You got Questions About OIL ** step inside please ** - 600RR.net
post #1 of 381 (permalink) Old 04-26-2006, 08:56 AM Thread Starter
vizsladog's Avatar
Take the time and read the links on the left.
Oil is always a hot topic.
http://motorcycleinfo.calsci.com/Consumables.html#Oil
I use the Shell rotella t syn
vizsladog is offline
The Following User Says Thank You to vizsladog For This Useful Post:
BikerMonkey (11-24-2014)
post #2 of 381 (permalink) Old 04-26-2006, 12:31 PM
Sodamninsane's Avatar
Images: 15
wow there's a lot of info there... good find.
Sodamninsane is offline
post #3 of 381 (permalink) Old 04-26-2006, 12:38 PM
DarkS1de's Avatar
Images: 13
i agree, this should be a sticky
thanks for the link
2006 Red/Black
DarkS1de is offline
post #4 of 381 (permalink) Old 04-26-2006, 01:07 PM
ME2
ME2's Avatar
Images: 18
Excellent find...
I personally use AMSoil 10-w40
ME2 is offline
post #5 of 381 (permalink) Old 04-26-2006, 01:15 PM
Jotaro's Avatar
Feedback Score: 7 reviews
+1
I rock 'em too.
Now you're just talking out of your ass, dude.
Sent via DingleBerry® waterless device.
Jotaro is offline
post #6 of 381 (permalink) Old 04-26-2006, 01:36 PM
AlpineJim's Avatar
Take a time an read the links on the left.
Or put in the FAQ section and then sticky it there..
+2 on the shell rotella t syn...
Matthew
03' 600rr - Track
AlpineJim is offline
post #7 of 381 (permalink) Old 04-26-2006, 01:39 PM
railed's Avatar
wonder how much shell paid for that to be posted
"You're not Worthy"
railed is offline
post #8 of 381 (permalink) Old 04-26-2006, 02:13 PM
C.A.H.N founder / President
CBR/LS1's Avatar
Images: 10
Good info. Thanks.
CBR/LS1 is offline
post #9 of 381 (permalink) Old 04-26-2006, 05:54 PM
Back in the Day
Moeman's Avatar
Images: 665
Feedback Score: 148 reviews
viz
i changed the tiltle to attracr attention and made the post a sticky in the maintenance section great link bro good work
Moeman is offline
post #10 of 381 (permalink) Old 04-27-2006, 12:31 PM Thread Starter
vizsladog's Avatar
THANKS MAN...
Glad it is helpful.
post #11 of 381 (permalink) Old 04-27-2006, 12:56 PM
Johnny Candles's Avatar
Excellent find. Glad to see it's a sticky now.
- Candles
Johnny Candles is offline
post #12 of 381 (permalink) Old 04-27-2006, 01:03 PM
knightrider578's Avatar
dang. nice find on the oil... i was gonna go with castrol for synthetic until i read this
knightrider578 is offline
post #13 of 381 (permalink) Old 04-30-2006, 01:27 PM
taj8250's Avatar
for those of you that use the shell rotella... is it the stuff you can get at wal-mart that has all the stuff on the back about how it's good for diesel engines?
taj8250 is offline
post #14 of 381 (permalink) Old 05-01-2006, 01:58 PM Thread Starter
vizsladog's Avatar
yup,blue jug at wally world...
shell rotella t snythetic
The Following 2 Users Say Thank You to vizsladog For This Useful Post:
raihan91 (12-25-2013), RyanK (06-09-2014)
post #15 of 381 (permalink) Old 06-03-2006, 10:00 PM
Images: 2
Exclamation valvoline 10w40 mc oil = bad
do not use the new valvoline 4stroke motorcycle oil in 10w-40. i just did an oil change in my 06 rr and it sounds like everything is loose in the motor/trans.
im goin tonight or tomorrow to get the shell rotella t syn in hopes it quiets it up.
HomegrownPerformance is offline
post #16 of 381 (permalink) Old 06-12-2006, 08:36 AM
NewRedRider's Avatar
Images: 24
The only objections I have to this site is the Mobil 1 Extended Performance (Gold Cap) and the filters. I have personally used Mobil 1 EP oil and had clutch slippage with it. I would also stick with the OEM filters. I would also agree to stick with a 10w-40 weight oil.
Does it make the clutch slip?
NewRedRider is offline
post #17 of 381 (permalink) Old 06-12-2006, 09:08 AM
OveRReV's Avatar
Images: 16
i use 10W-50 oil on mine & i haven't had clutch slippage issues with it.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #18 of 381 (permalink) Old 06-12-2006, 09:49 AM
Images: 24
Repsol? Repsol is good stuff. I've only used one other 50 weight oil that would agree with the bike and that was Mobil 1 Red Cap (15W-50). But the 50w oil doesn't make the clutch slip. It makes the Cam Chain Tensioner tick like crazy because the heavier oil makes the oil pump work harder when it's cold. It has problems getting oil up to the top of the motor so the CCT runs dry for a few minutes during cold starts.
post #19 of 381 (permalink) Old 06-14-2006, 11:33 AM
TonyBarron's Avatar
After the read Im considering changing oils. Its a big read and Ive gone a bit into it now...
TonyBarron is offline
post #20 of 381 (permalink) Old 06-14-2006, 11:37 AM
Images: 24
post #21 of 381 (permalink) Old 06-14-2006, 12:18 PM
OveRReV's Avatar
Images: 16
yes mang, Repsol 10W-50. :01_thumbu
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #22 of 381 (permalink) Old 06-14-2006, 01:33 PM
jlagss's Avatar
I've used repsol racing 10w50 twice in my bike. It's super smooth for the first 1000 miles then it turns to junk...same results with the Rotella T. I've also used Motul e tech with better results... I've used Amsoil on two separate occasions and i've found it to be the best of the bunch.
jlagss is offline
post #23 of 381 (permalink) Old 06-14-2006, 01:46 PM
Images: 24
Are you running track or street.
post #24 of 381 (permalink) Old 06-15-2006, 08:02 PM
Rotella T 10w-50 non syn
ShaunMood is offline
post #25 of 381 (permalink) Old 06-16-2006, 01:36 AM
simplepinoy's Avatar
i've always gone with mobile1 mx4t 10w-40.
the site says, "10w-40 oils should not be used in a motorcycle that runs the engine oil through the transmission." why is this? cuz our oil runs through out transmission right?
Born in Heaven, Trained in Hell, Unleashed on Earth
U.S.M.C
http://www.myspace.com/simplepinoy
simplepinoy is offline
post #26 of 381 (permalink) Old 06-16-2006, 01:51 AM
OveRReV's Avatar
Images: 16
yes our engine oil also lubricates our transmission gears too, i don't know about the Mobil website but if the oil in question is made specifically for bikes then i don't see the problem in running 10W-40 oil.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #27 of 381 (permalink) Old 06-19-2006, 05:39 PM
hey, I am going to make the first oil change (600 miles) I heard it was better to use regular oil than synthetic for this one. Is that true? why? For oil I was thinking about using repsol. What do you guys think?? any advise???
CRAZY_600RR is offline
post #28 of 381 (permalink) Old 06-19-2006, 10:49 PM
OveRReV's Avatar
Images: 16
Repsol is the goodstuff Crazy-dude & yeah i think you should run mineral based oil for this oil change before you step up to 100% syth oil.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #29 of 381 (permalink) Old 06-20-2006, 02:55 PM
Images: 24
I have to disagree with your Rev. There's no reason why he can't change over to synthetic oil. It doesn't stop friction and it won't effect the break-in. If it did you wouldn't see car manufacturers running Mobil 1 straight out of the factory. IMHO, that's another urban legend started by the dealers to make you buy thier oil.
post #30 of 381 (permalink) Old 06-20-2006, 02:56 PM
Images: 24
Provide a link if you can. They're most likely talking about a specific type of oil as they know it has too many friction modifiers for a wet-clucth application.
