Previous owner overtightened oil filter - 600RR.net
post #1 of 23 (permalink) Old 04-10-2014, 09:30 PM Thread Starter
And this is the result:
Had to put a screwdriver through the older filter just to torque it off. Why do people do this? >.<
Channel-locks couldn't even get it off.
RealityRush is offline
post #2 of 23 (permalink) Old 04-10-2014, 09:37 PM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
Some people end up putting the screwdriver through the oil cooler as well.
TheX is offline
post #3 of 23 (permalink) Old 04-10-2014, 09:42 PM
BOTM Winner 03/14
D1stylz's Avatar
I know the feeling.
My simple build.
RIP SpdyG_AK 22 June 2014
D1stylz is offline
post #4 of 23 (permalink) Old 04-10-2014, 09:42 PM
They're on there really tight from the factory, a lot of people torque them to the specs listed in the manual. I don't torque mine super tight but you definitely wouldn't get it off without a filter wrench, or the screwdriver method you used.
PatrickRR is offline
post #5 of 23 (permalink) Old 04-10-2014, 09:51 PM Thread Starter
Oh man, that would be brutal. I'd cry.
I have a filter wrench, even that wasn't enough to get it off. Whoever put it on tightened the hell out of it, way past manual specs. There's no point in over-tightening anyway, it'll bottom out against the metal and you wont crush the o-ring any tighter.
post #6 of 23 (permalink) Old 04-10-2014, 10:09 PM
Tater S's Avatar
Amazing how many times this same subject pops up. It's kinda like:
What's the top speed, Best slip-on, 180 or 190 rear tire, best windscreen, etc. Well ok, maybe not as bad but it keeps popping up.
It probably wasn't over tightened, it was more likely torqued to spec or the first filter change lol
A lot of the time when people can't get the filter off it's not because the filter was too tight, it's because they're not using a good stout filter wrench.
When tightened to spec a lot of the crappy $3-$10 oil filter wrenches that everybody carries just slip on the filter because they flex too much or are too lose of a fit.
I tighten mine to Honda spec every time.
I started out with the cheap wrenches (meaning I tried a few) and ran into the same problem.
Now I have the Honda oil filter wrench that nobody wants to purchase because it's too expensive and I haven't had a problem since. Go figure
Honda 07AAA-PLCA100
__________________________________________________ ____________________________________
Thank you for purchasing a 600rr as your first bike.
The odds are strong that you will successfully add to our classified section and help lower parts prices
Crash Stats: Length of ownership
https://www.600rr.net/vb/showthread.php?t=313730
Tater S is offline
The Following 2 Users Say Thank You to Tater S For This Useful Post:
cbrkat28 (06-18-2014), PatrickRR (04-10-2014)
post #7 of 23 (permalink) Old 04-10-2014, 10:14 PM Thread Starter
And do you always only buy Honda genuine parts? ;P
I work with seals literally all day at work, hand tight would even be enough to seal the o-ring, anything beyond that you are doing so it wont vibrate off. It doesn't need to be so tight that a $9 filter wrench from Canadian Tire can't get it off.
post #8 of 23 (permalink) Old 04-10-2014, 10:42 PM
Tater S's Avatar
Like I said, I tried others BEFORE I purchased the Honda wrench. If I wouldn't have purchased it for $13 off ebay I'm not sure I would have purchased it. But I found out it works great, take it or leave it.
I figure Honda made the bike and they've probably tested everything to the point of failure. That includes the tightening spec on the filters that are made for their bikes.
If you don't want to tighten it that tight, don't.
Tater S is offline
post #9 of 23 (permalink) Old 06-18-2014, 05:43 PM
harry-nyc's Avatar
Feedback Score: 10 reviews
Everyone should just buy oil filter pliers and call it a day. Harbor Freight has them for $7, and come useful with aftermarket headers where you can't get the oil filter wrench to fit.
harry-nyc is offline
The Following User Says Thank You to harry-nyc For This Useful Post:
post #10 of 23 (permalink) Old 06-18-2014, 06:58 PM
Ldn
Ldn's Avatar
Screw that nonsense.
Use a screw driver and a hammer. No need to spend money on proper tools as long as you have a hammer!
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
The Following User Says Thank You to Ldn For This Useful Post:
cbr6racr (06-19-2014)
post #11 of 23 (permalink) Old 06-18-2014, 07:22 PM
TheX's Avatar
Images: 2
New sig.....
TheX is offline
post #12 of 23 (permalink) Old 06-18-2014, 09:17 PM
Ldn
Ldn's Avatar
Hah!
10char
Ldn is offline
post #13 of 23 (permalink) Old 06-18-2014, 09:41 PM
370Z's Avatar
Yesterday I had the same issue on my first 1000km oil change. Service Tech at honda told me to use the metal filter wrench they sell. I was done in 20 mn. without even having to remove the fairing.
370Z is offline
post #14 of 23 (permalink) Old 06-18-2014, 11:39 PM
Plastic filter wrenches are useless... you can buy the right size metal ones for under $10.
I don't tighten mine up that much. Till the o-ring first touches, then 1/2 turn.
Fritolay is offline
post #15 of 23 (permalink) Old 06-18-2014, 11:48 PM
cbrkat28's Avatar
I have the cap type for a 3/8 ratchet...it sucks
1971 Volkswagen 1302 (02.19.2015 - )
For Sale:
https://www.600rr.net/vb/153-07-13-rr...0rr-c-abs.html
cbrkat28 is offline
post #16 of 23 (permalink) Old 06-19-2014, 12:00 AM
In metal or nylon?
Fritolay is offline
post #17 of 23 (permalink) Old 06-19-2014, 11:18 AM
harry-nyc's Avatar
Screw that nonsense. No need to spend money on proper tools as long as you have a hammer!
Son if you can't fix it with a hammer you got yourself an electrical problem - old proverb
Ldn (06-19-2014)
post #18 of 23 (permalink) Old 06-19-2014, 12:27 PM
+1 on these pliers
gmang35 is offline
post #19 of 23 (permalink) Old 06-19-2014, 12:49 PM
Ldn
Ldn's Avatar
I wish I could thank this post more than once.
Ldn is offline
post #20 of 23 (permalink) Old 06-19-2014, 01:36 PM
cbrkat28's Avatar
Originally Posted by Fritolay View Post
In metal or nylon?
Metal...still sucks though
For Sale:
cbrkat28 is offline
post #21 of 23 (permalink) Old 06-19-2014, 03:07 PM
harry-nyc's Avatar
Originally Posted by gmang35 View Post
+1 on these pliers
Funny cause I did an oil change on my truck (Honda Ridgeline) and used the ratchet version which kept slipping. I bought a smaller one but ended up being the same size. I was looking for a solution in my toolbox and completely forgot I had bought these pliers ever since I switched out to arrow headers on the bike. Saved me a headache, just took an hour between buying the ratchet and finding them. I won't make that same mistake again.
post #22 of 23 (permalink) Old 06-19-2014, 05:31 PM
WRXSTi0487's Avatar
A good set of sticky gloves and strong hands of steel.... I had to use some channel locks the first time I changed mine though lol.
I have heard good things about this style from the Diesel truck community and plan on grabbing one with a wide range to work on everything I have.
http://www.amazon.com/Lisle-63600-Oil-Filter-Tool/dp/B0002SR4Q8/ref=sr_1_1?ie=UTF8&qid=1403213296&sr=8-1&keywords=oil+filter+wrench
2012 CBR600RR Black - Tripage IT STD, Black Powder Coated Subframe, Rear Pegs, and Rearset with LED turn signals in pegs and LED brake lights in the subframe all modded by Tripage, Proton Flushmounts, ZG Double Bubble Windscreen, Arrow Titanium with Carbon Tip - Modified by Tripage, Tripage Dual Headlight MOD.
WRXSTi0487 is offline
post #23 of 23 (permalink) Old 06-21-2014, 01:52 AM
mran556's Avatar
good channel locks also work in a pinch
honda put them on very tight from the factory
2007 Cbr600rr Black
mran556 is offline
