avatar
Images: 24
For the very first oil change on the bike I would highly recommend changing the filter. You have a lot of break-in material in there. After that you can change the oil filter every other time if you want. It's good for 8k miles according to the SM.
NewRedRider is offline
post #73 of 183 (permalink) Old 03-09-2007, 03:26 AM
how many bottles of oil do u put in? 4?
bno817 is offline
post #74 of 183 (permalink) Old 03-09-2007, 11:29 AM Thread Starter
Images: 28
My '03 calls for something like 3.1quarts but I just buy 3 bottles and it always fills it up almost perfectly.
2003 CBR600RR
Ajax is offline
post #75 of 183 (permalink) Old 03-10-2007, 11:08 AM
I just tried this method last night. The only hitch was it took a little force to get the oil filter through the pipes. Thanks!
06' Silver 600 rr
RulingCzar is offline
post #76 of 183 (permalink) Old 03-13-2007, 03:43 PM
what size the bolt on the bottom? 12mm or 11mm? '03 RR
can anyone recommend a good wrench set? And I think I stripped my bolt, this happened to me on my F4i. Afterwards I brought this bolt, I forgot what the name was but it had a magnetic force on it, so it picked up a lot of those particles floating in the oil.
typeshx98 is offline
post #77 of 183 (permalink) Old 04-13-2007, 11:33 PM
Bucky045's Avatar
I just use the oil change as an excuse to clean inside all the fairings (minus the upper, PITA). Try putting some tinfoil down on the headers and shape it so the oil from the filter drains right away when it hits the foil. Another useful tip if you hate your bike smoking for 10/15 mins.
Dude awesome tip, never thought of this before but i will be using it soon.
yeah . . . . . . about that
Bucky045 is offline
post #78 of 183 (permalink) Old 04-16-2007, 09:09 AM
i just changed my oil yesterday on my 05 600RR, i have to move the frame and the coolant resevoir in order to get the oil filter out. it wan't that bad taking out the frame.
Sleeper00 is offline
post #79 of 183 (permalink) Old 04-16-2007, 09:21 AM
Negative. I have a 2006 CBR 600RR, 3/06 build date, and there is no way the filter will come out the way you guys mention. The weld is too thick to pass it through on my bike. I tried it at every angle possible and I am seasoned enough at mechanics to guarantee I am correct in my finding. I think it is luck of the draw if it will work on a bike, depends on that weld which seems to be slightly different on each bike. In short, this will not work on all 05 and 06 RR's.
i have 05 600RR, my bike is same as urs, have to remove frame and coolant resevoir to get the oil filter out
post #80 of 183 (permalink) Old 04-30-2007, 03:30 PM
mk600rr's Avatar
I change the oil and filter on my '04 this way and have no problems at all. Everything goes smoothly.
2004 Candy Blue 600rr
D&D Carbon Fiber Exhaust
LED Flush Mount Signals
LED Fender Eliminator
mk600rr is offline
post #81 of 183 (permalink) Old 04-30-2007, 03:48 PM
did an oil change yesterday to my '06 the filter dropped right thru the headers. fairing removal not needed!
soontobRR is offline
post #82 of 183 (permalink) Old 05-01-2007, 10:06 PM
frontslope's Avatar
nice man thats going to make things a lot easier fir me in the future. great job with those pictures also
frontslope is offline
post #83 of 183 (permalink) Old 05-14-2007, 09:12 AM
TurtlesScout
so u drain the oil from the filter? theres no screw like on a car?
06 600rr
jardine rt 1
hotbodies smoked flesh mounts
clear alternatives tail
kieti pads
speedoptions smoked windshield
vortex sliders
cbr grips
dds fender eliminator
ins516rr is offline
post #84 of 183 (permalink) Old 05-14-2007, 09:26 AM
Macho Office Monkey
chadandy12's Avatar
There is a screw just like a car twist it and let it drain out of the filterbefore you totally pull it off
08 600rr Orange/Black
https://www.600rr.net/vb/showthread.php?t=144174
Wifes new ride so pumped!!
chadandy12 is offline
post #85 of 183 (permalink) Old 05-22-2007, 11:52 AM Thread Starter
Images: 28
From my original post:
This post only details how to remove/install the oil filter without removing any fairings.
The procedure as outlined in the factory service manual has been posted in the FAQ forum so please refer to it if you have never changed your oil previously. I'm going to assume you already know how to change your oil already in this post.
The oil pan has a drain bolt, just like on a car. :)
2003 CBR600RR
Ajax is offline
post #86 of 183 (permalink) Old 05-22-2007, 09:23 PM
chef babu's Avatar
informative post!!
changed my oil in 15 min woooooooooot!!
i lined the headers with foil for the drippage worked out great.
chef babu is offline
post #87 of 183 (permalink) Old 05-25-2007, 12:43 AM
AFwestPunk's Avatar
my freakin oil filter wont come off! I am going to kill the tech who did the last oil change
OG PostwhoreScooter riding HK chasin' SOB
AFwestPunk is offline
post #88 of 183 (permalink) Old 05-26-2007, 04:04 PM
SrK
It is interesting that this procedure applies for some and doesn't to some other, even at the same model year.
I have a 2006 and it took me 15mins with this procedure and I didn't have to force the filter out or anything. After I unscrewed it, it just came of with no fight...
Anyways thanks....
BTW I put a K&N 204 in....
SrK is offline
post #89 of 183 (permalink) Old 06-03-2007, 09:52 PM
Todd_600rr's Avatar
Feedback Score: 8 reviews
Are the K&N filters smaller in diameter? Maybe the Honda filter are slightly larger?
03 600RR
Leo Vince Ti
Power Commander III usb
Galfer SS Brake lines
Zero Gravity BD Dark Smoke Screen
+3 rear sprocket
Todd_600rr is offline
post #90 of 183 (permalink) Old 06-06-2007, 12:12 PM
TonyBarron's Avatar
Good sockets will grip around the contact point of the head of the bolt without stripping it as much as standard types. Try a good tool shop and have a look at the types. The good ones grip each side of the turning force applied to the bolt, instead of the area, such as the coners its trying to burr and strip. Also try using WD-40 or similar overnight to loosen up road grime buildup.
Originally Posted by pissces06 View Post
ok so i was able to remove the oil filter this way. didnt go as smoothly as it did for the author but it worked. Anyway i still have oil to drain, and im trying to remove thebolt to do so but i cant get it to come loose. and im gettign to the point where im scared im gonna strip the bolt. anyone have any suggestions on how i can finish this up? by the way im doing this without a rear tire stand.
Similar Threads
Thread Thread Starter Forum Replies Last Post
3000K oil change with Repsol Racing full Synthetic Oil. e-saint Maintenance 13 08-29-2009 11:27 AM
Wtf! Bad Frame Slider Install And Oil Change! BRO6RR 03-06 RR Modifications 63 11-21-2006 02:16 AM
early oil change.. skimmilk68 Maintenance 30 09-22-2005 10:35 AM
Oil Change Ceph Off Topic & Flame Thrower 17 08-08-2005 11:27 AM
Changed to Synthetic Oil when should I change the oil again? MavrickDrummer Maintenance 5 08-14-2004 05:49 PM
