Engine cruising temperature - 600RR.net
post #1 of 17 (permalink) Old 07-07-2014, 10:29 PM Thread Starter
I ride all the time. While cruising on the freeway, my cbr600rr 2006 temp guage reads 177-178 ish. Yesterday while riding on same freeway, my guage read 200-215. Is that a problem??
jd4qtoes is offline
post #2 of 17 (permalink) Old 07-07-2014, 11:13 PM
shouldn't be a problem......if you have a strong tailwind or are tailgating cars the temp can climb quickly due to reduced airflow across radiator.
Should start to drop as soon as you are in normal wind conditions......
tary preisser is offline
post #3 of 17 (permalink) Old 07-11-2014, 03:44 PM
06/2016 BOTM Winner 07/2015 BOTM Winner
VenomRR's Avatar
Mine fluctuates a lot and it all depends if your in open clean air or not.
2008 Graffiti Edition
- Flush Mounts
- Fender Eliminator Kit
-Yoshimura RS-5 Slip On
FACEBOOK: https://www.facebook.com/GRAYFOXRR
MOTOVLOG CHANNEL - https://www.youtube.com/playlist?lis...4RgoTbx9yqHhfY
VenomRR is offline
post #4 of 17 (permalink) Old 07-19-2014, 05:24 PM
tylerjoe167's Avatar
it should fluctuate when riding in traffic when drafting
tylerjoe167 is offline
post #5 of 17 (permalink) Old 01-12-2015, 12:22 AM
At what temperature do you have to worry about over heating issues? I have an 03 600rr.
vex4ever is offline
post #6 of 17 (permalink) Old 01-12-2015, 01:44 AM
Alvaro's Avatar
Read up on this, great information.
https://www.600rr.net/vb/showthread.php?t=196767
Alvaro is offline
post #7 of 17 (permalink) Old 01-14-2016, 09:43 PM
jawsolsen333's Avatar
mine usually chills around 174-176. but gets up to 220 if I'm going real slow or at a stop for a while
jawsolsen333 is offline
post #8 of 17 (permalink) Old 01-14-2016, 10:51 PM
If you start approaching 250 you should worry, as in pull over and stop the engine. The warning light on your gauge cluster will come on around there to let you know. If your fan is kicking on at 220 and the temp drops from there or a few degrees above, you're fine.
ar556 is offline
post #9 of 17 (permalink) Old 01-15-2016, 01:40 AM
YG27's Avatar
On hot days I'll be at 220. At night on the same day around 190, freeway to myself I could get down to 181ish.
2A7X3. Aircraft Structural Maintenance.
Any corrosion (Paint, priming, identification, etc) or Fabrication (Sheetmetal, Fiberglass, Tubing, etc)
questions, go ahead and ask and I'll do the best to respond to the best of my knowledge.
Current : '08 CBR1000RR 20160213
Wrecked: '05 CBR600RR 20151221 RIP
Crashes: 2 minor low speed lowsides, 1 50MPH impact.
Injuries: 0 Broken bones, possible tear in shoulder.
YG27 is offline
post #10 of 17 (permalink) Old 01-15-2016, 07:22 AM
Nuithari's Avatar
Mine's usually between 72C and 78C (162-172F)
But can flucuate according to wind, like someone said earlier
Nuithari is offline
post #11 of 17 (permalink) Old 03-23-2016, 10:27 AM
Kyle Harris's Avatar
Yeah Mine usually is in the 170's when I've got open air and cruising I've never seen mine get above 220, the fan always kicks in and brings it down.
Kyle Harris is offline
post #12 of 17 (permalink) Old 03-23-2016, 11:46 AM
darcshadow's Avatar
You only really need to worry if/when the fan kicks on and the temp continues to climb. Even in Texas heat and top and go traffic the fan on mine was good enough to hold the temp and stop it from climbing.
I Refuse to Tiptoe Through Life...Only to Arrive Safely at Death.
FWMR.net Webmaster
darcshadow is offline
post #13 of 17 (permalink) Old 04-30-2016, 11:18 PM
Ace 1's Avatar
Yeah mine the same...
Ace.
Ace 1 is offline
post #14 of 17 (permalink) Old 05-24-2016, 11:52 AM
I have very occasionally seen up to 230 in traffic and 85 degree humid heat...but once I start moving over 40 mph temps drop down to 170-190
03 CBR600RR
07 Ninja 500R
02 CBR600F4I
Mitchypaps is offline
post #15 of 17 (permalink) Old 05-27-2016, 12:24 AM
Same here, but once i start moving it drops back down
"Work Smart, Not Hard"
07 CBR 600RR
amit16 is offline
post #16 of 17 (permalink) Old 06-14-2016, 04:10 PM
Same here, 220 is pretty much the highest I've ever seen it.
'07 600RR | '07 exige s | '07 cayman s | '95 240sx | '03 y34 | '85 girlfriend
kneepuck_envy is offline
post #17 of 17 (permalink) Old 07-11-2016, 06:38 AM
littlebr4d's Avatar
Highest I've ever seen mine was 221, but that was sitting in gridlock traffic on a 100 degree day on a highway, surrounded by other hot cars. Cruising I'm usually 170-185.
2015 Matte Silver Yamaha FZ-09
2007 Pearl White 600RR [sold]
1989 Yamaha FZR400 [sold]
1980 Honda CX500
littlebr4d is offline
